jap tin
Everything posted by jap tin
  1. Going to be hard to hook up on a cold track. I heard a freeze warning and low of 25 over night with a high of 50. If you hook you should fly. Should be great air.
  2. 91" on the back halfed car 94" on the tube chassis car
  3. twin turbo, transbrake, I think you really want a 9" under that Z. The 9" doesn't bolt in, you have to be friendly with a welder and bender, but you can hammer it and not worry. My na sbc Z has had 1.15 60ft's with a 9" rear under it.
  4. first bid is a thousand dollars and the reserve is not met. This will go through the roof.
  5. Yea, David K knocked me down to 3rd. LOL.
  6. Congrats on the cars and the times. I knew there was a quicker small block Z out there. Now we have someone in the 7 second range on the time slip page.
  7. It all helps. Aluminum and titanium are your friends.I have an aluminum drive shaft, aluminum spool, cut back ring gear, aluminum pinion yoke, rifle drilled axels with titanium drive studs and aluminum lug nuts. Make everthing that you turn over light as you can.
  8. I just got back last night about 11:30. Feet hurt, knees hurt, walk walk walk. Went through all the SEMA stuff Tues. and Wed. hit the APEX show Thurs.Used the monorail system which beat the heck out of the shuttle busses.Lots of fun, lots of goodies on desplay.
  9. jap tin
    Sema
    You might want to check this out. http://www.sema.org/main/semaorghome.aspx?id=56034
  10. jap tin
    Sema
    Going on the 31st coming back on the 2nd.
  11. Used to go to the Thrifty's and get ice cream for a nickle a scoop.
  12. 445" AJ 481X .Olds heads, blown alky. Went 5.50's in a TAD. Going in a F/C chassis with a 32 Bantam shell. Easy 6's with a little blower.
  13. jap tin
    Sema
    Anyone from here going?
  14. 12's , 11's , 10's , 9's , 8's , Time to quit is now !!! Don't let what happened to all of us happen to you. There must be a 12 step program for Drag Racing. LOL.
  15. 0-200mph in 27 seconds!!! I plan getting there in 6 seconds in my new ride. Thats 21 seconds faster, LOL....
  16. Yep, he needs to go to big-phil's riding school.
  17. Try the Hooker swap headers. 1 5/8" long tube .
  18. Jesel KSS 335050 will fit the Edelbrock and AFR heads. $795 at Jesel, probably cheaper through Summit or Jegs. Once you go shaft you will never go back.
  19. 1 5/8" primary and I believe they had a 2 1/2" collector. I had a set on one of my first Z's.
  20. If you would like it to leave a little harder with the converter that you are using now, don't bring it up on the foot brake . depending on how high I brake stall it (so far, around 2800-3100 rpm), Come up to the line at an idle and then matt it. It will flash higher and hit the tires harder. Better 60ft. times and et's. ...
  21. anti roll is a soild rear end deal, I have one on my chassis but I also have a soild axel. Don't worry about a anti roll with the IRS.
  22. that is the drive off the cam to run the fuel pump.
