Domzs
    5
Everything posted by Domzs
  1. Sorry , think you are crazy if you are thinking of doing such swap . I wouldn't consider do any european motors in any cars . Think they all junks . Have been working on cars , in an auto shop , for over 20 yrs .
  2. Looks like you are going to have a lot of fun . Lol . Which V8 are thinking ?
  3. That's an injector cooling fan . Heard my came on once , was 100 plus ambient temp.
  4. If that box fried , it probably did some damage to the harness . The fan you spoke of , injector cooling fan ?
  5. Are these what you are looking for ?
  6. I've seen it before . Just not sure if they are RKR . Thanks .
  7. That's poss. . With the way it acts i'd hook a gauge to check fuel press. while driving . My ZX pump has a screen on the inlet side . Check to see if it's clogged .
  8. I have Rota RB and RBR on my 83 . Tried RB 17x7.5 +4 on it . Seemed ok , just no sure about 17x8.5 +10 RKR . Thanks
  9. I looked at an 83 , didn't see any relay . You have to put one in if you want , it's better to have one . Less load on the switch . I added a Ford starter solenoid to my 83 when i did the LS1 swap . Good luck .
  10. Check wiring diag. . Look at park/neutral safety switch . Jump input signal from ign. switch to output signal at safety switch . I think it would be better if you run a new wire from ign. switch to the start . This sys. involves inhibitor relay . Preffered adding a starter relay , this will make ign. switch lasts longer .
  11. On most cars , they locate at trans. or shifter . You have to look it up . But make sure you have signal at the switch .
  12. Looks and sounds good . Great job !!!
  13. Fender problem ? It sticks out a lot . Lol .
  14. Y'all telling me , there's no one out there running this setup ?
  15. Auto has park/neutral safety switch ( preventing starting in gear ) . I'd say yes . But do you have start signal at switch ?
  16. Remove ign. switch from lock cylinder and turn it with a screw driver to see if you get any power to starter signal . Poss. the lock cylinder is bad and it's not turning far enough to engage starter position . Good luck .
  17. I'm thinking about getting new wheels for my 78 Z . Just wondered if anyone's running Rota RKR 17x8.5 +10 ( Ad on Ebay by Wheelbay ) . Do they require spacers ? If so , what size ? Pictures would be nice . Thanks .
  18. I'm glad . Good luck . PS don't forget the fuel filter and flushing the fuel lines .
