RB26powered74zcar
Super Moderators
    23
Everything posted by RB26powered74zcar
  1. Search my name for a carpet thread.... EDIT: Added my carpet thread link >> http://forums.hybridz.org/topic/66849-my-new-carpet-kit/
  2. Check for a vac line with a crack/ split in it. Is your gauge factory or after market?
  3. From what Dan told me when I asked about same, was the forum goes into a " service/ update" mode @ that time.
  4. Here's how they look with 285/40/17 on 10.5 CCW's
  5. I have a set of his BAMF rears in FG, and a full set of BAMF in CF. I have the CF rears on, with regular FG ZG's in front (temp.). What did you need to know?
  6. The thickness amount you'll need is what it will take to get the bearings to ride in the center of travel in the cage once your car is at ride height. I think you will solve the problem by doing both pass and driver sides. Maybe flip that one whole axle that is pulling out at the diff side.
  7. Sure... if you want to spend that kind of money.
  8. I made one for my old axles I had this problem with (long ago). It's the part with yellow paint on it. What I did was have a machine shop make me a circle the size of the companion flange mating surface, with the 6 holes drilled in it to go between the axles cage, where it bolts to the companion flange. It fits between the companion flange and the cage where you bolt the two together. I only had to do the passenger side for some reason.
  9. Looks like the center bars are to short, causing the bearings to pop out of the cage. You could make a 1" thick spacer to go between the companion flange and the cage, which will make the cage ride deeper on the bearings...
  10. Glad to hear you got it how you like it now! How bout some cruising vids Wish we were closer, I'd like to run ya ...
  11. Hope these help.... ( the outer seal is 3 pieced )
  12. Just messin with you Are not the front / rear different, or am I missing something?
  13. I was going to put this one on but decided not to. It's the only CF piece in existence...
  14. I think this is the best solution to this. Please follow pazefs's request by contacting him directly to settle any money / parts owed. Thanks
  15. Looks to be a nice clean un molested Z to me. Other than the carb swap and sun roof that is...
  16. Take your oil cap off for a listen. How is your oil pressure Sounded kinda like a exh leak/ spark plug missing type noise on my computer... You sure it's a metal on metal sound?
  17. Yes, I had the trigger wheel machined to fit the ATI race damper.
