MONZTER
    37
Everything posted by MONZTER
  1. What do the ports look like on that thing. I like it so far
  2. I am not sure what measurment you wanted, so does this help.
  3. Tim, I think your spot on. Funny thing is the guy does great work. Did a beutiful job on my NA motor. So I will leave it with him. I know if I call him every week it will get done. Its when you dont call it sits. The squeaky wheel gets the oil.
  4. Ya NOS, thats frightening. It already has 130 HP and weighs less than 400 lbs. It scares me just like it is. (for now) muh hahahah BTW Called the machine shop, says it will be ready next week, I am not counting on it..
  5. The part has been done, still have not gotten my block back from the machine shop (note to self - call machine shop) So, has not run yet. Also, I bought a new bike and have been spending time on that instead of my car. Will be back on the car real soon as I am now happy with my bike
  6. So does this mean all of these versions are JDM, or are people just confusing them because they all look similar?
  7. So What's with the JDM valve covers I hear people talking about. I have seen 3 different ones that are all called JDM. This one with Nissan Logo, I think in smaller letters This one with Nissan letters larger and more blocky (mine, I found in a US junk yard on a 280z) An one more I have seen with Nissan logo but made from plastic. Does anybody know the correct story??
  8. No, Nothing new. I got it to the point where I need to get some temporary guides and seats in one chamber and flow test it to see if it is worth finishing. I have not been working on my turbo car much since I got my bike. The NA motor has been running strong. I will be getting back on it after the first of the year and things slow down. I'll keep you posted when I move on with it. MONZTER
  9. I got some liquid nitrogen from the welding store. Put it on and the metal and tar shrink at a different rate. It literally fall off. Did it on mine to all of the factory coating on the inside of the car.
  10. Yep 14x1.5, I had a custom left-hand tap made, as it was not available anywhere. So one side is right hand threads, and one side is left hand threads, anybody know why there are left-hand threads? What would happen if you used right hand threads on both sides?
  11. Why do you need an idle screw if you are using an IAC unit? Wont you set the rough idle with the butterflies, and then let the IAC do it thing.
  12. OK I'll Play Engine size= 2.4l +1 Engine work done= Blanced and blueprinted stock rods, factory cast pistons and rings Compression Ratio= 10.6 Head= n-42 Head work done= Welded chambers to 36cc, and ported stainless under cut valves Cam= MSA Stage 3 Intake= modified non egr nissan Intake work done= Matched to intake ports Header & Exhaust= 6-1 header, with full 2/12" into a straight through muffler MSA stuff Type of Fuel control= Electromotive Type of Ignition control= Electromotive Rev Limit= 8000 Accessories= underdrive pully for alt. nothing else Dyno HP at wheels= 209.9 @ 6500 RPM Dyno Tq at wheels= 178.1 @ 5500 RPM MONZTER
  13. I am the Senior Engineer for a bicycle company called Felt Racing www.feltracing.com. I usually am working on designing the latest ridiculously expensive carbon fiber race frames. Currently working with our Tour Team Garmin Chipotle, getting their new bikes finalized for next season. MONZTER
  14. Great Idea David, I am sure this will be a big help to everyone out there. Thanks for helping the group. MONZTER
  15. Hi Guys, I moved mine back as far as I could without removing the hood latch, or having to cut up the car. My purpose was not for weight distribution, but to make more room for the cold air intake, radiator fans/balancer, and to smooth out the bends to the turbo and intercooler. 3/4 was the max I wanted to go, which was enough for my needs mentioned above. MONZTER
  16. check this http://burnsstainless.com/BTEC/btec.html
  17. David, looking forward to the pictures, glad to have helped. MONZTER
