25
Everything posted by Leon
Sounds like I really need to invest in an air compressor!
You just broke physics!
A few that come to mind: California, Scaglietti, 456 GT, 412, Mondial, 365 GT, 330 America, etcetera... The GT6 is a great design, but I'd consider it more of a hatch/fastback. This should get you started.
There have been plenty 4-seat Ferraris before this one, albeit no Ferrari shooting brakes since the '70s. I agree that it doesn't quite fit with Ferrari's modern image, but on its own it's a good looking car in my eyes. Again, I'm a big fan of wagons, hatchbacks and shooting brakes. Speaking of shooting brakes, there have been some great designs in the past including some of my favorites: BMW M-Coupe Volvo P1800ES MGB GT
Just checked and the '07 RS4 engine does have direct injection, in which case you can run a standalone ECU, it will just be more expensive. I think an aftermarket ECU is still the way to go here, as Douglas points out, if you decide to tackle this one.
Voice your concerns to the guy and get the price dropped down. If you can grab that engine for $1k or so then why not. If the guy doesn't want to budge then let the car sit there until he's tired of looking at it and try again. If he's any sort of car guy, I'm sure he'd rather see the engine put to use instead of getting crushed. I don't know if that engine has direct injection, if not, then why not go with a standalone ECU and your own wiring harness. It will likely be cheaper and easier than adapting the Audi ECU to run the engine in another car. Two R8s? It's not like he needs the money. Good luck!
It looks great! I love the "shooting brake" styling and didn't expect Ferrari to come out with something like this. I'm not a big fan of the headlights and front end, but it's a minor gripe. Although I really like the M-Coupe as well, so I'm a bit biased to the styling. Honestly, in the end I'd prefer the M-Coupe to the overpriced, overly-luxo Ferrari any day, unless someone wants to let me drive the Ferrari.
So everything is stock, except the MN47 head and flat-tops? Good luck running pump gas with that setup, as your compression is definitely over 10:1 and probably getting close to 11:1. Since you are running a stock cam, you will definitely detonate unless you swap out to a longer duration cam that can bleed off cylinder pressure at low speeds. IMO, it's worthless to go with flat-tops and an MN47 without doing anything else. You'll see minimal gains and you'll have to run race gas. So your choice is to either run race gas and hope that the stock ECU handles this combo (which it probably will given that your cam is stock) or swap out cams to get more performance out of it and maybe run pump gas. However, the latter will require custom fuel management. Or, you can always go with the easier and more economic choice, forget the MN47 and put on a P79/P90 head. You'd have a late-ZX engine which will run on pump gas and the stock ECU.
Especially with the stock cam. This is a situation where we need as much info as possible to make any judgment. If it's an overbore with everything else stock then the stock ECU handles it just fine. If you have an MN47 with flat-tops and a 290 degree cam then you really want a standalone ECU.
Attaboy! 98 pins? I am not envious. Hearing protection is key, but it makes it harder to judge the volume of foul words coming from my mouth into the neighborhood. It protects my ears, but not my neighbors!
The puller definitely helps, but if you have the will it can probably be done by sheer brute force. Blue's method worked well, pounding one side and then the other slowly moving the pin one way and then the other. Eventually, they slide out, and by eventually I likely mean hours of torture! Use heat, a lot of heat.
I've used rubbing alcohol and paper towels with great success.
Ouch, at least you got the best of them eventually! I was able to separate the puller and pin by putting the pin in a vice and using a pipe wrench on the all-thread. We should start a support group for those who've pulled spindle pins, and have SPTSD (Spindle Pin Traumatic Stress Disorder). We can have therapy sessions and counseling.
Mmmmm, high-revving German V8, I'd love to see that swap work out!
Well, the first time I used the puller, I didn't use enough heat. The all thread snapped at the nut end, toward the end of the inner threaded section, a stress riser. John said that the center section has to be heated enough for the bushings to essentially melt after I talked to him about it. I used the puller yesterday, but I got a little mixed up on the first pin. Since I am re-using the old, shorter all-thread and have a new one, I have two lengths of pipe to work with (the pipe that slides over the all-thread). I forgot to put the coupler on the first pipe that butts against the control arm and had it sink into the bushing. That's why the first pin came out mushroomed on both ends. When I went to do the second pin I saw the pipe coupler on my other pipe. "D'oh!" The puller worked well on the second pin and got the pin out using copious amounts of MAP gas and some tapping on the other end. I'm glad to finally put the pins to rest.
It was the murder weapon. Luck is the magic word! I don't have a compressor, or that much patience. I thought so too, until I got this 260Z and spring/shock replacement turned into a full rebuild. Diagnosis? While-I'm-at-it syndrome.
I'm rebuilding the suspension on my early 260Z and it came time to do those, oh so fun, spindle pins. I had taken the pins out once before, in my first 240Z and have blocked the majority of that out of my memory. I felt sprightly and masochistic today so I decided to tackle my second set of pins. By the way, this is a wonderful idea for a day-off activity. The painful process started this morning, around 11am or so, and finished around 6pm. I had technically started on the pins weeks earlier, but did not have the patience to do much. The mayhem started with John's pin puller but crept into whack-a-mole mode as the day wore on. Instead of boring you all with more details I took a video. I did eventually get both out. Never thought I could hate a piece of metal so much.
The search function is your friend: http://forums.hybridz.org/index.php/topic/97567-help-can-you-identify-this-front-end/
Tony makes complete sense. In SF, some crosswalks have the timers and I alter my driving pattern depending on how much time I have. If I see that there's no way I can make it, I coast up to the intersection in gear, saving gas. It really does take the uncertainty out of intersections and it saves on gas and brake linings. The core of the problem lies in stupid, inattentive drivers. But that's for another thread and forum altogether...
If your round tops are worn around the throttle shafts, that will create a vacuum leak. This will cause to car to run lean at cruise unless you richen it up. Since the round-top SUs don't have a dedicated idle circuit, you will richen the mixture across the entire band. Just another possibility.
Sounds like you're running too rich and possibly have an exhaust leak. You may have a crack somewhere in the piping or a mating surface is warped. An easy, although not necessarily conclusive, test you can do is stick your hand down by the exhaust manifold (don't touch it!) and see if you can feel exhaust pulses. A leak will also be noisy depending on how much it's leaking.
Allowable %EGR and how lean you can run an engine depends a lot on combustion chamber design. The more efficient the combustion chamber (faster burning), the more EGR an engine will take before it becomes detrimental to performance (tip in hesitation, misfire, etc.).
Injecting EGR into the combustion chamber will dilute the mixture and increase burn time. Saying that you can run more advance is a bit misleading, because it leads people to infer that they will then gain power. You have to run more advance with EGR than without in order to keep max cylinder pressure vs. crank angle the same.
Almost anything looks complicated in exploded view. SUs are very simple carbs with only a few moving parts. Get the SU video from ZTherapy and you'll be just fine. SU carb:
The BE section of the FSM is critical to gaining a good understanding of the 260Z, believe me. Print out the wiring diagram and some associated illustrations from the FSM and have at it!
