woldson
Everything posted by woldson
  1. I've filled an engine once, started it, let it run just a bit. No oil pressure. Investigation reveiled............. FORGOT to put in oil plug!! BTW I was 14 or 16. It happens. I will keep my fingers crossed for no damage.
  2. woldson
    E85
    Chevy can do both. Build something similar. If you have tank, lines and gaskets that can support it, it will be easier to adapt to fuel costs differences.
  3. Curious: How could of this occurred? ESP if the baring had little ware?
  4. woldson
    E85
    Just as a fyi, e85 here is 40ct. more expensive then reg. (At least right now)
  5. On initial guess, just replace that injector. You can also check it with an ohm meter. Replace it anyhow.
  6. U-joint axels or cv? That car has cv conversion if memorie severs.
  7. Next, get a fuel pressure gage and install it. Might as well get a new fuel filter as well. If problem still presists, start checking and cleaning ALL connectors. (including grounds)
  8. woldson
    E85
    Been discussed. Search some. Highly corrosive stuff.
  9. Along time ago my uncle and I got into a tiff on oil. The main thing I pull from that was why I run syn today, the temp at which the oil bakes at and its tearing properties. So much better than conventional it should scare you to run conventionals. This means you don't have to run such heavy weights and get far better engine response. At one time someone told me that the heavy weights due cause some ware and tare due to extra work the engine is doing in order to more that thick of liquid. You should not use typical syn while breaking in your engine, why, greatly reduced ware and tare.
  10. Oh, and his Z's are kept as mint as possible, I've never even seen any rust on his cars, even in problem areas................If only he liked me more, then they would be mine.... LOL!!!
  11. Do a full tune-up. Esp. plugs wires and cap and rotor.
  12. If it as good as it looks, that seems like a great buy! Thanks for shareing!
  13. Sorry, it would still be great to meet you:icon45:
  14. Dose not Brapp do this kind of work?? It would be cool just to meet him.
  15. Ummmm, if you can't turn it over how come you think it is the dis? Rethink your question in order to give clearity.
  16. This though will require you to run appropriate gage wire. You also have to isolate neutral and ground in the sub panel and run four wires off the main box. 2hot 1 neutral 1 ground. All grounds go to the ground bus and neutrals to the neutral bus. Neutrals and hots have to be marked at bot boxes. I still recremmend calling an electriction!
  17. Your dating, most girls think that time spent in "her" is deserved, yet time spent on you is a gift. If this is the case, find someone else. You can't have "balance" in that scenario, after marriage it is all her and to top it off, she will become board with the looser she has made you. Girls today think they need to dominate over men or they are a looser themselves........ so wrong. In the general sense of nature they desire to be looked after and protected, some how this got screwed up. DON"T have sex, or as little as possible. Even if girls say they are not using it to satisfy there obligation to you, 90% of the time they are. So not having sex will clear your mind to how much balance REALLY is going on. Since your dating, outside of sex, what dose she do for you?
  18. KTM covered my post, should of refreshed. Thanks KTM. Hell? I won't lie, sometimes. Woman have no idea how much power they have. Only the happy men live with those extrodanary women..........not selfish little grils.
  19. What she dose not get, when you have children, she will be wanting you to stay home and work on the car then go off for a drink with friends just to get away........
  20. Now that is geat thinking!! Ye all not leveing here till the cops come!!!!! Citizen arrest!!
  21. I will have to disagree with this, why? What would they do tear gas the crowd, rubber bullets? Come on if you want to stay free act responsible. If I had been around that poor woman, I would have shielded her with my own body,,,,,,,,,,,,, sad,,,very very sad... Makes me want to kick tards in the nards.
  22. Dude, you are asking for trouble here. Honestly, power is something we use constantly so it become mundane in a sense. It is VERY dangerous! Putting in appropriate breakers, WIRE GA. and placement of said wire and receptacle is very important. I would venture to say that 90% of all electrical fires are from over loading of circuits. Breakers just don't blow at said amp ratings. Plus not all breakers are created equal. Most apts are built with bargain bin components that minimally meet code. If this was your own house and you were single it would be one thing, you risk others and that is a whole nother situation. I would rather do a cheap break job on my car and tap my breaking system that would cause potential overload, than, do a 100mph on a busy freeway. With no insurance! (A mod like that leaves you wide open for a law suit!) Be like getting married 20 times having 20 kids with each gal and being your own lawyer in each divorce! Probably cost about the same.
  23. Mabey this weekend we can stop by steves garage, (wrenchrat), and get them out? Also are you planning on useing the ebreak option?
