Everything posted by Dat260Z
I have em. Need to be blasted and rebuilt. They are rusty. $20 +shipping
i have a short block here in GA you can have for $100. came from a running carb'd z.. pulled it out for turbo swap
Box of SDS stuff is on the way ! look forward to seeing the finished product!
subscribed here and on FB!
Those were before rebuilding/powdercoating . I now have front and rear z32's ready to be mounted. Here is a breakdown of what I have invested : Front bracket $175 Front rotors:$125 Rear brackets:$150 Rear rotors:$110 Front z32 aluminum 30mm calipers $250 Rear aluminum z32 calipers :junkyard find for $35 for the pair Z1 motorsports caliper rebuild kit: all 4 corners :$50 (do not buy) Stainless braided lines with banjo fittings $125 Brake pads $100 Powdercoat $45 A good amount of time braking down , sandblasting, powdercoating , rebuilding calipers )And I got some sweet decals made to stick on the raised NISSAN lettering..probably wont stay on very long but they are pretty. I will throw so,e high temp paint on the letters if the decals come off.
i have one that is shortened 1" .. off of a 83' Turbo car
Is there anyone who has mounted GM IAC on 280z intake manifold
Dat260Z replied to Meguiars's topic in Nissan L6 Forum
I have a Bosch IAC on my TB spacer. Contact Pallnet , he can make you a spacer with provision for sensor. Ill be running SDS EMS -
I have a mini MOMO wheel 10" diameter ...definitely need the small wheel with my stationary sparcos!
Brake Stainless Lines on Sectioned Struts
Dat260Z replied to 280zzzzz's topic in Brakes, Wheels, Suspension and Chassis
What Koni inserts are you running ? 86411220 sport? Have any issues with fitment in the 280 strut tube. -
R-200 Limited/slip Differential for some specific parts
Dat260Z replied to zentech's topic in Parts Wanted
I have a set of wheels and a low miles p90a head. PM if interested -
I have a MS relay board for sale. Pm for more info
This kit is no longer being sold. TTT is prob the best bet for the $
I might be interested in a pair if fritt doesn't want both sets.
OKAYYYYYY! So i got around to working on the dash this week and here is what ive done so far. I Vee'd out the cracked areas. decided to peel off all of the OEM dash plastic that covers the foam. Picked up some 3M Panel Bond. This stuff is SUPER strong ! and its expensive, $45 per tube, and it uses a special gun to push it out of the tube. it comes with a mixure tip, it mixes the hardener with the epoxy itself. I bought 2 tubes, i hope that is going to be enough. I applied the first coat of panel bond. This is mainly to fill in all of the cracks in the dash. It needs to sit overnight to cure so I will smooth it out tomorrow with 40 grit sandpaper and apply the 2nd tube over the entire dash similar to a glaze. This is to seal off the foam. The reason I pulled the dash in the first place was to remove the heat-AC components and weld up all of the holes on the firewall, so here is a before pic of both sides.
This is what I found under the dash cap! Long road ahead ..I think I will be repairing this..keyword..think
Hey Guys! I have a late 74' 260z that I am working on at the moment. I am in process of cleaning out the engine bay for paint and i decided to pull the dash so i can get rid of all of the ac/heat components , possibly some new guages (or clean up the stockies and replace bulbs with LED's) and mainly to weld up all of the holes on the firewall. I figured i would post my progress and share my experiences along the way. Any input is appriciated! First i pulled the seats: I really need to get some new covers or get these dyed back black. I have had these in my car for a couple of years as a daily and the southern sun really takes its toll on the black! They are also a bit wide for a s30 z, just in case anyone was wandering. I had to bang in the trans tunnel a bit so the shoulder wings wouldnt slam up against the door panel..they still rub a bit on the door panel/lock area. Next was the steering column: Piece of cake! 10 mins and it was out! I took the steering shaft out last week though, so the hard part was overwith. Next was the dash itself. It wasnt as bad as i thought it would be...6 bolts on top and 6 on the bottom( i think) and it rolled right back. I disconnected all of the harness that i could see before i rolled the dash back, and got the rest as i saw them. (it would be much easier with another person helping) My z had a dash cap on it when i bought the car 6+ years ago, and i never really bothered with in until now because it was my daily driver. So now im curious whats undernieth the cap.... ill post photos as i dig!
CCW sizing under stock fenders
Dat260Z replied to EvilC's topic in Brakes, Wheels, Suspension and Chassis
There is a guy running xxr's on his car with no flares. 17x9 front (essentially +10 ) 17x10 rear (essentially +13) Lips are pretty large on the rear. Almost 4". I think he is running 235 tire in the rear though. -
Z32 rear suspension conversion into a 78 280z
Dat260Z replied to 3200turboz's topic in Brakes, Wheels, Suspension and Chassis
I suppose if you have the fab skills it would be worth it , otherwise you would be better off just stiffening the chassis with reinforced frame rails/6 point cage/strut tower braces. There are guys running very high horsepower(600-800rwhp which is nutty) s30's with light chassis modification . If you were to go with the T3 rear end kit (utilizes the z32 brakes/diff) I'm sure you could swap over the ABS system. Though alof of road racing guys do not like ABS on their track cars. I'm not a fan either , but I only auto-x my Z. Anyways , good luck! -
Techno toy tuning has the kit to fit all the the z32 goodies ..diff/axles/brakes..why else would you want to swap z32 subframe under an s30? -
I know where an l28et engine is for sale.asking $500 . Comes with wiring harness and all. Pm of interested and I'll shoot you some details
I know where a complete l28et is , from a running z..wiring harness and all..asking $500 Pm if you are interested
Did you check Aerocatch ? Those would be nice!
thanks.. tried to text but the number listed is invalid.. i guess ill try to email him
