Everything posted by Challenger
78Z: L28et MS2, EDIS, Holset swap...
Challenger replied to Challenger's topic in S30 Series - 240z, 260z, 280z
Gonna pick up the pulley tomorrow. Basically I had the front pulley turned off. Itll look nice. Got the holset apart to reclock the housings. Removing the exhaust housing was pretty hard but it came off. I need to do the following this week for the turbo. -Buy T3 spacer -Grind down original wastegate bracket (hits exhaust manifold BAD) -Fab a mount for my wastegate (wastegate is from my 81 turbo) and cut down the arm to work on the holset -Install longer studs on manifold -Modify oil drain tube to fit onto oil pan, its closer than I thought! -Possibly modify banjo fitting? On the banjo fitting I went to house of hose and bought a banjo bolt for the holset. The original banjo is 12mmx1.25 and the holsets is 12mmx1.5 They had one that worked for the holset so I bought it. Problem maybe is the holes on it are much smaller than the stock bolt. Both the hole going through the center and the one through the sides are both smaller. Ive been reading about some people running a restrictor for the holsets. Is this just to bump up the oil pressure and help reduce flow through the drain tube so it doesnt get backed up? I read somewhere about the importance of keeping the drain tube a smooth and easy route to the oil pain. Any opinions? I might take this one back and go check out a diesel shop in town. I didnt know about them but Im pretty sure theyd have the right bolt. Other things to do this week are get the db37 all soldered up. I think I need to go get a smaller solder gun since the solder cups on the connection are quite small... I need to go get another inline fuse for my wideband controller. Ive seen it wants a 2 amp fuse for MS power and than 5 amp for the wideband controller. Do you think it would be bad to just use a single 2 amp fuse (power for MS and wideband are from same wire) for both, or will the wideband continually blow it? -
Do not keep replacing wires with heavier gauge wires. Thats not going to fix overcharging, its just going to fry other things, possibly multiple things. Its not likely since youve changed alternators but could it be your voltage regulator? AS mentioned might want to take the harness apart a little to see if there is a short nearby. Did you try measuring voltage at the battery and other spots on the car?
Awesome! A cummins fixes anything. haha
Well I decided Ill probably just get Derek's setup. From what Ive seen the fact that the outer pulley is cut off wont affect it... or will it? His instructions said the only place his trigger wheel and hub touch are at the face where the bolt goes in, it doesnt touch cocentrically. Can anyone confirm this? If so Ill just go have the edge where I cut it trued up to look nice. -
Cool. Thanks for the picture. Doesnt look like it needs much... when I mocked it up I thought it would take more than a half an inch but it looks like yours is just half an inch. Im going to see if I can get a t3 spacer cut out at school on the plasma cutter as well as check on longer studs and an adaptor fitting for the oil feed line. Also, I noticed the original oil drain line fits on the holset. Looks like Ill need to just cut it down and run a longer tube. That is after I rotate the housing 90 degrees.
Picked up a Hx35w for free from member "mastermechanic", thanks again Josh! Anyways, Ive been reading on how to use it on my car and had a few questions. Regarding the split housing, is it basically only beneficial with the use of a proper manifold? Is using the stock manifold just not utilizing its full potential or will there be adverse effects? The housing hits the manifold so ill just need to use a spacer correct? It appears that the top two holes on the exhaust turbo housing bolts are threaded while the bottom two are not. I drilled them out and it slides on now (without intake housing). As for the spacer will just any T3 to T3 flange work? Ill be switching over the wastegate from my stock turbo to the HX35w so I can keep the boost down where I want it. Thanks!
Well, all of the wiring is basically done so no real point in getting the full harness now. As long as it works, and it looks good as is, Ill be happy. As for the trigger wheel. I went to check on getting it turned down so it could be pressed on and was quoted less than $60. I talked to the machinist for awhile about engineering and he threw it on the lathe to make sure he could get it lined up correctly. He was really nice. Anyways I went home and was going to cut off the front pulley in order for it to take less time for him on the lathe, save a little money. Well, somehow I had remembered the pictures above with the trigger wheel right up flush against the inside pulley, so I was going to have him machine of the front lip (part I cut off) and then machine down the next lip on the outer pulley so I could slip on the trigger wheel. Well, obviously that isnt the way to do it. Its mounted all the way forward the front lip. With it flush up against the front of the inside pulley the sensor cant be mounted where its directly on top of the teeth how its supposed to be... So basically I ruined my 78 pulley.... I have my 81 pulley that I can machine the front lip down like I was supposed to but its going to be alot further forward which will make the VR sensor mount prone to flexing and moving/rubbing on the trigger wheel. Oh well, learned something. I hopefully be able to find one at a JY or on an engine in town I might pick up for the head. (JDM e88) Softopz, I might consider Derek's. Nice stuff but I think it will be fun to make it. I might even design it on solid works and see if I can make it at school... -
Using megasquirt to trigger stock fuel pump relays
Challenger replied to Challenger's topic in Ignition and Electrical
Ended up just using another switch that Ill flip as I crank the car. I figured I could use a second relay which would ground the original fuel pump relay triggered by a crank signal but now my car will be impossible to steal. haha Anyways heres the new wiring. Fuel_Pump_Wiring.bmp -
Did you try contacting him earlier?
Had a HUGE (36") HybridZ.org vinyl made for me.
Challenger replied to ModernS30's topic in Non Tech Board
Looks great. I wish someone would make a business card you could just slip under someones wiper. Maybe a spot where you can right "my username is ___" I saw a 280z parked and I had to write a ugly note and put it under his wiper. haha -
Another question... I ended up just using the stock fuel pump relay with a toggle switch ran to power all the time. So I can run my fuel pump as long as the battery is plugged in. I still want to hook up the oil pressure cut off switch which is simply a ground when their is oil pressure. How I have it now. Picture attached. So any ideas on I can incorporate the stock oil pressure sender and utilize its ground to cut power to the fuel pump in the event of lost oil pressure/crash? This would work fine with the holley unit but I dont want to spend the money for it. So is there a different datsun relay that would perform this task in a similar of manner? Ill check my ZX when I get home to see how each of them work. Thanks Fuel Pump Wiring.bmp -
That was added. haha
Fender Vents, General aero Questions
Challenger replied to Challenger's topic in Windtunnel Test Results and Analysis
Front lip. Doesnt go all the way up the fender but I thought this covers a large portion of the upper cross section of the tire. Might redirect the air up enough to not hit the upper part of the tire as much. -
PM your address and Ill send you a set.
Header wrap and a blanket would be a little different. Id bet on the header wrap trapping alot more heat than the blanket. I removed the heat shield on my n42 intake and was going to do header wrap since Ive seen it do wonders on other cars but Im thinking about just putting the heat shield back with a turbo blanket.
Is the clutch on your subaru stock?
200K miles! If it runs good $800 is a pretty good deal.
Throttle body upgrade with TPS sensor for MS, N/A 1978 280Z
Challenger replied to 2s2mad's topic in Parts Wanted
Also I think the stock cablep pulley on the 240sx Tb is made to where the throttle opening doesnt open at a linear rate. I dont have one to look at but If I recall from when I had one the first small section of pulling the cable opens it slowly and as you pull on the cable more the faster it opens. It helps with light throttle application, the throttle wont be as on/off. This problem would be amplified with the stock linkage. Youd have to figure it out, but as an example you might have the equivalent of the original full throttle when the 60mm is opened only 3/4 of the way. Which means youve really only given yourself a shorter push on the throttle for the same power, which doesnt seem beneficial. -
If you think about it, your runners and ports will only flow so much air. Just like water in a hose it will only flow as much as the highest restriction will. -
Yeah if I had a nickel for everytime someone says 2.8 liter v6. haha He sounded like he knew very little about the engine but as mentioned for $350, you can scrap the car for a couple hundred and youd have a cheap engine. Pull off the head and pan and see what its got. It would have been a garunteed profit, although I probably would have just set it on the engine stand for when I blow my turbo engine. haha Only problem would have been getting it home, probably would have had to buy the truck and yank the engine out. I could scrap the car down in kennewick and haul the engine back home. (kennewicks 2 hours away from me)
So Ive been planning my modifications to the front end of my car.. Car is lowered a couple inches, fyi. Heres the plan - Enclose radiator opening, seal the airdam to the bottom of the intercooler, etc Old setup Now I have an intercooler so Ill need to redo it. - Seal the bottom edge of the air dam to the bottom of the core support. Like this... I can attach directly to my supports. Extend it up the sides a bit enough to cover my wheels -Make some sort of panel to direct air away from the front of the tires. See thread.. http://forums.hybridz.org/index.php/topic/86261-front-of-wheels-aero/ Its not a good picture but imagine something like this (bottom left of screen) but larger and closer to the ground. Im thinking about using some sort of plastic, imagine something like the garden edging stuff so it could actually scrape the road. It would be flexible enough to not snap off but stiff enough to actually redirect air. It would go all the way across the car in a arc, wheel to wheel with the middle further forward. - I originally planned on just having a filter direcly on my holset but im thinking of incorporating an intake duct that will scoop up cold air from under the car. If you can imagine the area behind the radiator and in front of the sway bar, thats where the duct would be. Id get alot cooler air and a little bit of a "ram" affect. Should be good for 50hp, assuming the ducting is chrome as well. haha - Lasty it comes to my primary question, regarding venting the engine bay. I relocated my battery so now both areas under the inspection lids are open. I have a vented hood already and was considering modifying my inspection lids to have a vent. Im not sure how much venting it takes to avoid air going out of the bottom of the engine bay but I suppose too much isnt bad. haha Given that, I was looking into how Id setup fender vents. There are a few factors that come into play. I dont have fender liners so the battery tray area is directly open to the fender well. If I just install a vent on each side of the engine bay where it just vents to the fender *WELL* would that be effective? With my other modifications wouldnt the fender wells likely be a lower pressure area? Second option is to actually vent from the engine bay through a closed duct and actually out the fender, completely bypass the fender well and vent air to the outside of the car. I was even thinking about the possibility of running two small fans in the ducts to help evacuate air even at low speeds. See this thread for more pics and discussion. http://forums.hybridz.org/index.php/topic/61219-fender-vents/page__p__563492__hl__%2Bfender+%2Bvents__fromsearch__1#entry563492 Of course all of this will be paired with equal attention to the back although I havent considered what Ill do as much. For now its just VG, and hopefully a SDI 5.25 inch spoiler. Any comments and discussion is appreciated. I think this stuff is super cool, hopefully Ill be able to apply some of the what I learn in fluids this semester.
