Trevor
Everything posted by Trevor
  1. In this month's (August) Hemming's there is an: CAL CUSTOM valve covers, early small block w/2 small breathers on each cover, $140; Ford flathead 49-53 3-carb, Fenton, $285; Navarro Glendale 2-carb, $325; dual quad for 49-62 Cadillac w/Rochester carbs, $325; Ford small block new Motorsports aluminum intake w/water outlet, $200. PH: 860-589-6789 days, 860-583-9285 nights, CT. Parts Ad I remember them on the shelves at Pep Boys - the fins are pretty deep, not as subtle as Ferrari's.
  2. Looks like the boat is here to take it back to Japan.
  3. Will the stock 280 Z rotars bolt to the five lug 300 ZX hubs? Only if the rotors are drilled for 5 holes. The rotor bolt circle is not the dame as the wheel bolt circle (it's smaller) Don't know if they are the 5-bolt 300ZX and 4 bolt 280Z are same diameter and Don't know of any non-vented 5-bolt rotors with the proper offset. Will the 300ZX 5 lug Hubs mount to the 280 Z spindles? Yes - same wheel bearings I/D and O/D and same size spindles. Offset is a little different. I will throw out a tangent here also. I have read that the '70-'81 Camaro front hubs will fit 280Z spindles also. Never had the parts in hand to test this. But that's one way to get 5-bolt 4 3/4" circle wheels and big brakes on the front
  4. Not that power (no lack of) is the issue, but I think the Z is too light to tow a load as heavy as another car. You'd risk jack-knifing it if you have to hit the brakes. I'd hire a tow truck - $60 buys peace of mind.
  5. I always thought a "reverse curve" like a Jaguar XJS would work from a 2+2. Change the hatchback to a decklid. It would have to be black
  6. My '66 Mustang will start un any gear - there is no "safety switch" on either the clutch pedal nor the gearshift linkage. And it's all stock. The latest car I've driven without such frills was my dad's '70 Maverick. I've limped into a few gas stations using the starter motor when the tank was down to fumes!!!
  7. Warning = vent follows!! I get really annoyed by the state inspection process here in Virginia. Maybe it's not as strict as other places but i moved here from Arizona and never saw such a fiasco. I always took my cars to small independent mechanics for this "service". $15 for a 1 year windshield sticker and a pink ticket with 18 checked off points. Once my '77 Spitfire failed because they couldn't find the catalytic converter and I was told by the talking head at the service counter that "someone has removed it and replaced it with a straight pipe". "We can fix it for $400." I played ignorant and walked back into the shop so he could "show" me the completely stock exhaust system. "What's that?" I innocently ask, pointing at the catalytic converter.....I guess that made him mad and he still failed my car because the horn "isn't loud enough". Again the stock original parts - there are 2 horns- pitched a high and a low. Both were working but I replaced the high pitch with a second low from a parts car - twice the decibels at low freq. Whilst in the shop I noted that these guys listen to a looping 8-track of "Freebird" cranked up loud so their hearing is probably shot. You have no recourse, other than to use another Saturday and take the car to another shop. I paid the $5 re-inspect fee after my no$ repairs, then exacted my revenge. Word-of-mouth advertising works both ways. I work for the area's largest employer over 13,000 people. I made sure that everyone who would listen knew about my experience at this particular garage and the name of the manager.
  8. R-200 refers to the diameter of the Ring gear, which is 200mm which translates to 7 7/8". The working parts are just an inch shy of a 9" rear end.
  9. Just a brainstorm near-topic..... Has Anybody looked into manufacturing stub axles? The supply of stock pieces seems to be shrinking, reasons: - They wear, and break (see ZPARTS site) - 240 racers want larger 280 axles - CVJ conversions want 240 and 280ZX axles for the companion flange spline count. New parts could be designed with a hub flange large enough for th 4.75" 5-bolt circle. Is there enough material on the end of a stock Chevrolet axle that could be cut off, turned down, re-splined and heat-treated. Wonder if Currie or Moser will take small prototype runs?
  10. It could be friction welded or rusted, my guess is the outer strut tube is bent. the PO was parking it like the Blues Brothers and slid into a curb or something.... You're better off with a new (at least different) part.
  11. Damn, does that ZX come with a "ABBA" 8-track.
  12. Their ad in Kit Car doesn't list a web site address nor e-mail. Evoluzione's distributor is... K-1 Styling U.S.A. Classic Replicars 301 R Henderson Ave. Cumberland, MD 21502 301-722-0740
  13. From the look of the shoe on his other foot, I'd say he was on his way to play a round when the golf clubs fell off the back of his bike.
  14. If you are intent on stealing that car, just save your nickels and outbid the curbstone dealers at the next Police surplus property auction.
  15. I think he is trying to conserve petroleum resources by reducing the oilpan capacity by about 3 quarts.
  16. It looks like it takes more room than a rotiserrie, a tilter would need the width of parking 2 spaces to tilt a car versus one to spin it.
  17. Trevor
    Seats?
    I bought a seat re-upholstery set from JC Whitney, pn 78XD7493XF. They were made by Kar Kraft in California and fit my '77 seats perfectly. They aren't stock, in fact they look better with pleats and perforated vinyl. Best part was the price (they're usually $155), I believe I paid $115 ordering from their sale catalog.
  18. The closest non-Ferrari engine I've ever heard that sounded like a Ferrari was a Datsun L-6!!!
  19. What keeps them from turning on the axles and the car falling fore or aft?
  20. There is kit car called the Evoluzione, that has Lambo-like scissor-hinge doors. You might investigate how its doors hinge works, it is based on the front-engine rear-drive Camaro/Firebird platform. More like a Z unibody than the Fiero-based Countach kits.
  21. Ooooooooh. The Del Sol back window, Viper roof panel..... A Targa - top Z!
  22. The cool thing about Countach doors is they swing from one corner, so you only need one hinge per door, it's a pain to get two hinges to line up in a short curved door. (both pins have to be in the same line - look at older cars and trucks with exposed hinges) I recall reading in a Kit Car magazine that some Lambo Countach replica homebuilders used large industrial/commercial door hinges. It looks like an overgrown house door hinge, but the pin rides on bearings or bushings. You might get lucky and find them at Lowe's.
  23. Tips: Change the receiver/drier. Flush each section of hose separately.
  24. Shouldn't that be '85 300ZXT to get the 5 lug circle?
  25. Went to a Charlie Daniels' concert a few years back. He had something to say about street crime: "Justice is only as far away as a sturdy oak tree and 20 feet of rope." After a fair trial, of course.
