Leon
    25
Everything posted by Leon
  1. Seems like shipping is probably going to be killer on these things, so if there are any locals on the SF peninsula or Bay Area, I would really prefer that. Thanks guys.
  2. I'm looking for a '74-'78 (260Z or 280Z) center console with the radio mounts intact as I'd like to keep the stock radio. Please, no beat up and cracked consoles. Minor damage may be okay, just let me know what condition it's in. Pictures would be great!
  3. Care to explain your math? I calculate about 200lb at 70mph from Tony's numbers.
  4. Leon
    40dcoe
    Interesting. You'll just have to be on the lookout for good used ones on craigslist, ebay, our classifieds, etc. Good luck.
  5. Leon
    40dcoe
    I'm sure Pierce Manifolds either has them or can get them.
  6. Take a look at your own quote, it says nothing about being exempt from Smog requirements, just the biannual smog check. I'm not sure whether you've read the whole thread, here is what ray mentioned earlier:
  7. That's not true at all, especially with turbocharged cars.
  8. That is the way that I installed mine as well.
  9. I'll cover another question. I've never used MS but I'm pretty sure you can run a speed-density setup with enrichment coming based on dmap/dt, someone correct me if this can't be done. This eliminates the need for a throttle position switch whether you're running open or closed loop. A TPS is really only required if you plan to run TPS-based acceleration enrichments and/or you plan to run the fuel map based on alpha-N instead of speed-density.
  10. Calculate out the total steering ratio (factoring in steering arms) and you should have a valid comparison between the two options. I have not done this but it should be simple enough to do; the overall steering ratio is # turns at steering wheel/# turns at wheel. One turn of the steering wheel translates to a set amount of motion at the tie-rod ends, which would give a certain angle of rotation at the road wheel. All you need to know to do this is the steering rack transfer function and steering arm length. EDIT: If you choose to switch racks, be aware that the 240Z and 280Z rack bushings are different.
  11. I have a recent post on the topic, maybe it can be of some help.
  12. Modern turbos have very little turbo lag, it's essentially unnoticeable. You may be thinking of boost threshold, and what ovenfood brings up is a good point; what about cam threshold? It take time for an NA engine to "get on the cam." As far as the blow-off valve sound, I'm not sure if you fully understand how turbocharged engines work. A "blow-off" valve should not be vented to atmosphere, but instead should be used as a recirculation valve on throttle drop in order to prevent surge and keep the compressor wheel spinning, in a nutshell. Incorrect, and a terrible generalization: "a larger engine will always be able to make more power than a smaller engine." Like I said in my first post, forced induction is the replacement for displacement. Use the ideal gas law as a model for the air entering the engine during one engine cycle; PV = nRT. P is pressure, V is volume, n is # of moles, R is the universal gas constant, and T is temperature. (1) Solve for V (volume); V = nRT/P. Note that density is mass per unit volume; rho = m/V. (2) Therefore, V = m/rho. (3) Substituting for V in the ideal gas law; m/rho = nRT/P. (4) Solve for density (rho) with m/n=M; rho = MP/RT. Therefore, with M and R being constant and holding temperature constant, doubling intake pressure doubles intake density. (5) Look back at the density equation (2) and double the density, so V = m/2rho. (6) Put the right side of the equation back into the form of (2) and you get 2V = m/rho. This means that when you turbocharge an engine, you are effectively increasing displaced volume. Double the intake pressure and you effectively double displacement, e.g. take a 2L engine and put in 14psi of boost and you now have an effective engine displacement of 4L. I do enjoy letting the nerd out once in a while... When we talk about two turbocharged engines, the comparison remains the same, increasing intake pressure increases effective displacement. So you can say that theoretically, "a larger engine with running the same amount of boost as a smaller engine will almost always be able to make more power" but where does that really get you? Can't you just slightly increase the boost on the smaller engine and get to where the slightly larger one is? Using the 3.1L vs. 2.8L comparison, and let's say that the 3.1L runs 10psi of boost. In order for the 2.8L turbo to match the 3.1L at 10psi, it would have to run 11psi. The performance difference is essentially negligible as there are other factors in ultimately making power and going faster besides the amount of "boost." For example, the 2.8L can spin faster than the 3.1L, holding everything else constant (lower mean piston speed at equal engine speeds). Will that alone make up for the discrepancy, I don't know and I don't feel like doing the calculations to possibly find that out. The price difference, however, is not negligible. I'll take the 2.8 turbo over the 3.1 turbo, thankyouverymuch! My 2 cents.
  13. There is a replacement for displacement and it's called forced induction. I would have a very hard time justifying 3.1L vs. 2.8L if both are to be turbocharged.
  14. You already have the 3.9 diff as well so add a lighter flywheel and you're good to go. The car should feel and go pretty quickly with an otherwise stock setup.
  15. You'll get much more bang for the buck out of a numerically higher diff ratio, lighter flywheel and bigger exhaust than trying to cobble bits together that will degrade performance unless more thought and money is put in.
  16. And filthy with a combination of rust and penetrant!
  17. Bingo. Higher altitude makes for less cylinder filling, which means less cylinder pressure (and temperature) therefore reducing the tendency to knock.
  18. I'll try to break this down, it's getting late. There's always a happy medium or compromise, and in this situation it's fuel mixture homogeneity vs. pumping losses. At some point, one overwhelms the other and you get diminishing returns in mixture uniformity while further increasing head losses. The injectors do atomize fuel better initially due to a much greater deltaP than carbs, but the location of the injectors matters as well. If they're far away from the valve then you still need to rely on the intake to mix the air and fuel properly. I would tend to agree that in general, carbs need more help in getting the mixture uniform when compared to EFI. Yes, take diesel engines as an example, they're all direct injection. Even though air is all that flows through the intake, it is still beneficial and actually more important to impart spinning/twisting forces pre-combustion chamber in order for the mixture in the cylinder to be better distributed. You don't want the incoming air charge to be shot straight into the cylinder with some air getting a bunch of fuel and the rest getting too little. You want it spinning and swirling turbulently as the fuel injector does its work. Port design is much more at play here, with intake design taking a back seat here. However, in order to change the angular momentum of the incoming air you do sacrifice volumetric efficiency through pumping losses. This is more evident at high rpm where higher flows mean higher head losses. Also with the air charge coming in at a higher momentum at high rpm there is less of a need for swirl and tumble to get the job done. For more info, you can look up the terms swirl and tumble as they pertain to IC engines. More time for the air and fuel to mix is good, but heating your intake charge is a double-edged sword; it benefits fuel atomization while being detrimental to volumetric efficiency (air temp goes up, density goes down). As rpm increases heat transfer effects decrease, so ITBs with injectors far from the valve will have better atomization and mixture distribution at high rpm with the sacrifice of low rpm efficiency. The magnitude of the sacrifice would have to be empirically quantified on a dyno, where the same engine would be tested with different injector locations. Injector placement is an oft-overlooked but important piece of the puzzle, finding the "sweet spot" takes testing. The main reason for having staged injectors is when using larger injectors that cannot adequately and precisely control the smaller pulse-widths required at idle. I suppose there are some secondary mixing effects from this, but I would consider it negligible for all but the most detailed builds. One injector per cylinder placed correctly should be able to deliver a good, well-distributed mixture given that the demanded pulse-width doesn't go outside the injector's realm of predictable operation throughout the engine's speed range. Hope that made some sense. You're getting caught up in describing flow as laminar or turbulent when it doesn't really matter as you won't get laminar flow from an engine anyway. You get high speed pulses tossed in the exhaust which would never come close to being laminar flow. Your last sentence sums it up pretty well, but laminar or turbulent is the least of your worries even in the scavenging portion. There are greater effects to take advantage of than trying to hit an unattainable and unnecessary goal of achieving laminar flow in your exhaust, or intake for that matter.
  19. We should have some jackets made with "Spindle Pin Club" and your skull and cross-pins on the back!
  20. Laminar flow has been thrown about a bit in this discussion. If you calculate out the Reynolds Number from the flow in the intake tract, I doubt you could ever get laminar flow, unless the tract is very smooth and large in diameter. Therein lies your contradiction, you want to have laminar flow yet you want velocity relatively high. These are conflicting goals. By the way, a large port is not detrimental either as long as you match the intake geometry accordingly. Turbulent flow is not necessarily bad and laminar flow is not necessarily good, at least in the case of internal combustion engines. The turbulent flow in the intake is beneficial to mixture homogeneity which is in turn important in maintaining consistent and more complete combustion. Mandrel bends in the exhaust have nothing to do with laminar flow and everything to do with minimizing pumping losses by having a bend of consistent radius and diameter. A crush bent radius will have a smaller effective diameter than the rest of the straight piping which would increase frictional losses in that bend. My 2 cents...
  21. Turns out that I definitely misread direct ignition control as direct injection control when I was reading over the TEC3 stuff!
  22. The swap is definitely for someone that knows what they're doing. I think one of Electromotive's TEC systems handles DI as well, as do other fairly expensive standalones. The Audi V8 is a great suggestion, those are nice engines and it would definitely be a more do-able swap. You've got me thinking now. Just need to figure out a manual transmission that would work with the engine, as I'm not very familiar with Audis. I did have an '89 100 however, it was an interesting car.
  23. As an aside, those of you who have drastically altered combustion chamber shape have to keep in mind that MBT (max best torque) timing will change. I'm sure if one has spent the money for head altering that dyno time will be in order, so remember that a faster burning chamber will require less timing advance to get best performance.
