Leon
    25
Everything posted by Leon
  1. Good call jhm! Looks like it's a TVR 2500M: Looks like it's an early '70s TVR body with TR6 drivetrain.
  2. BMW Z3? It's probably 30 or so years older than the earliest Z3, very likely a '60s era British sports car. My first thought was Lotus Elan but that doesn't quite fit the bill. You have me curious now, looks like some searching is in order...
  3. Well there's your problem... Take this as a lesson learned and move on, and at least this lesson is a relatively cheap one.
  4. Braden's book has some rough sizing guides. You'll likely find similar stuff online. When I have my book on hand, I'll try to dig up some equations for you. But before I do, you must get me... a shrubbery. Here's something you can find from a quick google search: http://cnx.org/content/m37431/latest/
  5. The procedure to check timing is the same whether it's a Datsun, Volkswagen, Ford or Volga. Newzed makes a great point: buy a general automotive repair book and self-educate.
  6. Sounds like stivva's Z but I think he changed his paint scheme since then. Here you go: http://forums.hybridz.org/index.php/topic/87272-post-pics-of-your-zs-here/page__st__320
  7. Thanks! It's funny how we've taken a similar path with our cars as well! Since I have the 240Z sitting on stands, I've been thinking of what to do with it. LSx? Maybe... The plates were there when I got the car. They block off the bumper shock holes as you've said, purely cosmetic.
  8. Or you can put in 6 EGT sensors and get a 6 actual numbers that can be data-logged instead of a purely visual and subjective reading. It would presumably be cheaper than 6 colortunes and 6 cameras as well.
  9. It would not be wise to remove the booster from a system designed for power brakes. Your pedal ratio will be too low, and there will be a considerable increase in pedal effort. This is dangerous. You don't like pedal travel in your brakes? Would you rather have almost zero pedal travel?
  10. Jetting your carbs takes experimentation and will be tough without a dyno or at least a wideband 02 sensor. As I said, there are books on this, e.g. Braden's book, that have some rough guidelines for setting up your carbs. You can try to order a few different sizes to try to match them up to your engine. The carburetors function the same, whether it's an L20 or L28. Read the sticky!
  11. Oh no! Get rid of those Mustangs immediately! I had an '83 5.0 and will never, EVER touch one again...
  12. There are vendors in the US, if you want it shipped out to Japan. Off the top of my head, there is Pierce Manifolds, Redline, Weber Jets, etc... Once you start tuning, search this board and elsewhere online. There is a sticky in the FAQ section as well. There are also books to aid you in the process.
  13. Great article! Thanks for posting, John.
  14. Nice job, reminds me of a straight-pipe 935!
  15. Do you have photos? Wheel diameter?
  16. That 280Z has been on CL before. I'm not sure how set they are on actually crushing it...
  17. I have a lead on a wheel, so if anyone has one then speak up! I'll very likely be on the lookout for a Momo hub as well, let me know if you're willing to part with one in good shape.
  18. I've considered it. Wish I had the space!
  19. I'm looking for a Momo steering wheel (some other brands may work) with the following specs: - leather rim (i.e. no cheap-o vinyl) - silver spokes - 350mm (~13.5") to 360mm (~14") - in good shape, with no tears or nasty blemishes I really like Dave's wheel, so something similar would be great: I've been keeping an eye out on CL and ebay but figured it's worth it to see if someone here has one laying around. Thanks!
  20. I'm slated to go on the dyno August 20th and will test a few exhaust configurations on my L24 with triple Webers and stock exhaust manifold. I'll report the results when I have them!
  21. I'm a mechanical engineer (Cal Poly SLO), currently in injection molding manufacturing. Automotive engineering is on the side for now!
  22. I would grab this one if I didn't already have a Clifford. It's a nice header, have a shop build you some twice pipes imitating the original Datsun Comp setup and you're set! Obviously, this is not my header.
