RB26powered74zcar
Super Moderators
    23
Everything posted by RB26powered74zcar
  1. Can you fab up a bracket? Picture would help...
  2. I have the RB FSM's in PDF format on my hard drive but don't know how to upload it.... Anyone know how to send, or post a pdf file?
  3. Real NICE !! Like other member stated, cage is wicked....
  4. AHH... I se what I messed up. The last part I wrote >> "Then go to the last post and click on the "reply" tag, and it will auto add the multi quoted quotes in your reply post..." Is not correct. Go past the last post and click the add reply tag. It will add all the quoted material...
  5. Just start at the upper most post you want to include in the multi quote, and click on the "multi quote" tag. Keep going downward to the next post you want to add, and click the "multi quote" tag. Then go to the last post and click on the "reply" tag, and it will auto add the multi quoted quotes in your reply post... Make sense... ??
  6. 5 Star rating from me.... Awesome job Lee!
  7. What is your fuel system consist of? (tank, filters, lines?) Sounds like you have trash in your tank/filter...
  8. Look up TimZ He has a nice tripple TWM set up with a custom log.
  9. Thanks. We'll see what grretc thinks about them first, and go from there...
  10. Next in line if grretc is not interested.... Can you take some pics pleeze?
  11. Pistons are graded. Check the top for size and be darn sure your replacement is the same size. It would be best to hone the cyl wall and use new rings, but next best would be to put old rings on replacement piston, since new rings will not seal in a non honed cyl. Just my opinion...
  12. " what does this tell you? " It shows that you need to re read the rules on how to properly title a post....
  13. Thats cause SoCal is the capital of tweaker land....
  14. LOL... you are correct. I was remembering a IC tubing thread with my remarks...
  15. So long as there was no support rib down the underside center on the OEM piece, it should hold up as others have said
  16. Kinda, sorta... The one I remember seeing had a handle to roll the tube some how.
  17. I know I saw a tool posted here (HBZ) that did the same thing, and alot less expensive. Just don't recall who/when posted it... Edit: I think it may be in a RB build thread.
  18. This is what I get clicking on OP's link.... "lol" http://www.aircraft-tool.com/shop/search_result.aspx This is what I get when your link is used... http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=AP145
