makaofox
Everything posted by makaofox
Well now that work is over and the semester is also over, I can get back to working on the z some more. Havent done much with the z, started the car up yesterday and has a lumpy idle. At times it jumps 300-500 rpm for a sec then dies down. With a faulty tach not sure how low it dips. Im sure once I drive it on a daily basis it will iron out. But I ordered new NGK spark plug wires, and that should come in on the 27th. Going to order cap and rotor as well, just to be safe. Had some spare time and I was sick and tired of hitting my head on the roll cage. So I cut it out and just left the rear hoop. Eventually im thinking about adding a 1 3/4in piping for the upper roof but angle it at a height that wont bonk my head and possibly run the rest of the cage through the dash. Also had some difficulty with a front sway bar that came with the car. Since it came with the car and not on the car, I have no clue if its even for the z. So I purchased a Summit racing sway bar for $194 and should get that on the 27th as well. Im probably going to scrap the old sway bar since its aluminum, but wasted $20 on 28mm bushings :/ So cut it all out and shed some SERIOUS weight. And then proceeded to unbolt the rest of the cage to grind it down and repaint it. All Done and reinstalled. SO much more room. Confusing sway bar Looks more of a rear than a front, so ive been told. Browsing around and a possible idea for a diff mount to prevent clunking. Since ill have extra sway bar endlink bushings, im definitely going to try this mod. And me clowing around I want to have a beanie that says this. I already have a place that might be able to do it, just waiting on a price. Guess after the holidays. Datsun Sun: "Oh stop it you" Just something to look it from november ^ Notice it says my name I always get a kick out of it lol. ^ Fixed the exhaust also, it has MUCH better fitment now. Thats all for now until I get my parts in next week where ill have new pics of the exhaust and spoiler. Also forgot to mention my locks all work now! Went to a locksmith and he was an awesome dude! Took out my hatch lock, gave it to him $26 and boom done. But had a difficulty that the door locks have an extra tumbler. No biggie, 5min with the door locks and boom he did it again. Now I have proper working locks, and windows that roll up with my pinky :thumbsup:
Hey christine its mario . Just posting that I am on here and various other forums lol. Again great build, keep it up
^ Agree, also check for an exhaust leak. Check the vacuum hoses, intake and exhaust manifold. If those gaskets are shot, it will give you issues, if you have a tear in you afm boot it will cause issues. But backfire from intake is a timing issue. Make sure you're properly timed, good gas, good plugs and wires, and no air leaks. A good way to check for leaks is using starter fluid, if it jumps in rpm then you have a leak, if nothing happens then your fine in that aspect.
Becasue I like the z32 trans lol. Honestly its not a hassle finding one and its one that im firmiliar with. The R154 is great but around our area they come with a steep price and as you stated shifts badly. But for a z32 trans you can find a good one for $200 and those rebuild kits arent expensive either and throw on a z1 short shifter and you have an amazing combo. The adaptor plate is great because it has the holes for the z32, z33 and even the new z34 trans, which is great for anyone really. Having owned a TT and an NA they are pretty beefy trans that can handle 500hp like its nothing. My goals are modest so a z32 trans is more than enough for me and in the end the cost will either balance out or be much cheaper. If I was able to get a trans from the 05+ z33 at a reasonable price that could be an option. But for the moment its not.
If it doesnt work by replacing both flasher units and cleaning the hazard switch in the center console with eletrical cleaner. Then you have to check if you're even getting power through the system.
It was alot lol. I tried putting all the info I could gather in a thread. Starting with my own info and some from clubna-t. Generally to my knowledge 1bar is like 15psi? right? Thats not important though, what is important is the map sensor lol. NiceI want to go 1jz with a 5sp z32 trans. I used to own a z32TT so that technically was my first turbo project but with the s30 I want to go all out and learn all I possibly can.
Try replacing the flasher unit and the blinker unit. Sounds like you replaced the one just replace the other since your there. I had the opposite. Flashers worked but blinkers didnt. Took my turn signal unit to get refurbished and still nothing. Then took some electrical cleaner from advanced auto to the hazard switch on the center console. Spray the CRAP out of it literally, I had built up gunk in mine. Then it worked perfectly.
Well doing some searching on numerous threads here and on supra forums about a jz series swap into my 76 280z. Just finished refreshing the L28 motor and I want to drive that a bit before going onto a 1jz or 2jz swap. But I want to gather further info on the swap and start collecting parts. Im currently helping a friend build his 2jz 240z, but I also want to put more info on the swap out there. So far I have a basic list and a detailed understanding of na to t. I just want to know which is better suited your my needs (or yours). Im looking at 450whp and an na to t looks cheaper than the 2jz but looks about the same as a 1jz? Buying a single turbo na to t is amazingly cheap but the ge you are dealing with the dizzy and that could be an issue. Ive seen it fit under the z hood just fine though, in the few recent threads. Any clarification on which is better choice for a given reason please feel free to comment. Any way here is what I have so far, please feel free to correct me, elaborate more on a topic and generally add to it (such as which brand you used and the like). I want to be able to save and and read it and start processing my ideas. 1jz/2jz Datsun 240z/280z Swap Specs from a few builds: 1: Engine Specs will be as follows: Eric Noss 3zc USDM 2jz-gte Turbonetics T4 76mm SDS Stand Alone Engine Management W58 Transmission (until it breaks) Aeromotive Stealth A100 Fuel Cell HKS SSQV Tial 44mm MSV Wastegate Greddy Intake manifold with Q45 tb (wont fit) GREX Oil Cooler HKS SSQV Bov Unorthodox Underdrive Pullies Titan Motorsports Fuel Rail Siemens 850cc injectors Aeromotive Regulator -10 Feed, -8 return Fluidyne Radiator Dual FAL fans Gigantic Greddy Fmic (doubt it will fit) 3" IC piping Titan Motorsports Engine Mounts Clutch Masters Twin Disc Clutch 3 or 3.5 Exhaust with Apex-i Race Muffler Intake manifold w/ 90mm billet TB Chasebays.com wiring harness Luis z32 2jz engine specs: Drivetrain: ATB lsd Quaife, Driveshaftshop aluminum driveshaft, Getrag 6speed. Exceedy carbon carbon clutch 3.4L motor, BC internals. custom intake manifold. Accufab throttle body, 1050cc injectors. twin bosche 044 fuel pumps, Garret GT42R. 4" exhaust that splits to dual 3" to freeflow resinators and dual Apex Nur Spec exhaust. Greddy exhaust Manifold and greddy open wastegate. Kevlar timing belt. Titan cam gears, titan fuel rail, arp head studs, arp main studs hks head gasket, custom powersteering resivoir, 3" stainless IC pipes. Custom FMIC, custom radiator, wire harness tuck, Engine Management: Aem ems, Aem injector driver box, HKS dual spark ignition Things needed for swap (General list): -1jz-gte motor from a soarer, chaser, mk3 supra rear sump (91-95 vvti 96+). -2jz-ge motor from a soarer, chaser, aristo, mk4 supra and altezza rear sump (91-96 vvti 97+) -2jz-gte motor from a aristo and supra mk4 rear sump (91-97 vvti 98+) -Custom adaptor plate from SWAP1UZ.com or on ebay (snomagt1) for z32,z33,z34 trans -Pair of Jaguar XJS V12 engine mounts or hockey pucks -Custom cross member, beta-motorsports -Cut trans mount ears, possible custom trans mount -23.5"x11.75"x4†Universal Intercooler Core from ebay to fabricate FMIC -Turbo: Garret GTX 3071-R, 3076-R or Borg Warner EFR 6258, 6758, or 7064 -Chasebays wiring harness -3in stainless steel IC piping -Custom intake manifold or ebay greddy replica -Throttle body ebay something less than 90mm greater than 65mm -Fuel rail with atleast 440cc injector’s ebay aiming for 800cc -Exhaust manifold eBay; make sure to have proper flange ie T25, T3, T4, twin scroll -Arp head studs, main studs, exhaust studs etc -Waste gate at least 38 or 44mm - twin bosche 044 fuel pumps no intank pumps for s30 or 255 walbro GSL392 fuel pump -Engine management either AEM EMS or Haltech etc -Headgasket (stock or 2.5mm) and gasket refresh kit for entire motor -HKS F-CON is piggy back for stock ecu fuel and ignition management -10an Feed and -6 or -8an return fuel line -3in downpipe and 3in exhaust -50mm bov -For 2jz-ge na to t use 92+ V6 4Runner dizzy cap and rotor PN19101-65040 clears T-61 turbo -HKS 272 cams and cam gears -300zx 90-96 na or tt trans, 350z 03-08 or 370z 09-2013 -jz clutch, flywheel, throwout bearing ect -Custom driveshaft -New water pump, oil pump -fuel pressure regulator -6-rib 990mm belt of a d17 honda civic for a 1jz with no PS or AC -upgraded map sensor General info about non-turbo to turbo setup Copied from Clubna-t: Hopefully, by being on this website, you understand the basics of the 2jz series of engines. In the United States, Toyota released "technically" 2 versions of the 2jz motor, the GTE and the GE.... both come standard with DOHC, 24valves, EFI, etc... what else can you expect from Toyota? The basic differences between the GE and GTE (not comparing either VVTI editions): -Most obvious difference to anyone familiar with engines is the TURBOS. The GE has none, that’s what the 'T' in GTE means. -Another is the style of intake manifold, the GE has a manifold developed for more torque development in the lower-part of the rpm band vs the GTE's short runner type. The GE doesn’t have more torque; it’s just that it develops more than it would if it had a GTE-style intake manifold. Hope you knew that. -Compression, the GE runs a 10:1 compression ratio and the GTE runs an 8.5:1 compression ratio. The differences are obtained through a thicker headgasket (.2mm for GE vs 1.6mm for GTE) and lower compression pistons on the GTE. The higher compression allows the GE motor to make the most of its power since it lacks turbos to begin with. -Injectors and Airflow sensors, the GE runs 330cc top-feed high impedance Denso-style injectors and uses a Karman Vortex air-metering sensor to read how much air volume is being ingested. The GTE runs 540cc side-feed low impedance injectors (though uses a resistor pack to raise the impedance for the ECU's sake)... measured through a hotwire MAF sensor. The GE's airflow restriction is around 450hp from the stock AFM and the GTE is around 650-700hp depending on several factors. -The heads are slightly different. Some say the GE flows better than the GTE, though no concrete numbers have come from a flowbench to prove it. The GTE motor has larger intake ports on the head whereas the GE has larger exhaust ports on the head. -The exhaust manifold and intake manifolds port spacing and studs are completely different and will not work with one another unless some machining is involved with the manifolds themselves. There are people who have successfully grafted the upper part of the GTE intake manifold onto the lower part of the GE manifold. -The GE motor runs a distributor-based ignition system with spark plug wires and a single coil. The GTE runs coil-on-plug ignition with individual coils for every plug. The distributor gets in the way sometimes of the turbo intake pipe These are just motor differences, there are many little others such as oil squirters, oil feed/return lines, transmissions, etc. Now onto Similarities: Both the GE and GTE bottom ends are VERY strong. The only difference being the pistons themselves. That’s right, the rods and crankshaft are the SAME parts! The 2jz motor itself was DESIGNED to be turbocharged from the beginning and is built VERY strongly from the factory. No one yet knows the limits of a GE setup, though there are several 1000whp setups on the GTE with the stock bottom-end. Dave H uses a GE motor and ran a 9sec 1/4 mile time with the stock GE block (a spare 220k mile motor to be specific!) All in all, it is very doubtful that you will need to build your motor when designing a NA-T setup unless you're gunning for ridiculous amounts of power. The stock cams are roughly the SAME. Designing a Turbokit for the 2JZ-GE Going the DIY -The Price is a good bit cheaper. -The installation is a bit more difficult since you're putting together parts that weren’t necessarily designed for one another and may require some fabrication -Used parts don’t last as long and a lot of times they just aren’t as good of a quality as new stuff is (new stuff is ALWAYS coming out for the GE car nowadays). Buying a Kit Is much simpler and easier to follow. You will still learn a lot about your motor if you install your kit yourself and still have the opportunity to purchase some used parts if you can find good deals, etc. Buying a kit you KNOW that it will work correctly if it’s a reputable shop such as BoostLogic, Sound Performance, PHR, Dave H, etc. You can purchase a turbo kit, fuel kit, aem kit, and be done with it and have a monster on your hands. They literally come with everything you need. Parts in a Typical Basic NA-T kit (note this is not everything you need) Turbo manifold (there are log and header types, headers flow for more power, but spool slower) Wastegate (bigger you go, the more control you have and less chances for spikes and creep) Downpipe (connects to your exhaust) Intake pipe (connects from your turbo inlet to your filter or AFM) Oil feed and drain lines (feed and drain oil to/from the turbo) Turbocharger (large varieties of these, this is what makes boost!) In the basic kit you usually run directly off the wastegate spring. Most kits keep you running on the stock compression levels (10:1 remember?) in the first "stage" or two, until you get serious about power anyways. This results in quicker spoolup and better off-boost response but you cannot run as much boost without risking serious damage to your motor. -10:1 compression limits you to around 7-8psi without fiddling with your ignition timing (stock timing has a big "spike" of advance around 4000-4500rpms that will cause detonation if running more than 8-9psi and the base timing is not retarded 3-4 degrees) -stock injectors will also limit you powerwise. I've seen several setups make OVER 400whp on the stock fuel setup (upgraded fuel pump) but its still best to upgrade them (and with a way to control them too -- SAFC, emanage, MAP ECU, AEM standalone, etc.)... generally I wouldn’t go over 350whp with the stock 330s. -intercooler options, some kits come with some don’t, most of the lower-priced ones don’t and you are left to fend for yourself in the intercooler arena... you NEED one to run more than 5 or 6psi realiably -strong turbo manifold, either a strong cast unit or a strong (IE 321 Stainless Steel) tubular header manifold... Dave H's manifold runs via Weld Els and it is VERY strong and beefy. His manifold is more of a hybrid, not really a log and not really a header. -turbocharger to suit your powerband preferences (a later discussion perhaps?). Most people go with a T04E or PTE style turbo that makes around 400whp at 10psi of boost. EDIT: Thanks for suprapunk pointing out something: If you are building your own kit: Ensure that your exhaust turbine lines up with your manifold Like make sure its a T4 hotside and a T4 flange on the manifold, and make sure you have the correct hotside outlet as well to mate to your downpipe (v-band, on-center, etc) -35mm wastegate, Tial or HKS brands are good stuff. Many kits are running 38 and 40mm gates, which is fine, they cost more. Depending on how much power you'll be making with your turbo, you need to decide what to run unless a kit-maker already picks one. -fuel and a method of controlling that fuel to supply enough for your power needs. On more basic setups I recommend the Emanage blue. Affordable and can tune your car very nicely. Most basic kits can make good power with MKIII Supra Turbo injectors. They are also top feed (but low impedance, need resistor box or inline resistors) and denso style but flow 440cc instead of 330. The Lexus V8 AFM modification is affordable and can make the 440s easily tunable with a simple fuel controller. -a FRONT MOUNT INTERCOOLER. Do it once, do it right. The sidemount jobs cannot compare with the Front mounts other than being harder to see. You can pick up good quality units off ebay for under $300 these days. -A 3 inch downpipe and 3" exhaust system! At least 3 inches all the way back if you can. Turbos need FLOW, give them a bigger exhaust and they will spool faster and give you MORE POWER. -GOOD spark plugs and good conditioned ignition system (get a new rotor and cap for your distributor pronto!). NGK 3330s and NGK 6097s are both great plugs, they are pregapped at .031 which is perfect for turbo applications under 19-20psi of boost -Oil feed/drain lines properly sized. Typical setup is -3 or -4 AN feed with a -10 (no smaller) drain line. Garret turbos require much less oil than most people think; and dumping high pressure (60psi+) oil into it and then having a small return line blows the oil seals on the turbo very quickly. You want NO flow resistance on the return line. You can do this by having a BIG return line like a -10 or use a oil-line restrictor (can pick them up at atpturbo.com). IF you buy a premade kit that comes with a oil-line kit then don't fret, its already been tested and setup with the turbo you'll be running from the kit. Keep in MIND!!! That all of this is how to get power reliably out of the MOTOR. The transmission and the rear end are completely different subjects. Your stock clutch WILL NOT withstand more than 300whp and last for very long. Your stock transmission WILL NOT WITHSTAND more than 400-450whp for very long and driven hard (your mileage may vary). Autos are very different from the stock 5-speeds. Do your research on driveline modifications! In the bigger power arena, you need to bypass several obstacles. One most notably being the stock ECU with regards to fuel metering. There are only so many bandaids you can run before you run out of airflow (even with the V8 AFM). This means by going to speed density! Speed density is a completely different way of measuring the air intake in the engine vs the mass-air system used in the stock GE. The stock GE system uses Karman Vortex as its way of measuring air. If you've ever taken apart your intake and see the sensor itself, you'll see a waffle-style (or honeycomb) front on it. What this does it cause small vortexes to form after the air enters the system. The more air that enters, the more vortexes (and the larger they get). The quantity and amplitude of these vortexes is measured by a small speaker inside the housing. You can see it if you look carefully. Do not damage the honeycomb up front, you will cause the sensor to read bad. Speed density uses two seperate sensors to measure how much air has entered the system. -The first sensor is a pressure sensor that senses how much pressure or vacuum is in the intake system. This is called the "MAP sensor" MAP is short for "manifold absolute pressure". By absolute, this means TOTAL pressure including atmospheric pressure (which is 1 BAR at sea level) by the way. If someone has a 3 bar map sensor, it means it can read 29.4psi of pressure ABOVE atmospheric (14.7psi = 1 BAR). Obviously, this is a little sensor, and causes no intake restrictions of ANY sort. -The second sensor is an air temperature sensor. When air cools, it becomes more dense, with more oxygen molecules. This sensor allows the ECU to compensate with more fuel to keep a safe mixture when the temperature rises or drops. It is called an IAT sensor - or "intake air temperature" sensor. This sensor also causes no restriction. Almost all aftermarket ECU solutions are Speed Density (also called MAP-based) and this includes the AEM ECU. It can run via AFM, but its a waste not to utilize the extra flow and control with MAP. The "MAP ECU" is a piggyback solution for the stock ECU. Like the older VPC, it translates a MAP-based signal into an AFM signal that the ECU can use (and isnt any the wiser). Both the MAP ECU and AEM allow you to run MUCH larger injectors. Ok I'm running a speed density system, I am cool! Not so fast! You need BIG fuel injectors for that too. Luckily, the stock fuel rail is a top-feed unit, has an FPR plug on it that is right around 1/4" NPT in size, and has a good enough internal diameter to flow enough fuel for over 700whp. Boost Logic, SP, Titan, etc now offer NA-T fuel systems that either use the stock rail or replace the whole thing completely. These systems are generally customizable to the size injectors you want and most use TWIN Walbro Fuel pumps. Nice eh? After that, you will already need to be running a GOOD turbo header... the cast jobs work well in the low-power arena, but with the big boys it’s all about FLOW.... and cast units DONT On the header setups, you will already be using a larger wastegate (40mm+) and at least a 3" downpipe. A lot of companies will have a 4" downpipe and midpipe combo to upgrade to if you're going to be making big power (don’t really need that unless you're hitting over 700-750hp). A FRONT MOUNT INTERCOOLER!!! A turbo that can flow the amount of air you want. Do some research, because there is a HUGE turbo selection out there and new ones are coming out all the time that offer better and faster spool, more flow and power, and more extras At this point you MUST be running a thicker headgasket. Why? Because you cannot make over 400-450whp reliably with the stock 10:1 compression. Stock SupraTTs come with 8.5:1 compression and can run lots of boost from the factory. YOU can get to this point by running a thicker headgasket. Your stock gasket is very thin... like .2mm vs the GTE gasket which is 1.6. Do not worry about squish-volume problems too much, since the primary source of compression drop on the 2jz-gte is achieved by running a much thicker headgasket. 2.5mm will get you to 8.5:1 compression. The only problem left is ignition, which can be solved by running lower gap on your plugs and an HKS DLI. It boosts the ignition signal and will allow you to still make spark at higher boost when it would normally be "blown out" from the excessive pressure. After this point, you can start tuning, running race gas and making BIG power. The stock GE intake manifold (EGR delete please!) can flow over 800-850hp and there's no point in upgrading to a high-flow unit (such as the DaveH unit) until you eclipse this point. There are lots of little things this guide didn’t have for big power, which is detailed tuning instructions (get it tuned by a professional if you don’t know what you're doing!), and small tidbits you should already know. (ie Beaded intercooler pipes, new gaskets for all hardware, etc.) Please understand that this is just a basic blow by blow of how to obtain power from this motor. If you can understand this so far, then congratulations, you can probably handle the whole deal just fine.
Love the video and DEAR LORD love the z. Pretty much my inspiration lol. Thinking of going 1jz, gunmetal grey, fender flares, fender mirrors, spoiler. Do like man keep it up, cant wait to see the numbers. My goal for the 1j is also around 400-450wheel max and I think thats pushing it lol.
I brought an ebay rad as well. Same exact issues the verticals lined up but not horizontals. I have a 3 row but I think its a different vendor, as I brought it a bit more expensive. I had to hack away at it, add 3 out of 4 new holes and it sits about 1 inch above the rad support. Luckily the hood closes no issue. I have to say I love the rad but it was alot of work to make it fit, I dont TOTALLY mind making it fit. Being hybridz its make it work mentality but for others that just want to bolt and go, this isnt a good buy. F-it I say take the $50 and change it ONCE you get paid. Honestly YOUR SHOPPING ON EBAY. You pay for what you get, your just warning someone that doesnt really care. All they see is the cheap price tag. I've done my hw and had a 50/50 chance with my rad, it could have sprung a leak by now. Somethings are ok to shop on ebay others arent. So up to you but I say go for the money and post the feedback. Maybe he will actually change the radiator to make it fit, or just sell it as pre 75.
I had no key, going to lock smith tomorrow to get a new key made. Its SO easy to remove the hatch lock buuut im afraid putting it back will not be so easy lol.
240 turn signals/bumper on 280Z
makaofox replied to DuoWing's topic in S30 Series - 240z, 260z, 280z
^ Honestly its THAT simple. Its like 8 bolts total I think not even. Its so simple, only thing is I had a xenon bumper and you have to drill the holes yourself. Thats not hard but that is the only thing. Airdam install took me 30min, only thing is it needs reinforcement or it flexes, atleast the urethane one does. -
For my 280z euro tails I paid like $300, I dont know where you get 800 from? I think you should search and post a wtb. I definetly know people would sell them for $800 but you can find really great deals if you look. Try the jp ebay or yahoo and uk ebay. There is a place that made reproduction 280z tails and they SUCK they look like garbage. They come red on white. Im sure a few have seen them, they look horrible and they are expensive for no reason. Reproducing them wont be easy or cheap. I have a euro 280z tail, if you want you can have it to do the mold for it? Its rough but atleast its not broken, just sun beaten. Its not the same a 240z but very similar. Either way making a copy isnt easy, you have to find trusting resources.
Nice I frequently am around bloomfield college, so monmouth is right there. Actually i have a number of a guy in monmouth that has a brown 280z with the rb swap in his z. Its for sale at $18k. The L24 is a fun little motor but breaking 250 is not worth it best bang for your buck wise. For that you can get an L28et and have a blast with that, 350hp is easy and cheap. The L24 is a fun motor and things like a mild cam, 45mm ITB or like a holley carb or mukini, header, 2.5in exhaust, light weight flywheel, msd ignition compents and light weight pully can net you a fun little ride. There is lots to do on an L24 without breaking the bank but will not get you anywhere near the horse power of the RB or even an SR.
Welcome! What paart of Jersey you from? As for the swap, I would go with an RB 25 just because your hp goals are some what modest and the 25 is more than capable of it. But 550wheel is ALOT for a sub 2500lbs car. If I was you I would focus on hitting the 350hp mark, THEN start working on suspension and brakes. Better yet focus on just running the z stock hp at around 280, while working on the suspension /handling and brakes. No sense in having 500hp and not being about to stop or handle well. There are a ton of threads on here about the rb swap, search a bit. Its been done a ton of times with great success. They have wiring specialties where you can buy the wiring harness from rb25 to datsun 240z. For around $350-500 depending on the extras. Thats basically the hardest part is wiring. The motor mounts are available on plenty of sites. Mckinely motorsports comes to mind, but they are half assed swaps personally, becasue you still have to tweak the motor mounts and cross member in some cases.
Wow he had some serious money! Thats an amazing transformation! Cant wait to see it at a meet or something. Great job joe
^ Cant use the bathroom unless you by something lol. Thanks ill give him a call, maybe he will have a few parts I need. Do they have a website, to browse the inventory? edit: Found the site, nice inventory.
^ Love it chaos, looks really sexy. Any more shots? I have always wanted to see rpf1's on an s30. wheel specs, tire sizes?
^ Thanks man thats great info! Yea I want to put the hoses back, but havent been able to find some of the components. I know the hose that goes from the block breather tube has a bigger diameter than to where it goes. But I will certainly try and fix that! Im sure she still has a leak or too, and the valve lashes were all kinds off out of wack. 3 of them WILL NOT BUDGE. But adjusted the rest, and the difference of just the motor sounding better was night and day.
Cage is super tight against the body. Im not a large person, so the cage is fine for me, if I was 6'2 285lbs that would be a different story. The harness is fine, if it goes any lower it could be dangerous, where it is now is safer than a few other harnesses that I have seen. But thank you.
Been having some troubleshooting issues. Got some of them worked out but still runs a bit weak. Oil pan and oil pump were leaking due to the gaskets being shot. I replaced them initially but somehow they must have gotten moist. Replaced them and all seems well FOR NOW. Then I decided to make a skid plate for the oil pan. The car is so low, it scraps, I had to make this pan to help with that issue. Its pretty ghetto but I think its ok for just eye balling it really. Made from stainless steel, after the first 500 miles on the motor I will take it down, tweak it and then coat it with undercoating. Hope to get the car registered tomorrow and on the road insured for next weeked!
Wow I love both, great tastes man. The black on white is sick. Wheel specs?
Sexy as always stivva! My gf loves your zed. ^Looks great, if you put the 240z airdam, she will look so sexy! Looks great now though
I was wondering when I was going to see pics of that again. So insane!
Thanks man! And Lol really? You want my plate? It's just the one but I would be willing to sell it.
