ktm
Donating Members-
Everything posted by ktm
No problem. I scoured the net for hours before I started on my Wolf EMS wiring.
I saw that car on Craigslist. It was a good deal.
http://www.rbeelectronics.com/wtable.htm http://www.rallylights.com/other/wiring.htm
I routed my I/C piping under the car AND I have an electric fan. Under the car looks soooo much cleaner than in front of the engine. However, I will state that having a 1/2-inch spacer helped to align the turbo outlet with the steering shaft. If you are running a stock T03, clocking it straight down will not help - the linkage will be in the way.
At wits end - wiring up electric mirrors...sounds simple...yah right...
ktm replied to ktm's topic in Ignition and Electrical
Daeron, thank you for the suggestion, but I am positive that I have not 'switched' the L/R and U/D controls. I can get the mirror to move L/R by moving the switch L/R. I am almost 100% sure that the problem lies in the mirror/switch combo. The later cars used two motors; the 280zx used one motor and a coil/clutch combination. The switch for the 280zx jumpers three connections together when moving the mirror U/D; the Maxima switch does not, and only jumpers the correct wires to activate the second motor. -
Cozy, thanks for the help. Your wiring description is nearly identical to how I have mine wired. After looking at the FSM again, I realized I was mistaking the coil symbol for the defroster. It makes sense now, however, I also looked more closely at the switch diagram after reading your description. I've come to the conclusion that my switch will not work as I hoped. Your description and my review of the switch jumper diagram confirms it. The 280zx switch, when activating the up/down, ALSO activates the L/R (or motor). It jumpers all three together. The 1994 Maxima switch does not jumper the up/down together with the L/R or motor. However, I have a work around. My switch contains the mirror defroster function. I can simply turn on the defroster to activate the coil, adjust my mirrors up/down, then turn it off. It is not as neat as having a stand alone control, but the smaller size, single switch to control two mirrors, etc. more than make up for it. Thank you for the help. -
Intercooler - Thoughts on the one linked inside....
ktm replied to ktm's topic in Turbo / Supercharger
I was looking at that exact same IC. The core height is irrelevant, its the core thickness and the core width that matter. That particular core has 60 sq. in. of charge air surface (3 in. thickness x 20 in. long). That is MORE than enough for a T3. Wigen, J. Soileau, the reason I was looking at the IC with the inlet/outlets pointing up/down was because I wanted them to either point up or down at the time. The IC steve linked, as well as sweetleaf, has the inlet/outlet on the driver/passenger side. I did not want the inlet/outlet both exiting on the driver/passenger side. I wanted them either pointing to the ground or the hood. However, I went a completely different route and bought a typical IC with the inlet and outlet on opposite sides. I am running a very stealth setup and will not need to modify my front valence whatsoever. Also, I am running the inlet piping UNDER my engine. Thanks for all the input. -
I am wiring up a pair of 280zx electric windows (with defroster) for my 240z. I am using a 1994 Maxima switch to control the mirrors. I have the defroster working (very easy). Here is my problem. The wiring diagram from the FSM for the mirrors is incorrect as far as I can tell. The FSM shows TWO plugs with 2 wires each. However, upon opening my mirror up (after a couple hours of frustration) all the way to the mechanism, I found that the mirror has ONE motor and a wire wrapped coil with an arm that activates a clutch. There are a total of 6 wires for the mirror (2 for the defroster, 4 for the mirror controls). Basically, the motor controls the mirror (left/right, up/down) by alternating the current. When electricity is applied to the coil and creates a magnetic field, the clutch engages and the motor controls the up/down adjustment of the mirror. Here is the problem. The way that the mirror is wired up, all the wires carry current in both directions, depending on whether or not the mirror is adjusting left or right, up or down. However, the coil with the clutch only transmits current in ONE direction. It should only engage when the mirror is adjusting up/down. I can not, for the life of me, figure out a way to engage the clutch while the mirror control switch is in the up/down position. The the up/down wire and the left/right wire from the switch both tie into the same motor wire (as I wired it....I could be wrong here). The, for lack of a better term, generic power wire ties into the other motor wire. I've gotten the up function to work, however, when I move left, the mirror moves up as well (since everything is tied together). Can anyone shed some light on how I can get the coil to engage the clutch?
I called you guys on Friday and left a voice mail message. I'll drop an email later today. Thanks for the response.
I love the sound of the L28et without the muffler when revving.
I am nearly done with my build and only need the exhaust system built. I have gotten three quotes from three separate places for a 3" mandrel bent aluminized system for $500 to $600, including the downpipe. Is this reasonable? If not, just where should I be going?
Best place for silicone hoses and adapters that I have found so far: www.siliconeintakes.com
Take the intercooler and rotate it 90 degrees and you will see how the inlet/outlet are on the same side. Most cross-flow I/Cs have the plate and bars running parallel to the inlet and outlet. The same side I/Cs have the cores running perpendicular to the inlet and outlet. Like I said, if you rotate this one 90 degrees you can see that the inlet and outlet are on the same side. J. Soileau, I've got Corky's book and have referenced it extensively. I am still looking at the same side intercooler similar to 240Hoke's (was going to buy his but I need more of a custom fit). I like the layout of this one with the inlets and outlets either facing up or down. -
http://cgi.ebay.com/ebaymotors/FMIC-Turbo-Intercooler-One-Side-24X11X3-V-Mount-RX-7_W0QQcmdZViewItemQQcategoryZ33601QQihZ015QQitemZ250150783664 Same side inlet and outlet. Core is positioned correctly and given the long length should do a good job at cooling. Inlet and outlet could be positioned down or up. End tanks look decent. Thoughts?
Last weekend I finally got my OE engine harness back into the car. I removed all superfluous wires, replaced a few chewed up ones, attached all new connectors, etc., as part of my Wolf EMS install. After chasing two bad grounds, everything related to the OE engine harness works. I also installed headlight relays as well. This weekend I connected all of my harnesses/subharnesses for the Wolf EMS. I waited with bated breath as I turned the key to 'ON' and was elated when the Wolf ECU LED lit up and the fuel pump whirred for 5 seconds before shutting off. I was dancing in my garage for nearly 5 minutes pumping my fists. Now all I need are fluids, an intercooler, BOV, and exhaust and I can try to turn her over. I just needed to share with those that are more understanding. My wife just looked at me with glazed eyes and shook her head.
I gathered through searching that a few folks installed SPAL's electric fans and some others talked about installing SPAL's electric window kit, but I did not find anything where someone had installed them. Sooooo, has anyone installed their kit into a 240/260/280? How does it fit? Fairly straight forward install or are there a few places that require modification? How do you like them?
Identification Help Please - Not in Wiring Diagram
Anyone? -
I have a 1972 240z with which I am installing a 1983 L28ET and using Wolf EMS. I've taken my engine harness out for a refreshening, and at the same time removing superfluous wires. In doing this, I've run into two switches/relays that are not showing up in my wiring diagram. I've even looked for the number and color of wires going into what is shown on the diagram to no luck. Attached are the photos. They are a little oversize for clarity. The gray plastic switch/relay is by the wiper motor plug. The oxidized metal switch/relay is located by the driver's side headlight. Does ANYONE have any idea what they are and if I can remove them? Thank you. By the headlight By the wiper motor plug
First part I can't help you with. Now for the second question (which has been answered ad naseum here and the answer can be found by searching), the turbo clutch will work with the 5-speed tranny. You will need the throwout collar for the turbo or 2+2 - this is IMPORTANT. The throwout collar is paired with the pressure plate. If you use the wrong collar, your clutch will either not disengage or engage fully.
I just went junkyard diving last Thursday. I hit all the major yards in the OC and LA area: 5 Pick Your Parts (2 in OC, 2 in Long Beach, 1 in Sun Valley and 1 Ecology (Long Beach). There were a few N/A ZXs with turbo hoods, but no turbo ZXs. I found a few Z31 turbos (I was looking for a differential) but they were all 1986 (no LSD). Your best bet is to watch Craigslist, Zcar.com classifieds and Hybridz classifieds. I found my turbo engine in the Hybridz classifieds for $550 and it included the AFM and harness. The engine and turbo were in excellent condition.
Yes, $2500 is a good deal so far. However, I was looking at $300 to $500 to source the block and head and $300 for the crank alone (you got a deal at $150 for the crank and rods). What you, and ezzzzz have not mentioned, is head work. My $4500 includes a $2000 quote from Rebello to do the head. Sure, you could do it yourself and save some money which is the point people are making I guess. I would hate to spend $2500 to $3000 on an engine and not achieve its potential.
I was simply quoting a cost I have seen for a couple of sets of triples that required rebuilding. I have also seen new Mikuni's sell for $2000. I was simply pointing out that ezzzzzz did not mention induction and thus his budget may be a bit low. I know when I was contemplating stroker versus turbo, my stroker build was rapidly approaching $4500+ while the turbo build (based on a horsepower to horsepower comparison) was around $2000. I don't think that stroker and 'cheap' can be used in the same sentence, unless you put the word NOT before cheap. Cheap is relative though. I am nearly $6500 into my turbo build now. I would say that $4500 is cheap.
Ezzzzz, you did not mention carbs......in order to achieve your goals you are looking at triples. Best to add another $500 minimum to your budget.
Why the rush to buy the turbo tonight? Take your time, figure out what your goals are and then do some research. Sounds like you are buying whatever is available now.
