53
Everything posted by Derek
Ever since I was a small boy I dreamed of having a 6 speed transmission in my Z car. Ok it was actually in 2014 when I heard that people were retrofitting the CD009 into various different vehicles and thought that would be awesome. At the time I was up to my ears in KN20 development and I put it aside immediately. Fast forward to a few months ago and I decided to finally bite off doing my own system. The Hoke system is a great piece of engineering but it wasn’t what I wanted. JWT offered a conversion plate but you needed to source a used bell housing and like the Hoke adapter required a special flywheel. The solution for me was always going to be a cast bell housing. My goals were to be able to use my existing clutch, pressure plate and flywheel. I contacted Chris at at Godzilla Raceworks too get his input on the feasibility of my approach. I know a lot about castings but my knowledge of what components play nice with other components is seriously lacking. Based on the info Chris provided I decided to move forward. Step one. Jump in with both feet by buying a brand new CD00A from Z1 Motorsports. Step two. Cut the bell housing off of a brand new transmission so there was no turning back. The first thing I needed to determine was can I get 100% spline engagement on the clutch disk. I setup a block, crank and flywheel on the bench. I removed the pilot bearing. I then slid the transmission into the crank until the pilot shaft bottomed out. I pulled it back 6MM and made a reference mark on the bench. Visually the pilot shaft looked like it would play nice with the pilot bearing so I moved on to the next step. Check spline engagement. I bolted an old PP and disk on and slid the transmission back into place. I had over 100% engagement and it looked like some version of the longer release collar would bridge the gap. So now that I was confident the math would work I had to work out how I was going to machine the casting. The big problem for me is my CNC mills are converted Knee mills and they don’t have a lot of Y axis travel. I also don’t like doing uber precision work in a production environment. I decided early on that I was going to leverage the existing front cover to be the “glue” between the transmission and my bell housing. My plan was to sandwich the front cover between the bell housing and transmission. After confirming that I had a decent machining strategy it was time to collect data. I scanned an old 5 speed case I had. This is what I refer to as a dirty scan. It’s only for me to design around. I import the mesh into my solid modeler and it becomes a reference for the features I want to add. All of the critical measurements are done with a touch probe in the mill or conventional calipers and micrometers. First step was to align the mesh with the bell housing holes I acquired with the touch probe. I also pulled the input bearing hole from the case when I got the bolt pattern. I then then positioned the scan and the probe data I made of the CD009 cover centering the input with the input from the case. And then I push a couple of keys and suddenly like magic a bell housing casting model appears. Ok there is a lot more to it than that but you get the gist. Next I had to design the machining fixtures. All of the important stuff is done in the first setup. This ensures the input shaft of the transmission lines up with the pilot bearing in the crank. Pattern time. Without getting into a ton of detail here is the finished tooling just before I shipped it to the foundry. So while I waited for the castings I worked on all of the fixturing. By using the existing front cover I was able to save a ton of precision machining. But the cover has to be positioned properly. I accomplished this by making a fixture that indexed the cover on the input bearing. I then bring all of the bolt face bosses to the same level and then ream 3 of the bolt holes to accept a 10mm hollow dowel. Here is the finished cover with the dowels installed. So I guess I was in a hurry on the machining since I didn’t get any process shots. Here is a shot of the first test after machining the engine flange. This is testing the cover fit. This is before the clutch lever and slave work. And the finished product. I designed the cross member to be as versatile and adjustable as I could. I also decided to share the load between the floor/frame and tunnel. On most of our cars the tunnel is probably one of the most unmolested rust free parts of the car. It uses the crossmember from a 72 and up and an Energy Suspension transmission mount. Both ears are adjustable up and down and the ears are slotted so the cross member is adjustable side to side. You can remove the transmission just by removing the ears. The floor/tunnel bars stay in place. Here is a slightly fuzzy shot from underneath. And the finished product. What’s next? Now that I have a running car I’m finishing off a second bell housing and cross member and sending it out to Chris at Godzilla. He is going to test fit it in a 280Z and check the fit of the cross member as well as the clearance on some headers. Godzilla Raceworks is going to be a dealer for these and he took care of having the drive shaft made. As soon as we verify the fit on his test vehicle I’m going to go into production. I’m not taking pre orders but if you want to be on the list of pioneers you can contact me or Chris at Godzilla. When the bell housings are done you will have the first option to purchase. Pricing: Bell housing. $900.00 Crossmember. $295.00 Labor charge for modifying front cover. $75.00 You must supply either a brand new cover or brand new take off as a core. No used covers will be accepted. So far I’m really liking the gear spread on the 6 speed. I currently have a Subaru 3.9. I’m going to put the stock 3.364 diff back in to see if it brings the revs down at 75mph and see how it effects the first and second gear feel. For me that is the most important thing. Thanks Derek
As in Ohm readings? No not really. Since I used the calibration feature of the MeterMatch as opposed to the pre configured method there isn't any way to know for sure.
So I finally had the right combination of events to where I ended up with 1/4 tank and the time to drain and measure. I used a 5 gallon gas jug and it was so close to 4 gallons that I'm calling it a winner. The needle does start to swing a bit down around 1/4 tank and I did have one scare. I was about 30 min from the shop and I was hovering around 1/4. I pulled up to a light that was on a bit of an incline and the needle bounced down to E for long enough for me to convince myself I was running out of fuel. I wasn't but without knowing for sure I threw in a few gallons. It is way better than it was before and I'll probably run it down to 1/8th and see where I'm at. As long as I can count on it to between 1/4 and 1/8th then I'm golden since that is usually as low as I run it.
Yes but the owner of Technoversion drives a 240 so there is that to consider:) Went for about a 45 min drive today. Gage went down as expected and was rock steady the whole time. I do want to reiterate that I change my sender wire and installed the MM at the same time. I would do that first since old wire and connections are not a great combo for dependable ohm eadings
Yes. I did the coarse setting with the MM and then refined it with the gauge. Yes. The needle moved slowly which gave me some hope. I then installed the sender and added gas at a known amount and checked the gauge to verify. It was very accurate without any other tweaking but I wanted to get it dialed in at the 3/4 mark since that is probably pretty close to the point where the tank narrows. The drive home went well and the needle was more stable than it has ever been. The real proof will be when it get's down a little past half. that is when I really noticed the massive swings. The needle would literally go from half a tank to empty.
I just posted this in Electrical but here it is as well. Speedhut fuel gauge and MeterMatch Like a lot of others I’ve had issues with the Speedhut fuel gauge playing nicely with the stock fuel tank sender. I would get wild swings and was never really sure how much fuel I had. After some discussions on the Speedhut group buy thread I decided to get a MeterMatch from Technoversions. It basically takes the ohm readings from the sender and converts them to a more stable range for the gauge. So here is how I attacked this. I tried to install it without pulling the sender and it was just not working. And during the course of this I was getting some erroneous readings from the sender. So I drained the tank all the way and pulled the sender. I brought the sender into the car so I could manually move it to see what was going on. I set the fuel gauge back to default of 240 empty and 33 full. I then used the MeterMatch to set full and empty calibration. To calibrate you used up and down buttons to move the gauge needle and then save it when you get it where you want it. I had a really hard time since a single button push moved the needle almost a 1/4 tank. I ended up getting it close with MM and then doing a final calibration with the gauge. This worked really well. I reinstalled the sending unit and rewired it with a new good ground and a dedicated sender wire straight to the MM. I have a 16 gal tank. I put in 2 gallons and the meter read 1/8 and was stable. So far so good. I put in two more and it was a little above 1/4. Still good but I wanted to try the lower mid point calibration. As before the button presses moved the needle a ton. But I noticed the needle wasn’t stopping at the same place. I found I could walk the needle around by different combinations. I went to the gas station and put in four more gallons and the gauge read 1/2. Four more and I was a little above 3/4. Went for a drive and the needle was really steady compared to what I had before. Let’s face it a lever arm sender is going to have a lot of movement and if the gauge isn’t designed for that sender then it’s only going to be so good. So I got back to the shop and contacted Brian at Technoversions with questions about the up down calibration. Here is his reply: With regard to the MeterMatch, what you are seeing with the up/down resolution is on purpose. Most gauges use a fair amount of current, so if we made the buttons work at full resolution, you could be pressing one of the up/down buttons a thousand times to go from end to end. So we make the buttons move the amount in larger increments. But to make the points in-between accessible, we make the increments between up and down slightly different, so that all values can be selected. This is hardly noticeable on most gauges, but on some electronic gauges, such as the one you have, much less current is necessary so you are working within a small range of values, so the resolution appears to be much coarser. But you should be able to get there. So you can hit a specific target with the right combo but I will tell you it is a challenge. You can get the needle where you want it and after you take it out of program mode it changes. I set the upper mid point calibration the best I could considering the heat index in Florida right now and may revisit it in the future. From 3/4 tank and up I don’t care if it is accurate and truth be told as long as I can count on 1/4 tank being stable and accurate I’ll be happy. So to sum up. I would run a separate dedicated ground and signal wire first since in all reality that may have been the bulk of my issues. I already had the MM so I used it. If That doesn’t work for you then: Purchase MM from Technoversions Set the fuel gauge to default ohms since that is where it was designed to work. Use the MM calibration to get the needle to full and empty as best you can. I wouldn’t get too crazy with the button pushes since you are going to set the final calibration with the gauge. Recalibrate the Speedhut fuel gauge. Install the sender and use known amounts of fuel to check calibration. I plan on draining the tank when it reads 1/4 and if I have 4 gallons then I’m golden. I’ll update this thread after I drive it a bit as well.
I just pulled trigger on the Techoversions unit. I will report back as to the results.
This part from the instructions got my attention. That is exactly the issue I'm having. The slightest movement on the sender makes the gauge swing. This is also interesting as well. I have a lot of electrical items and I'm sure the voltage swings quite a bit depending on conditions. Not sure if this bothers Speed Hut gauges.
Just a heads up. Techo versions the company that offers the Ron Tyler mount also offers/makes the meter match. The more I read about it the more I think that is probably what we are looking for.
I did as well so I put in a brand new sender. I think it made it worse:) That would be great. I'm going to check the connections to the sender this morning and make sure nothing is loose.
Just got back from a drive and the gauge was swinging form 3/4 to empty at what seemed to be random intervals. I got nervous and fueled up and it only took 4 gallons. I read somewhere that the the voltage to the gauge can effect the reading but not sure if that is valid. Any thoughts on this unit? https://www.tanksinc.com/index.cfm/page/ptype=product/product_id=473/category_id=167/mode=prod/prd473.htm Pricy but if it will solve my problems then I'm willing to go that direction. They also have this: https://www.tanksinc.com/index.cfm/page/ptype=product/product_id=748/category_id=167/mode=prod/prd748.htm That is probably a very accurate assessment
New Techno Toy Tuning Micro Rear Brake kit
Derek replied to Miles's topic in Brakes, Wheels, Suspension and Chassis
I think when it comes to safety and when using a mis mash of parts documentation is important. If they are two ways for an item to be mounted but only one works then that requires documentation. -
After the hassle I had with the kit from Zcar depot's Ebrake function I wouldn't buy it without detailed instructions and pictures of it installed. So much of this stuff is not much more than a collection of parts that require a lot more work on the users end than they let on to. To sell a brake kit without detailed downloadable instructions is almost criminal in my mind. -
The gauges themselves are great as far as I'm concerned and I would search specifically for this ohm problem with any other set you look at.
+1 for this. I'm currently in therapy because of range anxiety. Looks like I have half a tank, great, looks down again, Empty???
Great job. You are right it looks like it was originally that way.
Mine is the one in the speedo. There is an old post by KTM where he had the same issues and I'm almost positive that is the stand alone gauge.
Mine is the same. It wings wildly when it gets to about half tank. I'm not an electrical guru but I imagine the ohm range on the Nissan sender is too narrow so a little movement on the arm results in a lot of action on the gauge. I have a brand new sender and it's no better than the original one.
Has anyone figured out how to get their fuel gauge to read properly?
Looks great. Right before I did my twin cam head I was looking into getting another Z and making it electric. Unfortunately the double whammy of the price of Z cars going through the roof and the cost of developing a cylinder head blew that dream out of the water. I'll live vicariously through your build:) I think we need to think of ourselves as "propulsion heads" rather than "petrol heads" at some point since electric propulsion isn't going away. And that instant torque is pretty appealing. Thanks for posting. Derek
I have the 3.9 in mine with Datsunrestomods axles. I have driven it with both the stock 4 speed and the FS5W71C from Godzilla Raceworks. My build is not kicking a ton of HP since it is 2.818L and the CR is only around 9.5:1. There is a noticeable difference between first and second gear between the two. The 4 speed has a much better snap to it and is a lot more fun to drive. The FS5W71C is way better on the highway. I have a 3.2L that I'm slowly getting together and feel that the extra HP and torque will more than makeup for the lack of gearing. Ultimately after doing a ton of calculating with ratio calculators the CD009 with the 3.9 would be the best choice for my style of driving. That is a hill that is too high a climb for me at the moment. My gut feeling is if most of your driving is around town I would go with the 3.9. Beware that used Subaru r180's can be a crap shoot. I bought mine from a reputable seller on ebay that supposedly had 36K miles on it and it howls at 50mph. And unfortunately 50 is my in town cruise speed so it's pretty crappy. They are getting really popular and the prices are no longer what I would consider cheap. If I had to do it again I'm not sure that would be the direction I would go. I paid someone who has done quite a few Datsun R180 diffs to try and get the wipe pattern dialed in and the Suretrac carrier gave him a ton of trouble trying to get it out of the diff housing. The long and the short of it is I'm at $1200.00 for a diff that is noisy so make sure you choose wisely. When they were $350.00 it was worth taking a chance. At $700-900 not so much.
- 5 replies
- drivetrain
- r180
(and 2 more)
Tagged with:
Rear disk kit from Zcar Depot Anyone using it.
Derek replied to Derek's topic in Brakes, Wheels, Suspension and Chassis
Possibly. I'm going to try shortening the cable first since I have the equipment. I may end up designing and fabbing new cable holder brackets at some point. I have 15" wheels so that limited my kit choices a little bit. -
So I ended up re cabling my old set. I think some of the problem is with the brackets they sell you end up using a lot of the effective travel of the mechanism by the time you get all the slack out. I ended up making the cables a little too long and I'm still using up too much adjustment. It's better but there is no way the brake would slow and stop the car in any kind of emergency. Maybe with every bit of the throw available it would but I'm still not sure. I think the travel on the caliper lever is longer than the available travel on the lever. -
I could hear the relief and excitement in your voice. My prototype head fired right off and it is quite the shock. I almost didn't know what to do next because I wasn't expecting it. Great work. And it sounds really good. You must be one happy camper.
