Darrel
Everything posted by Darrel
  1. 2500lbs---'73 240z, 2.8, full tank of gas, spare, stock trim. 3060lbs---'82 280zx turbo, 4 spd auto, full tank of gas, stock trim. cars only, no driver.
  2. How about renting one the the bins like you were going to, then tell her it's a new storage bin.
  3. http://www.qv500.com/detomasomangustap1.php
  4. If you download it to your gallery here it will automatically resize it. Or use photobucket.
  5. she's gonna get such a rash.
  6. Get the drill doctor. http://www.genext.drilldoctor.com/ You can also find them on ebay brand new.
  7. Darrel
    ZXT halfshafts
    direct bolt in/snap in it's the 280zx and not the zxt.
  8. how long did it take you? $65 new spindle pins + time $70 spindle pin tool and reuse spindle pins + 1/2 hr pulling both out.
  9. Darrel
    pinks2??
    Does this mean the first pinks was a success?
  10. Check in your area for commercial hollow metal door and frame places. They will have a lot of door cut outs and door frame cut offs in a steel bin ready to go to scrap. The frame material is usually 16g, the door cut outs are usually 18g.
  11. thunderZ took this one while they were leaving Putnam racetrack http://putfile.com/pic.php?pic=5/13016090617.jpg&s=f5
  12. try lowes for the round one. They carry a variety of plugs.
  13. Just recap what went on at the bachelor party. my brother is still pissed at me for that.
  14. What is wrong with the driveshaft that you have gone thru 2? I used my 73 driveshaft in my 240 with the lsd and finned cover.
  15. If you're using new seal, just cut the old one out, leaving the glass sitting there. Keep the metal trim for the new seal. That keep the corners straight for the glass. Your choice on installing after paint, do it yourself or have the professionals do it.
  16. Darrel
    new here
    The first thing you want to do is check the body over for rust and what it will take to fix that. It is a MN car afterall. Then you can start doing something with the engine.
  17. When I did mine, I knew i was going to have new exhaust. I made sure the driveline angle was correct (although I'm not convinced of that now). Then I had the exhaust done in 3". When you get it done, I'm sure your wife will love it.
  18. Ya just gotta build a better mouse trap dontcha? When I went to Utah to pick up my transmission from Twheel, I checked out how he did his swap. About the only thing I made different were the brackets. Everything else was pretty much the same. What did it look like with the other cross members? With the orignal cross members they do turn up to allow for the exhaust.
  19. The zx tunnel isn't as flat as you think it is. Go ahead and make the brackets with 2x3 square channel with one side cut out. Use which ever crossmember, straight or curved that will match closer to the tunnel. You can always shim it out. For the interior you will have matching plates to thru bolt to. The straight or curved brace is proably about the best bet to use. The joys of modification.
  20. It looks like the 260 and 280 kits are the same according to the energy suspension parts catalog. http://www.suspension.com/nissancars.htm
  21. Do the front calipers have the bleed screws at the top?
