Brad-ManQ45
    7
  1. Keep in mind that that hood bulge also acts as a stiffener for the hood...
  2. According to my Consumer Review buyeres guides form '90 an d'91, all Q45's had Limited slip. I know that my '94 Q45a has it. If my basement weren't in such a mess from a broken water heate, I might have found my '93 and '95 volumes.
  3. This time I can see all of the pics - go figure!
  4. Unless I'm wrong (won't be the first time), If you are willing to buy pistons and have the block bored and the rotating assembly balanced, you can have your 327. I doubt very seriously that GM made the block casting water passages larger for the 307 vs the 327/350 - they probably just bored the cylinders smaller. 3.88" bore vs. 4.00". smame stroke as the 327. You could truly have a fresh 327! All it would take is money. Of course you'd probably want different heads, cam etc.
  5. Hey Denny - I tried to email you but got the message back. Can you update your profile so I don't have to use this site to continue a dialog? Brad
  6. Denny - Sorry about the zoo - hate disappointing the little ones myself. My little ones are all the neighbor kids now - our son is at West Point. I got lucky, because after reading yours and associated posts, I remembered my Northern catalog at looked at the two types of scalers they had in it and one looked like an air hammer w/the attachment you thoughtfully told us about. I went to the Harbor Freight site and did a search for air tools/hammers and voila, got bigger pictures of the CP stuff, went to the garage and pulled out mine and what a match - identical! To be honest, I hadn't thought about using a scaler until your post (at least for undercoating removal). My wife has relatives in Tallapoosa, we actually live in Marietta. The next time one of us comes the other's way we should try to get together, ooohhhh and aaahhhh over the other's project - I should come to you first - I haven't done anything but tearing out the interior and buying floor pans and patch panels yet. I'm taking welding classes for the MIG welder I bought. Should have had the engine out this weekend but the timing wasn't right for my niece's boyfriend to let me use his workplace after hours I've got all the tools but the availability of the lift and hoist at the shop make it monetarily and physically more comfortable - and I'm starting to realize I'm not a young man anymore... Classes last for about 4 more weeks and then I'll start on a rotisserie. Keep us posted on what your doing and other bright ideas/time/work savers you come up with! Brad
  7. The Streetmaster ought to be OK w/your 600. PRobably won't be an IDEAL match for the cam like a performer, but better than the VJ. As I recall, this one was for 2500-6500 rpm vs 1500-5500 for the dual planes. You will probably loose a little low-end torque, but you have more than you need anyway! After you build the engine, use the Victor Jr. a(assuming you have the cam can carb for it). I will probably use a Victor Jr. for a FI system I wnat to put in.....
  8. Harbor Freight has the head attachment for 14.99 Scaler Attachment This fits the Air chisel made by Chicago Pneumatic, which Harbor also sells, as well as Northern. The replacement blades are $10. It appears as though the air hammer I got w/my Coleman compressor just so happens to be made by Chicago Pneumatic! (it's identical to Harbor Freight and Northern's Air Hammers). Hope I've saved someone some money... Brad
  9. For what it is worth, I believe you would be much happier w/a mandrel bent 2.5". Definitely quieter (less droning) and weigh less. N/A engines DO like a little backpressure as compared to Turbos (which don't like ANY). Supercharged engines act about the same as N/A except are generally happier w/a bit more exhaust. For exhaust discussion purposes, I will lump the N/A and supercharged engines together and turbos in their own world. A lot of people I have talked to and heard from for N/A z's recommend 2.25" to eliminate droning at certain rpms (I have a '75 that has header w/2.5" and it DOES drone - this will be rectified when I swap in the V-8 and hopefully - turbo it), so 2.5" would probably be fine for you. The nice part is - these can be had fairly inexpensively to bolt in from MSA/others, or have it done at a GOOD shop in your area. Of course I am assuming that you are not going to be running super high boost (no intercooler) and nitrous. If this is a weekend toy then you may want to go bigger but I personally wouldn't. I had a 2.5" w/Flowmaster on my '83 ZXT and hated it drone at idle and below 2500 rpm and not much better on the highway. Went to a 3" stainless mandrel bent system w/straight through oval Ultraflow and not only quieter, builds boost faster and has better top end. Remember though that this is a turbo, so you start out quieter. I have a pet theory about the cancellation type mufflers and turbos - I don't think they work as well at quieting, because the exhaust pulses are a bit dampened/stretched, so there is a disparity between the affect on exhaust noise reduction between N/A and turbos that tend to favor them for N/A cars. If there is in fact a scavenging effect to the Flowmaster type mufflers, the dampened pulses from the turbo would tend to support my pet theory, and at least one magazine article I can remember did a muffler comparison on a turbo car and the Flowmaster did not do as well as the same I/O Dynomax of approximately the same size (noise or acceleration). Since I went up from 2.5" to 3", acceleration times comparisons would be unfair. But the overall enjoyment of the car cannot be stated enough. Instead of the hollow droning at all times around town, you get the sound like came out of stock Musclecars when I was a teen (late 60's early 70's) and no,my memory is not shot - I had my 72 351CJ Mustang (BOUGHT IN '74) until a few years ago (when I bought it my girlfriend's mother said it was the first car a boyfriend had that sounded just right - quietly powerful)! OK, I'm off my soapbox now Brad
  10. Definitely have to have the turbine/housing separated if you're even goin to try it - tolerances very close. What do you hope to gain? Can't guesstimate the engineering effects that the larger area uncovered vs. ability of stock actuator to operate. Going to higher levels of boost, it doesn't take much to bleed off enough, unless you go supersize on compressor. If you're goin that far better off w/a separate wastegate.
  11. Sounds like the wiring in your car for the ignition system should be replaced - the wiring between the ignition switch and where you hot wired it.
  12. I can't see the pics above, is this a setting in IE that needs to be set? Thanks, Brad
  13. Several of us seem to be at the same stage - new welders, planning rotisseries, etc. I still have 4 more weeks of welding class before I start doing anything. 1st project - Rotisserie. Good luck to us all!
  14. Unless MSA has found a new source, or fibbed when I got mine - I was told I got the last Drivers' side Qtr Panel they had. I have been browsing Northern and the internet and have looked seriously at the flange tool, because I also have patch panels for the lower front fenders. Until I get out of welding class (4-5 weeks), I have plenty of time to scope this stuff out. MillerMatic 175 still in box waiting for C25 mix and ME! I will probably build the rotisserie first though, so I can do as much welding horizontally as possible. I'm itching to get started - tearing the car apart just isn't as satisfying as putting 'em back together! I like the idea of steel flares, but the only ones I have seen are too wide for my taste - I'm thinking 1.5 inches apiece could be the ticket. If I'm the first to use the flange tool, I'll post my impressions here for everyone else, but will definitely keep my eye on any later posts! If anyone does find a source still supplying good body panels, it'll be good to know also.... brad
  15. If your vehicle did not have cats to begin with you do not need them w/a later engine - all other smog stuff DOES have to be present.
  16. Buy one that fits a Mustang T5- it'll work (assuming you're using one. The T-5 that came in 280 ZXT's were different only in Belhousing, input and output shafts. Hurst
  17. I haven't been able to find a REALLY good discussion of the benefits of H-beam over I-beam and under what situations. What about turbo engines? One thread I found stated that H-beams are great for High Rpms, but not a LOT of torque. (Once again - just passing on what I read - I don't know enough to comment - that's why I'm posting this) I'm hoping for some MAJOR illumination here.... Brad
  18. Brad-ManQ45
    Sad day
    Don't forget traction aids for all that power to the rear wheels... Anything that shifts to the rear will help. My favorite are fuzzy dice - loaded of course.
  19. Here is a link to articles about modifying these.... web page
  20. I believe Pete has plans on his site: http://members.home.net/pparaska/structuralmods.htm
  21. Thanks a bunch for the article Jeff! I'll be doing this just as soon as I have built my rotisserie, which is just as soon as I finish my welding classes. Timely info, to be sure.... Brad
  22. Ok I've searched everywhere I can think of and found no way to determine if the Neapco part JTR sells will fit. I looked at an R200 out of a 300ZX NA last night and could'nt determine where the measurement is taken for the pilot flange to tell 2" or 2.25. It was not intuitively obvious, but I'm sure someone out there has the info. If you could share it with all of us, I know I'd appreciate it! Thanks, Brad
  23. Been a while since i looked at DFI - my bad. Never thought of anything BUT sequential. Will definitely look at DFI again. AEM - Didn't someone say that the interface for it seemed overly complicated? I like the sound of the DFI detecting bad sensors and acting on it... Will investigate AEM too... Don't know how I missed the later posts on the prior thread - must have been busy/braindead (I prefer thinking the former, but more than likely the later )
