I agree with John on what he has said. This is a very good basis for a quality manifold. Cylinder pairing based on firing order should seperate pulses as much as possible to keep individual cylinder pulses from interfering with eachother.
If you are running a divided turbine housing, you will want to pair cylinder 1,2,3 together and 4,5,6 together. This is vital to making a split scroll turbine housing work properly. On 2L race engines I've seen 1000rpm reduction in spoolup time by using a properly designed divided collector vs a common collector. Ideally you will want to use 2 wastegates as well to completely seperate each side of the turbine housing from one another.
Theres a good thread going on right now reading this here:
http://www.honda-tech.com/zerothread?id=1630241
Go read "Street Turbocharging" by Mark Warner. It will go into header fabrication a bit more.
Ideally, you will want to use an equal number of bends per runner. This balances the restriction across each cylinder. Priority number 2 is to keep the runners close to the same length. The average length of the runner will also effect the helmholtz frequency, and effects the torque peak. To read more about Helmholtz read this SAE article:
"Jameson, Renee T., and Hodgins, Patrick A., Improvement of the Torque Characteristics of a Small, High-Speed Engine Through the Design of Helmholtz-Tuned Manifolding, SAE Paper 900680, March 1990."
Regards,
Justin
