Brad-ManQ45
    8
  1. Glad it worked out! I will be doing one of these swaps myself if I ever learn to weld well enough to replace a qtr panel and patch the fenders and remove the driprails. Then it will be paint, wiring, brake/fuel lines, interior and FINALLY engine.... I'm just a glutton for punishment - I've always wanted to do a ground-up - always done engines, suspensions, brakes, bodywork (no welding) on the cars I've had in the past, and helped by brother restore a '66 Datsun 1600 (Short Windshield). I'm gonna experience fun, pain, anxiety over every decision, but most of all SATISFACTION - especially the first time I crank it up!
  2. Chevrolet first used fuel injection (in production) on the '57 Chevy and Corvettes. Volkswagon had fuel injection on the TypeIII engines (Squareback and Fastbacks) in 1970 for sure - I had one. Fuel injection has been around a LONG time and Chevrolet wasn't the one to develop it.
  3. The carb you have should be just fine on a 350. Chevrolet used a 780 on the Z28 (302). I had a Holley 780 on my 351 CJ Mustang before going to a 700 double pumper. Hd tried a 600 to start but like the 780 MUCH better up top. I had all the springs and cams for the accelerator pump at one time...this was back in '70's and 80's - wish I'd never sold that car.... Something is Definitely wrong with the carb if the secondaries don't open.
  4. Thanks for the info - interesting about the tranny, as I'm thinking 4l80E for the turbo v8... Brad
  5. Looks soooooo sweet. Very sanitary. You're and artist man - I hope I can get my engine room looking HALF as good.
  6. '83 factory service manual states standard 142 lbs at 350 rpm, 100 minimum. For the normally aspirated engine, 171 and 128 respectively. Yes- I bought the Service manual in 1990 when I bought the ZXT! Saved my bacon (money) a few times and glad of the purchase.
  7. I am definitely interested, but haven't made the decision on single or dual. One way to minimize lag is to get a divided turbine housing and do some trick work with the exhaust to supply each side w/even exhaust pulses. I am going turbo because I want the car quiet (relatively) so I don't beat my ears to death every day. Ok - that's only HALF the truth - I also want to shame some of the 'vettes and Vipers running around Atlanta
  8. I believe NHRA REQUIRES tubing, not pipe. S&W specifically states tubing on their website. AutoPower makes some rollbars and cages (bolt-in) that ARE NOT leagal for NHRA (but ARE for SCCA). These are made of pipe. Even if they were welded in they wouldn't be legal for NHRA. If I am mistaken I hope to be corrected... Brad
  9. I believe in my reading about the LT1 engine that the EGR is an integral part of the air/fuel/timing mix that allows a signigicant improvement in gas mileage by allowing leaner A/F ratio and more spark timing for low speed operation. Of course, most of us don't have much concern about gas mileage, or we'd keep the original engine, but if I were not going to do much in the way of modifying the engine for more power (just slap in the LT1 w/stock management and call it quits) I'd try to keep the EGR... Brad
  10. I have to go w/the Challenger. Even though I've had a '73 Javelin and a '72 Mustang 351CJ, the Challenger has to be the best looking pony car ever made. Wish I'd bought one of those instead...
  11. One place to look at what has been done on a production vehicle, if I remember correctly is the Ferarri 360 Modena. If I remember correctly (again) there was a small raised area in the center of the front air dam tunneling back to an enlarged area (providing a low pressure area under the front for downforce there), then making its way back to the rear diffuser (pproviding downforce in the rear. I believe I saw all of this in a Road & Track magazine a cople of years ago. This would tend to modify somewhat the flat bottom theory, which addmittedly is better than nothing if rake is provided, but then the windshield is at a higher angle of attack, providing more drag, and possibly leading to buckling/collapsing. Anyone else recall seeing the design I'm talking about? I of course have eliminated a lot of stuff that they did on the Modena, but another trick was to have oval/elliptical susension arms that had to go through the tunnels to get to the wheels etc. It was interesting reading at the time - maybe I can scare the article up - if I can get past the scary thought of searching through all the boxes from the move..... Brad
  12. No such luck w/ other T5's - they have different input shafts. The ratios on the SVO Mustang are the same, but once again, input shats different. Find a wrecked ZXT 5-speed and get the transission from. Thi sis the only option.
  13. Veeerrrryyyyy Nice ZR8ED! Hope mine looks as nice when finished...
  14. Keep the rods the same (no reason not to - same pin height) and design the smaller diameter pistons to weigh the same as the larger diameter 350 pistons and you save money by not remachining/designing the hardest part - the crank. This one instance is extremely likely....
  15. Actually larger turbos at the same boost produce LESS heat...the compressor doesn't have to work as hard.
  16. Definitely check out the flow @ the pressure you need to run on your efi system. Basic measure (if I remember correctly is .5 lb per hp per hr. Gas weighs (?) ~6.87 lbs/gal (again - thisis the measurement I REALLY can't remember). Figure ~450-500 HP AT THE RATED FLOW - what happens at lower pressures used on most systems?
  17. HRE makes wheels like this (custom). Depending upon size can get SUPER expensive.
  18. My understanding is that even w/LT1 Edit, the stock computer doesn't read boost - you have to kludge other values. I too, would like to use the stock system, but won't until boost is capable of being read. BTW, Compression is alittle high on the LT1 (cam too big to?). I going to run more than 6 lbs boost, would probably want to replace rods. I've been researching this for a long time - I like the reverse cooling aspect for turboing..... Brad
  19. Leonard: I debated whether to tell you about the electrical connections. I swithced mine around when someone else disconnected them (had to replace the boot between AFM and Turbo and he didn't mark 'em) and the blower would only come on once the car reached ~2500 rpm! Nissan in their infinite wisdom put the same half of the connector on each wire TO the equipment instead of swapping them around so that you could only connect them one way. Easily fixed as soon as I tried using the AC, but irritating anyway (much like the Q45's door lock switch - press down to unlock and up to lock). I just LOVE counter-intuitive.... Glad you found the problem(s). There are quite a few people here from ZCar.com - both are great sources for help.
  20. These are called 180 degree cranks. Ferrari uses it in the 360 Modena. If I remember correctly, circle track racers used them (may still for all I know). A little rougher than typical V* crank, but that RIPPPPING sound is neat! Who can can tell us more! Brad
  21. The combination you want - good launch, decent ride and big tires would seen to indicate coilovers - keep the length for wheel travel/squat/ride and the narrowed springs allow for bigger tires. Otherwise your weight transfer w/relocated perches won't be a good (shorter/stiffer springs) and ride will suffer. Am I wrong here guys?
  22. I believe that K&N type filters are great for non-wire mass air sensors. Alot of talk about the oil mucking up the hot-wire systems. 'Course - this isn't a problem on our z's - the restrictive AFM is (vane/flapper type). I have a K&N on my '83 ZXT. brad
  23. From what some of the transmission vendors are saying, durability is a wash between the two once upgrades are made. w/o upgrades the R700 has a bit more.... At least that's what I've read. If you're really gonna bang it, put in a 4L80E - TH400/w Electronic overdrive! ('course, you'll need the computer for it...) Hope this helps, Brad
  24. Unless you have som bad problems w/your valvetrain, your dieseling problem is probably ignition related - not fuel related. Make sure your timing is set correctly, then check your entire ignition and secondary ignition circuitry. The person who rebuilt your carb obviously doesn't have a clue if he hasn't already mentioned these possibilities to you. From your previous post in getting the car home, I think we can pretty much rule out valvetrain problems, if once running it runs fine... Hope this helps... Brad
