Derek
    53
Everything posted by Derek
  1. I second Tuner studio. Much better program and well worth the money. Derek
  2. I used magnacore for my setup. Their noise suppression is really good and you can get them custom made for no extra charge. The turn around time is fast. Derek PS your stuff went out yesterday.
  3. This is becoming commonplace on Ebay. You don't pay ebay charges on shipping.
  4. I cast the block when I was doing the manifolds. Not familiar with the idle block from DIY but what your trying to accomplish is to bleed air from the filtered atmospheric air into the vacuum portion of the block. Derek
  5. For a site that encourages encourages searching (I,m in agreement) hybridz search engine blows. I've searched for stuff I know I saw the day before even using title key words and got no results. The old site had a Google search box incorporated and it seemed to work a lot better. Derek
  6. Turbo encabulator that's a proper fit for the Z.
  7. If you use the chassis punch (which would be my recommendation) put the cup on the convex side and the punch on the convex side. Much more civilized than drilling! Derek
  8. Unfortunatly it won't work. See how the damper hub has 2 ears protruding into the hub. This would keep my hub adapter from even going in. Then there's the problem of the depth not being the same. Plus if you look at the distance between the boss where the washer sits and the tabs there isn't any room for an adapter either. You can have your 2 row rebuilt for around $100.00 or buy a new one for $200.00. Derek
  9. Cool oven! It looks like you used the controls and elements from a regular oven. What's the box made from? I need to re-bush my suspention parts and thought I would blast and powder coat them while I was at it. I'm looking at the Eastwood dual voltage gun. Derek
  10. Saw this oven on my vacuum form forum oven Looks to be a pretty nice setup. Derek Oh crap I just necroposted!!! I thought that last post was Feb 2011 not 2010. Still a cool oven though!
  11. I hear ya. It's all in the setup. I love the ones where you get 90 percent there with the setup and then realize "that'll never work". The main reason I'm thinking step key is the strength of the key way is somewhat determined by the fit. When I try to make the connect cut if I'm off a hair it may be problematic. Then again I can make the cut and if it's not right I can open it up and do the step. Derek
  12. My newly acquired diesel crank has a little key way damage from an exploding damper. Since I have machines I have options. At the very least I have to touch up the groove with the tig welder and then mill the groove with a key cutter. I figure since I'm going to the trouble of setting it up in the mill I might as well convert it to a single key. Now the options kick in! 1) Weld damaged slot Pick up the existing slot in the mill and connect the grooves for a single key. 2) Don't weld the slot and oversize the entire key way and the install a step key. I may have to make the key but that's not a problem. Realistically I could mill the slot then fixture the new key with super glue and then mill it in place. This is the way I would like to go unless someone in the know has a better idea or sees a problem with this approach. Thanks Derek
  13. According to Pete in this thread specs Which is what mine measured. Derek
  14. Run away from that car. The only way you won't be revisiting the rust is if you strip the car and have it blasted. I have a rust car and the only reason I stuck with it is I already owned it. Derek
  15. I've bought 2 "good" Dampers from hybrid members. One never showed up and the other one was broken so bad that there was no way it could be used. Make sure your definition of "good" is the same as theirs! So no I don't have a source. Realistically if you buy a used one and pay to have it rebuilt your almost at the price of a new OEM unit. Derek
  16. Sorry you had trouble with the fit. Did you have to grind the back corner of the bracket like I suggested? It may have just been the angle of the dangle when you were installing because I did a test fit on a motor I have here and it bolted up with no problems after I ground the corner. I wonder if there are different timing covers out there? Derek
  17. I slept in the luggage area of my Z at Road Atlanta for 3 nights in the early 80's and took it camping plenty of times. Cooler in the center running longways tent and sleeping bags jammed on the sides and my Alice pack on top of the cooler. Fun times Derek
  18. Yes this has dinged my credibility a bit but hopefully I'll have some product in the future. I started this when I was slow but my pattern business has picked up quite a bit since then. Plus there's that stroker thing. Derek
  19. Did you assemble the motor yourself originally? Maybe it was that way when you got it. Derek
  20. Got done with the test fit. No problems. The speakers fit fine and there is plenty of room between the evaporator and the speaker. You can fit the panel in with the speaker installed. Here' some pictures. Here is the spec sheet on the infinity speakers. There isn't a ton of room for the magnet so I would try and stick with something close. I have a few orders to fulfill and then I'll have them available. Please post here if you think you want a set. 240Zip is already on the list Thanks Derek
  21. That's sad but then again sometimes the fun is in the chase. Also think of the knowledge you've gained that you can apply to the next build. When I was putting my car together I knew it was going to be my daily driver. The base design factor for me was "will my wife ride in it". She does! Good luck on the next project. Derek
  22. I can do any color you want as long as it's black or silver Contact 280znhchris he powder coated one blue that I sold him. I can sell you a raw un-anodized one and you can have it coated yourself. Pic of his cover
