Hey Lee, this is a little off topic, but I did some research for you.
So you'll end up using the Turbo stuff from the DET motor (Turbo/manifold, crossover pipe that has the factory blow off valve), there are provisions for the oil drain, feed, and coolant hoses, but they are either blocked off, or need to be drilled and tapped (i've read that some blocks have it capped off, and some need to be drilled and tapped for it).
You'll need also need the ECU and MAF sensor (the injectors are the same size). So it's virtually plug and play. There's no wiring involved, you just unplug the stock ECU, and MAF, and replaced with the turbo versions. So everything you do is actually on the mechanical side of it all. You're compression is a bit higher (I've read two separate sources saying 9.5, and 10:1), but everyone seems to agree that you can run that same setup on 6-8 PSI, on the stock intercooler, and people say as high as 10-11 with a good fuel pump, and front mount intercooler.
CX Racing makes a really nice intercooler, and I can source a Walbro 255 fuel pump.
