mas28O
Everything posted by mas28O
  1. hanomon, looking good. Do you have the wiring done? Mike
  2. Mark, Will the datsun tie rod ends fit to make it the right size. I am going to post some pics of my motor to see if it will clear the motor. It looks like it will be close to the motor. Thanks for the info. Mike
  3. Mark will the WRX rack clear the datsun towers? If you are going to make a new mounts for the LS1 you might want to buy the Corvette mounts from quick240. I know that he bought some but he ended up using Johns mount kit. Mike
  4. Hi Mark, I just ordered my Arizonazcar a-arms today. I am looking at doing the WRX power steering also, but it looks like the WRX shaft will be in the way with the datsun engine tower. how far are you with the WRX swap? Mike
  5. Dave I spoke to you on Tuesday about buying some control arms. I have the R230 in my 240z I will try and take some pics this week of it. If you make the MB for the r230 it would sell good. (I WANT ONE). Mike
  6. I was looking on his web site and I saw this new item. Looks like a good deal for only $229. I hope that Dave will make a mount for the R230 also. Mike
  7. Thanks for the info on the Rough rule of thumb. I think that I can get my 60' down into the 1.4 range with some good tires. I am going to wait for the flare's before I buy my new tires. Scottie what size tires did you run? Mike
  8. Scottie I already bought the new cam for the car, so I have to use it now. I think that the car is making the power if I can get it to hook up. Right now I can not give it full throttle until 2nd gear. (Your numbers are dead-on and with a gain 25.8mph in the 2nd half) Is this something that i should look at, The gain from the 1/8 to the 1/4? Thanks Mike
  9. Mike I think that I need to get my MPH in the 124 and it will run a 10. I am going to install a new cam and do some more dyno tuning.
  10. I took the Z out to Sacramento race park today. I found out that I need slicks now. I had to take it easy in 1st gear, but I got some good times. 1.6 60' 7.1@97mph 1/8 11.1@122.8mph Almost a 10 sec pass. Mike
  11. I can not believe how many LS1 swaps are in the works now. You almost never here about the LT1 now. Good luck on the swap David, the ls1 swap is now an easy swap. Mike
  12. I want to buy some panasport rims for my z. I found the modle that I like but I donot know where to buy it or what the modle # is. Can some one please tell me the best place to buy this model. They are 17"x7.5 wide Thanks Mike
  13. Terry with a 275/50/15 drag radial you should be able to get your 60' in the 1.5 range. You have the mph to run 11's. Have you ever tried a roller cam? Mike
  14. I put in a 302 in my old 280 before, good motor. I like the LS1 alot more than the LT1. The best part about the 302 swap is the price. Put on a set of heads and a good cam in the 302 and then you will love it. I am also looking for a FRC 99-00 corvette, I test drove one last night but it was junk. Mike
  15. Mudge 5.0? I thought that you where going to use the turbo 6 for your 240z?
  16. I am using the MTi's c2 cam with good luck. I might try something larger down the road but right now I am making 400rwhp with a auto. I will have to look for that magazine. Mike
  17. Went my his shop and his 280z/ls1 swap is getting close. These are some old pics I will post some new ones as soon as I get them. Mike
  18. That motor looks too clean to sell Stan????????? Mike
  19. how much for the body with the vette rear? Mike
  20. khashabi1 is using the Corvette mounts on his LS1 swap, he also has the ac mounted in the stock location. It was nice to have 2 LS1 swaps on the road at the same time. Mike
  21. David, good luck on the swap. Let me know if I can help you. Are you going to make your engine mounts? Mike
  22. I had my car at Tims house, maybe he likes the LS1 now. Just a guess, Tim what are you going to put in that car??????
  23. Looks like a good deal. You have alot of $ in that LT1. Stan try to post some pics if you can. Mike
