Everything posted by Dat260
Iam sure it fits. You can you the n36 from the flat top carbs engines found in late 73s early74s. The manifold has slightly bigger ports.
Weber jets??All who live for their triples please read this
Dat260 replied to datfreak's topic in Nissan L6 Forum
Not to Highjack this informative thread. Steve260z if you want I have an extra one. PM me if interested. -
Wiper, tail lights and dash lights don't work
Dat260 replied to tooquick260's topic in Ignition and Electrical
I have the same problem. check your wiper/lights switch. I took it apart and found loose/corroded wires. This tutorial was helpful too. Rebuild_240Z_combo_switch.pdf -
I bumped in on this thread through search because I'am looking to find a solution to my jumping tach. I have a couple of instalation diagrams for your petroniks and msd box that I will post. In the mean time post 11 mentions resistor of 4.0 or 5.5 ohm to be installed. I installed a 2.2ohm resistor at the passenger side under the dash and its still not working. (260Z/74) My question is; My ignition is stock and if I install a 4.0 or 5.5ohms resistor on my factory wire harness would it cause any harm? Here are the pic for you guys with petroniks and msd box; Ign upgrade 1.doc
Need 240 Z 9mm rods and a set of 87/88 mm forged pistons
Dat260 replied to zentech's topic in Parts Wanted
Hi, I have what you are looking for. My piston came from Arizonazcar which are no longer available but they are 86mm flat top with different compression to fit 240 rods. This combo will give you zero deck height and. Pistons comes with rings and pins. Let me know. -
No I did not make this, but it should not be too difficult to make. Just follow the same principle. To me it looks like a front strut bar modified to fit the t/c cup. The owner of this car also did the same to the rear following the same principle.
Trying to fix my jumping tach issue, I searched and found a couple of approaches. - replaced the resistor situated in the passenger foot well, no go - dismantled the tach, cleaned it and slightly heat up the soldering connections, no go.
I have the same problem with a jumping tach. I change the resistor in the passanger foot well like suggested above and still have the same problem. Iam thinking maybe the coil since it seems its the original one but the car runs fine so I do not know what else to do. My car is an early 260Z 5/74.
5 Stud Front Hub Conversion
Dat260 replied to diggs's topic in Brakes, Wheels, Suspension and Chassis
Iam doing the same install and I was wondering if debris can get in there? Is there a seal that closes this gap? -
Project: SteeZee - 1973 Datsun 240Z LQ9 V8 Build
Dat260 replied to Aaj2k5's topic in S30 Series - 240z, 260z, 280z
Don't change your post, I need glasses, I hate to admited. Thats what I wanted to reffer in my question. Localy lq9 are a dime a dozen but t56 are rare and very expensive. But, Z33 trannys are easily found and I wanted to know how did you mate the two? Did you by an adapter or you made one and is the Z33 tranny strong enough for a 400hp lq9? Sorry for the confusion, Cheers, -
Your "parts list" mentioned it. Thank you for clarifying. -
What adapter are you using for the r33 tranny to lq9 motor? -
No Low Beams/ Dash Lights/ Running Lights
Dat260 replied to 240zBoy's topic in Ignition and Electrical
You have a short obviously, check your bulbs and bulb sockets. My culprit was the front left blinker, the socket was rusted and created a short. I was driving for awhile without the lense so it got corroded. cheers, -
The kit is called zvette. Came out in the 80's I think.
Very nice job, Thank you for sharing.
I would be interested as well for mounts with T56.
Dat260 replied to k3werra's topic in Brakes, Wheels, Suspension and Chassis
very nice! -
If you come down to Montreal, maybe I have something for you. Let me know when you are in town, I;ll show you a nice project. Cheers,
Hi and welcome. What is your budget?
It would depends on how long you have this knock problem. In any case its wise to check everything. Measure your cylinder for roundness, your connecting rod for warpage and your crank journal for out of round. Get yourself some precision measuring tools. If you have the "how to built an l6" from frank hosowitz (sp?) it shows you how to check for all this. Good luck!
