str8pipez
Everything posted by str8pipez
  1. I believe no resistors are needed if you use Pulse Width Modulation in MS2. The MegaManual has a section on injectors and this is covered. http://www.diyautotune.com/faq/megasquirt_efi_ecu_options_diy_details.htm
  2. There is so much on that site it's crazy. Even a tutorial on flush fit windshields. Builders NEVER give out details like this.
  3. http://www.jefflilly.com/fabrication/index.html#
  4. I have 16x8 klutch SL1 that are +15, and I will be adding 5mm spacers. +9 would have been perfect for me. 215/50-16 tires btw.
  5. I think I'm going to give South Bend a shot. What the hell, it's only time and money!
  6. Looks like the S30 and S130, including the turbos use the same flywheel so the dual pattern must be on all. Looks like a 240 clutch it is.
  7. Hmmm, interesting. I'll have to research to see if mine is. Thanks!
  8. I'm keeping the 225mm flywheel as I bought it before I had the wise idea to add a turbo...
  9. Turboing my N/A S30 and need to upgrade the clutch while swapping in a 5 speed. I have a Fidanza lightweight flywheel now. Trying to decide between the Spec Stage 3, or Centerforce 2. Any thoughts?
  10. Many of you may have seen this already but for those that have not, this guy is awesome.
  11. I believe the "WTF" is a shunt? Maybe wrong. The rest of the stuff is relays. Check the FSM under Body Electrical. Also the VR may be still connected because that alternator also uses the external VR like the stock alternator.
  12. I just upgraded to a GM alt. and while searching for a place to mount my MS relay board I can across these 2 dudes attached to the bracket that the ext. voltage reg. was bolted to. Anyone know what they do? I went through the FSM but no luck.
  13. They may be to big for the makerbots. That bumper delete measures 16" long. I think a maker bot is 12".
  14. maybe I'll buy this and make my own! http://markforged.com/
  15. I asked 7 Tune about those parts and got the following: Hi, This is Shin from 7Tune. I have got your email via FW: from Star Road. I also sent us an email couple weeks back?? I'm really sorry for delay. That circled part in the picture is still in the process of development. It should be out for sale soon but it might be a sold as kit with the front grille. Best regards, Shin. 7tune. Shin Sudo Sales and Export Manager www.7tune.com - "The Ultimate JDM Experience" E-mail - shin@7tune.com Phone (Mobile) - +81-80-1100-8008
  16. Sell the module and plug only? Really want to do the Chrysler coil or possibly COP.
  17. Per the title. Don't need the sensor, mount or wheel. I'll also take chrysler coil pack and plug wires.
