so i have a chance to get two HRE wheels for a $500. problem is that it is only two wheels. i dont have a a ton of money, and i know HRE wheels are really expensive, but i wanted to know if anybody knew where i could pick up just two wheels fairly cheap.
also, do you think if i bought them that i could sell them for more than that? i think i could but i was just wondering about the potential sale of only 2 wheels (as soon as i find out what model they are i will post what they are)
im about ready to remove the glass from the hatch of my car, i started poking at it with a screwdriver and all i did was start to tear the rubber, what did you guys do when you removed the window?
is the goal to take away the weight advantage of these cars? my car is backhalved, with straight frame rails running through the passanger compartment through the firewall and into the front subframes, and then im going to top it off with a 6 point cage and it will be more than enough
if i was closer id come and buy it as is for 500... thats not in a very important area of the block. it would pretty much need to be welded just to stop any oil leaking and for some strength but thats it. from the pictures, it looks like you are taking pictures of the passanger side front part of the block, that would be where AC mounts, and if you arent running AC you dont need those anyways..
305 heads bump up the compression and make it have lotso torque
its a cheap way to bump up compression, and making close to 300 hp at the wheels is most impressive.. shows you that the heads arent that restrictive. but yeah, you should get some like L98 heads or some aftermarket heads and you would see great gains
i want to see an LS1 weighed on here..
currently my car probably weighs around 1000lbs lol.. its almost completly stripped, no doors, hood, fenders, hatch, interior or motor
i got some "halos" for my LS1 camaro..
those look really nice, if someone had driving lights in the grille it would look sweet driving around with those halos on..
since my donor LS1 car was wrecked we just cut off the front part. put the car on rollers and pulled the whole car back using a dixie chopper while the motor/trans and cross memeber just sat on the ground
its been done before.. a guy got LT1 heads and intake and had them machined (think was around $500 for it to be machined) to be adapted to a regular gen one block. then used the TPI computer harness to get his spark and fuel injection
problems with the opti spark come from a worn out water pump leaking on it. vented optis cure that problem very well.
LT1s are cheap to buy and the parts for them are cheap becuase they are just an upgraded gen1 sbc. LT1 would also use the JTR mounts and any angled plug header for a regular sbc. for about $2500 you can get a new supercharger kit for the car, and it would be hella fast and with a M6 be very reliable and get 30 mpg. LT1s need high fuel pressure though, so you would need to upgrade your fuel pump
