9
Everything posted by Michael
Ford Super 8.8 irs swap thread. Rear brakes too
Michael replied to Invincibleextremes's topic in Drivetrain
Any thoughts on doing something like this, with a classical Ford 9"?- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Question about gear ratios for the 8.8 rear... earlier in this thread, one of the posters mentioned a Top Loader transmission. That has 1:1 highest gear, correct? Meanwhile, I run a Doug Nash 5-speed... also 1:1 5th gear... but a pretty deep 1st gear. To match such transmissions, the preferred rear-end ratio would therefore be numerically small... 2.73, or even lower. But the numerically lowest ratio that we saw in this thread, mentioned for the 8.8", is 3.15. That's still too high. Is anything lower available?- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Resurrecting this thread, for the following reasons and inquiries: 1. Did the original poster, now a "guest", make any progress? 2. Did Jmortensen, five years after 5 years after 5 years, reach his goals? 3. 10 years after my own posting in this thread, did I make any progress (answer: not yet, but "finally" I'm getting serious). 4. Why is the newest thread in this subforum, 5 years old? Aren't there any Datsun-related motorsports events worth mentioning? Or is this the wrong environment for such discussions?
Just saw this thread. The original poster's wheels are 14x6, correct? Here is a photo of 14x7 "Western Turbine" wheels. They fit a stock -suspension 280Z, with about 3/4" gap between the outermost portion of the spring perch, and the innermost extent of the wheel lip or rubber. For the eagle-eyed, these are Pete Paraska's wheels, from >20 years ago... and yes, the "original" tires. My plan is to replace the tires with Toyo Proxes R888, 225/50R14. These look to be the last "meaty" tires available in 14" diameter, which are even remotely suitable for the occasional sparing jaunt down the street.
Yes, I remember that Rota buy; it was quite the extravaganza. But weren't those wheels a bit on the... heavy side? That at least was my sentiment at the time. So I searched for alternatives... Konig, CCW, Enkei, XXR, and a dozen others. None had the magic combination of backspacing (or offset), bolt circle diameter, hub diameter and width. Weld wheels shows an example for a 280Z, here: https://www.weldwheels.com/gallery/fire-orange-1972-datsun-240z-weld-s77-forged-wheels/ . But if we look closely, we see 5 lugs. Perhaps, at $800/wheel, they'd be willing to drill for 4 lugs? As for the 16x9, the usual questions: 1. Do you have coilovers? 2. If you affix flares, would you also cut/weld the fender?
Primaz, you're quite right about the relative abundance of 16" tire choices, over 15". This seems to be becoming even more of an issue with each successive passing year. Recently I sold some parts to a fellow who appeared in a Honda minivan... the usual trappings of family-life in the back...strollers, toys, grocery bags filled with various stuff. But the minivan was sporting 19" wheels, with 245-50 tires! They actually looked like Panasports... only giant-ones. Thus about tires. But what of wheels? Spending some idle hours in the wilds of the internet, looking at wheels in 16x8, 0 offset, 4x114.4, with 73.1 hubs, I found... precious little. Spdrcr's choice (see for example here: https://jr-wheels.com/category/jr19, or here: https://basewheels.com/62877-jr-wheels-jr19-wheels-flat-black-16-inch-8j-et0-4x100-114-3) was a rarity, hitting all of the requirements. As for JR-brand wheel-weight, this pdf: https://uploads.tapatalk-cdn.com/files-2208/1528618050_JR20weights202B20lip20sizes.pdf is a nice compendium, but is missing info specifically on the JR19-model. The JR11 model is similar, from which we can guess a weight of 7.8 kg, or 17.2 lb... not light, but not heinous either. Then again, Tire Rack lists a BF Goodrich G-Force Comp-2 tire in 245/50ZR16, as 27 pounds. So for a wheel-tire combo, some 60% of the weight (or more) is the tire. Perhaps it's dumb (beyond a certain point) to cluck and fuss over the weight of the wheel? Edit: 245/45-16 tires look to be a solid 5 lb lighter than 245/50-16!
Bumping this thread, first to inquire as to whether the original poster has made a purchase and has results to report, and second to note that the link that I posted in March, now seems to be dead. That is, 15" tire choices have dwindled even further. The largest (widest) for my purposes, that is currently available, seems to be this one: https://www.tirerack.com/tires/tires.jsp?gclid=CjwKCAjwmeiIBhA6EiwA-uaeFZorYZPfqBgMhIOxDF64xOmrK1xyQKiFDPcbf6Bu1BaWu53B4_p7zRoCt94QAvD_BwE&tireMake=Toyo&tireModel=Proxes+R888R&partnum=35WR5R888R&GCID=C13674x012-tire&KEYWORD=tires.jsp_Toyo_Proxes+R888R_Tire&code=yes&ef_id=CjwKCAjwmeiIBhA6EiwA-uaeFZorYZPfqBgMhIOxDF64xOmrK1xyQKiFDPcbf6Bu1BaWu53B4_p7zRoCt94QAvD_BwE:G:s&s_kwcid=AL!3756!3!72322456933!!!g!99873502813!&gclsrc=aw.ds . These are 235/50 R15 Toyo Proxes.
Toyota front brake upgrade - still relevant?
Michael replied to fusion's topic in Brakes, Wheels, Suspension and Chassis
According to this site: https://www.wheeltech360.com/ROTA-Wheel-Kyusha-15x8-4x11430mm-73mm-Hub_p_136.html , the Rota Kyusha 15x8 in 4x114.3 weigh 16.6 pounds. Not outrageous, but a bit on the heavy-side. A search for 15x8 wheels in suitable offset (+0; or was that -0? I'm so confused!!!) shows that many weigh around 16 pounds. Some months (years?) ago, I had a thread on Vors wheels (https://forums.hybridz.org/topic/132345-vors-wheels-specifically-tr3-opinions/), which were 2-3 pounds lighter. Next question is tires. As expected, choices in 15" are... limited. There's an OK selection in 225/50-15, but anything wider gets rare. Not having overdrive on my 5-speed, I'd really prefer a taller (and wider? maybe) tire. Options dwindle... it's not 1994 anymore. Darn. Options greatly increase if we go to 16" wheel diameter. But unfortunately tire weight (not to mention wheel weight) jumps... typical 225/50-15 tires goes from ~23 lb each, to ~29 lb. But perhaps I'm obsessing over the wrong thing? -
While of course I can't speak for Fusion (or others), the rationale behind 5-lugs is that it allows for use of the standard drag-racing wheel choices, especially in 15" diameter. If easier/cheaper alternatives are forthcoming, then of course it would be silly to insist on an upgrade merely for upgrade's sake! But in my experience - broad, but shallow and unsophisticated - to find decently light/strong wheels in 15x8 in 4x114.3 has been problematic, to put it mildly. Noll - your photos are intriguing indeed. What wheels to you use, and where did you find them? What size are they, and how much do they weigh? Not to hijack Fusion's thread, but my vantage point is that of a car that's been sitting for decades. The tires and probably the brake-pads/shoes date from the Reagan administration. Now, attempting a return to serviceability, would be less daunting, if the task could be done incrementally. Fusion's question about old-school brake solutions tickled an itch. -
The big challenge is not in making one or another individual choice, of this brake-kit or that, but in having the entire combination work as a system... brakes, wheel/tires, suspension and drivetrain. Larger brake rotors mean larger wheels, which often means conversion to 5-lug and/or the coilover mod to accept larger backspacing. 5-lugs means, in the rear, new stub axles, and that likely leads to new half-shafts and so on. The project snowballs. There is no obvious way to change one set of components, leaving the rest alone, without glaringly deleterious effects, like the rear brakes locking up first. Meanwhile, these various "upgrades" aren't necessarily useful for the street, but they are heavier, and thus sap acceleration. Should we just stay with stock components? Maybe, but how to find suitable tires for original rims? And what of brake components that are leaky, rusted, frozen? Is it really all that sensible to do a complete shop-manual-spec restoration, on 50 year old components? There doesn't seem to be a good solution. Thus the dilemma! -
Remove the valve covers and inspect the rockers and pushrods. The latest malady sounds like what happens with a "wiped" flat tappet cam and bent pushrods. Also manually turn the crank-bolt and check that the valves are opening correctly (that whole 18436572 firing-order thing). Re-do the "quarter turn trick" if it's a hydraulic cam, and re-set the lash if it's a mechanical cam. It's conceivable that the distributor was installed 180 degrees backwards, so to speak. That is, spark hits the #1 piston as it's coming up on the... exhaust stroke, instead of the intake stroke.
240z Electrical. NO 12v at ignition Switch
Michael replied to Dondo_Z's topic in Gen I & II Chevy V8 Tech Board
Turn everything off, put transmission in neutral and spin the crank (via crank pulley bolt) with the appropriate socket wrench (7/8", if memory serves) and either a breaker-bar or a section of pipe engaged with the wrench handle. Spin the crank for a full revolution. It is possible that the crank is seized, whence the starter can't muster enough torque to break the seizing. If the crank is indeed seized, that's problem #1. If it spins OK by hand, then we'll return to the starter problem. A vigorous person should have no difficulty turning the crank with the spark plugs installed and normal compression. But if you're struggling, or in doubt, remove the spark plugs (all 8). With plugs removed, a small block crank should spin with no more than around 25 ft-lb of torque. Check with a torque-wrench. If the torque is higher than that, there may be a problem. It may also be worthwhile to try to "start" the engine with the plugs still removed. Just don't spin it for too many revolutions, as that soaks the cylinders with raw fuel. -
Welcome! Several of us are in the LA area. Perhaps we should have an in-person meet, 'rona-permitting? If you car doesn't presently run, and you're unsure of re-start procedures, it may help to post in the "general troubleshooting" sub-forum. The usual culprits are of course fuel-air-spark, assuming that the valvetrain and so forth are healthy, and that the compression is OK. 4L80 is an unusual choice, to go behind a small-block. Was the original intended for drag racing?
Plates around bell-housing - racing application
Michael replied to AydinZ71's topic in S30 Series - 240z, 260z, 280z
To affix aluminum plates to the transmission tunnel, as a completely new feat for me. Isn't the more common approach a "blowproof" bellhousing? Something like this: https://www.holley.com/brands/lakewood/products/drivetrain/bellhousings/ . These are unfortunately very heavy (maybe 40 lbs), but aren't they required by the NHRA? -
Welcome back! Yes, it's been a long and choppy 21+ years. Perhaps we ought to have an "old member" section, for reminiscences and such? I will bring my hot-water bottle and wool blanket. An important lesson is regarding having the right environment. Insufficient garage space, or too rigid of a state regulatory burden, all conspire to sap motivation. Or in some parts of the country, where land is plentiful and regulations are forgiving, the climate is brutal, and for half of the year it's unpleasant to drive a sports car, or even to be in the garage. The result? We have to await the age of permanent relocation, to a more commodious place... hence, resume the hobby in retirement. Congratulations!
Moving front wheels outboard
Have a look at the "suspension" chapter of the venerable JTR V8 conversion manual, where there's a discussion on re-drilling the K-member to move the LCA outboard (and slightly upward). There's also been discussion suggesting (sorry, the context escapes me) the benefits of a "slightly" wider track in the front than in the rear. As to the 5x114.3 vs. 4x114.3 dilemma, both aesthetics and wheel selection-options suggest the benefits of swapping to 5-lug in the front, if that's already been done in the rear. Given the cost of the Ray's wheels, the additional cost of new 5-lug hubs (around $500?) is not outlandish. 275's on an 8" wheel... is that advisable? -
Having spent 20+ years trying to do it myself, I realized that my skills are woefully inadequate. I've also garnered a respect for professional workmanship, even if it's costly. The frustration is that most pros are into the show-circuit... $20K paint jobs and that sort of thing. I've also learned to never argue with a seasoned pro... that's one context in which it is assuredly not the case, that "The customer is always right". But you're quite right about the importance of patience. Today Datsuns are expensive. In another 20 years, the generation that idolized them in their youth, will likely exit the car-acquisition phase, and prices will fall. One perhaps counterintuitive observation is that displacement and engine weight don't strongly correlate. A pushrod-valvetrain V-block is remarkably compact and light, for the displacement. An example is the Ford "Modular" (more recently, "Coyote") V8... overhead cam, vs. the venerable 5.0 pushrod engine. Compare weights and exterior dimensions, for the same displacement... uncanny! Engine designers might brag about wringing the most hp from the least displacement, but from a vehicle design viewpoint, what matters is the overall engine weight, the external dimensions, and torque curve and the fuel efficiency. These can be surprising. One data point is my 1991 Miata (engine swapped from a 1996 Miata). It's a 1.8L 4 cylinder, DOHC... makes all of 110 hp, weighs >300 lbs, and is lucky to get 25 mpg (in a 2200 lb car). Overall it's a great car, but nowise because of the engine. The engine power to weight ratio is horrible... on par with 1970s emissions-strangled GM and Ford land-yachts. Anyway, without rambling ceaselessly, this: it's good to be on the lookout for cleverly-built, one-off gems... the weird cars, the complete tube-chassis ground-up customs. That, and not a faithful restomod, is my ultimate objective.
Not to range too far of topic, but that's a 150-pound block. I chose those attributes intentionally, to result in surprisingly light engine. It's the sort of thing that powers the winners of the Hot Rod Drag Week contests... things like 1962 Novas that weigh 2100 pounds. But the big-block people or the Nova people won't countenance one of that them thar Datsuns... and vice versa. Just like it was, 21 years ago, when this site first started. The point is, that great things are possible by dispensing with OEM stuff and replacing it with high-end, specialized parts, tested and installed and tuned by expert craftsmen. As goes without saying, this is expensive... deep 6 figures-expensive. The irony is that if the sort of Datsun that I described were today for sale for $70K, I'd immediately whip out my... checkbook. But we don't really see such animals for sale anymore.
Not to be provocative, but I wonder how much of the price-escalation is from a cultural affinity to "keeping it Japanese" or "all Nissan"? In other words, if the engine were a Donovan aluminum big-block 572, with AFR heads and a big mechanical roller cam, backed by a T-56 transmission and a Ford 9" center-section (duly converted to independent half-shafts), then might we find ourselves with a car that cost $100K to build, but only fetches $40K at auction?
Vors wheels (specifically TR3): opinions?
Michael replied to Michael's topic in Brakes, Wheels, Suspension and Chassis
Plausible and intriguing, but would the bending stresses (cantilevered load) be acceptable? Miata 15x8 wheels are typically around 36mm offset, whereas a Z, if I'm not mistaken, would be 0 offset (4.5" backspacing on an 8" wheel... that is, 9" lip-to-lip, is 0 offset). So that's a 36mm-thick cylindrical slab of aluminum, drilled 4x114.3 and counterbored to accept lug nuts and the head of a socket-wrench (what is it, 21 mm?) ... and then drilled and studded at 4x100, to accept the Miata wheel. 1" adaptors: https://usadapters.com/collections/4x114-3-4x4-5-wheel-adapters-wheel-spacers-4-lug-hub/products/4x4-5-4x114-3-to-4x100-usa-wheel-adapters-12x1-5-studs-1-71mm-bore-x4-spacers . But 36mm = 1.417", so perhaps we'd need 1.5" adaptors? Interestingly, the same company ("USA Adapters"; correct spelling would be "Adaptors", but hopefully they're better engineers than English majors) makes 4-to-5 lug adaptors. Is this a possibility worth considering? -
If you've done the 5-lug conversion, the world is your proverbial oyster (at least as regards wheels). There appear to be lots of OZ wheels in 5x114.3. It's us poor 4-lug schlubs who lack options. Were I to have done the 5-lug conversion, I'd just order some Weld Draglites (https://www.weldwheels.com/street-strip-wheels/draglite.html) in a custom offset. Problem solved. Maybe this is classic paralysis-by-analysis, but here's the problem: 1. Car has been sitting for decades, and tires are completely unsafe, even for pulling out of the driveway. 2. Choice of new tires that fit, is somewhere between woefully bad and completely zero. 3. "Good" new tires would require new wheels. 4. "Good" new wheels, to have a proper selection, probably require the 5-lug conversion. 5. Ergo, just to get this [expletive] thing back on the road - I mean, just to do a vanity-lap around the block - entails a massive customization and re-engineering project, which I have neither the patience nor the resources nor the motivation to do. -
There is of course the adage of getting that for which one pays. I don't expect forged wheels for cast-wheel prices. The quandary however is that even among comparably built and comparably designed wheels, there's wide range in weight and price. One would like to get "the best" within a certain class of product, realizing that "best" will differ between the different classes... or applications. Another example is Konig wheels. Several appeal to me, in price, design and even weight. But good luck getting a 4x114.3 pattern with the right offset for a Z. Another example is 6UL (https://www.counterspacegarage.com/949racing-6ul-15x8-4x100), with which I'm familiar from the Miata side (my daily driver is a Miata). Great wheel, good price, well-deserved good reputation! But by design, it's only available in the Miata 4x100 bolt pattern; there's simply no "meat" in the hub-area to accommodate redrilling for the larger bolt pattern. -
This is precisely why a crowd-sourcing approach of gathering data - even anecdotal data - is so important. Until brands build a reliable track-record, we can only rely on word-of-mouth. By way of example, I bought a "Central Machinery" drill press from Harbor Freight Tools, about 20 years ago. It still works great! Best $150 that I ever spent on a tool. But the purchase was blind... no knowledge, not even anecdotal data. I dislike Rota for two reasons. First, they're heavily advertised, which to me suggests more sizzle than steak. Second, they tend to be heavy. Vors caught my attention because for the same size wheel (15"x8") and essentially the same design, their advertised weight was 2-3 pounds lighter than Rota. But without a track-record, can one tell, if this advertised weight is correct? I wonder how much of the price of something like TE-37 is for exclusivity, branding and so on... a Hermes scarf, a Louis Vuitton suitcase and so on. I am looking for low weight and OK (not necessarily outstanding) durability, at an acceptable price. I just need to get my car back on the road. Not the track, just the road! My current tires were already old when the 21st century started, and finding tires that fit the wheels (14x7) seems like a dead-end. For 14x7 BTW, the only "acceptable" tire that I could find is this one: https://www.tirerack.com/tires/tires.jsp?tireMake=Toyo&tireModel=Proxes+R888&partnum=25VR4R888&vehicleSearch=false&fromCompare1=yes . And while this is great from a traction and tire-weight point of view, it's an awful short tire, resulting in some pretty frenetic rpms at highway speeds (5 speed transmission without overdrive). -
all big block z owners please report to the dance floor.
Michael replied to fl327's topic in Gen I & II Chevy V8 Tech Board
It occurred to me, that after thirteen and a half years, a reply might be judicious. Or at least amusing.... The vendor is/was called "Cam Motion", from their "low lash mechanical roller" line. A modern internet search reveals this: https://cammotion.com/low-lash-solid-roller ... but that's for LS-series engines, and not for Mark-IV big blocks. I can't find anything about big-blocks on their current web site. Back in the day (winter of 2006-2007), the part number was L2402-2501-12+4. That's 239/249 deg @0.050”. Lift is 0.642”/0.646”, 112 LSA, installed +4 deg. Springs are Comp Cams PN # 933: 185@ 1.920" (valves closed) and 490-500 over the nose. Valve float was, if memory serves, nonexistent. The real rpm limit was piston speed, or in other words the structural integrity of the rods and rod-bolts.... 3/8" ARP bolts, but stock (resized) GM rods. In hindsight I ought to have redone the bottom end... maybe even gone with a stroker crank and 6.385" rods -
Any updates on this? Those Jongbloeds are beautiful wheels, but what of cost, weight - and most importantly. fitment? A quick search reveals that just over the past year, we've had multiple threads on "Help, all of the Datsun wheel links are now 10+ years old, and there's no comprehensive spreadsheet anyway". Then there's the inevitable question of stock springs (cut or otherwise... assumption is that the spring perch is NOT relocated) vs. coilovers. The result is inevitably... inconclusive.
- 5 replies
- light weight wheels
- 3 piece adjustable
(and 1 more)
Tagged with:
