mas28O
Everything posted by mas28O
  1. Dale, when do you think you will have you 280z on the road?
  2. http://www.autobarn.net/eqoilpreselt.html This is the kit that you need for the water and oil.
  3. I hope to see some Z,cars at the track. Mike
  4. mas28O
    Jtr Ls-1 Pics
    Tim when are you going to put a LS1 in your car? Mark looking good. MIke
  5. Tim the early 5.3 have a cable and the later years switched to drive by wire throttles. You can buy any 5.3 and then just put on a cable TB. 5.3 motors are cheap on ebay now. Mike
  6. Congrats Mark, When will you have it on the road? David you are next in line to get your swap done. Mike
  7. blueovalz the 280zx will hold up to track racing but not drag racing. If you stay away from the drag strip then they will last you a long time. As soon as you put on some sticky tires and try to launch they will brake. I know eian that drives a Viper blue 240z with a 280zx turbo motor has broken a few of them also. And he runs a 300rwhp 280zx turbo motor that runs mid 12's in the 1/4. Cyrus I did not know that the q45 diff comes with a 3.11 gear? That would be a nice gear to have. Mike
  8. My 240z has the 4l60e in it so I cant tell you how the t56 would be in the z-car. But my 1993 Ls1 RX7 does have a t56 in it. Right now I have 4.08 or 4.10 gears in it. I still find 1st very usable, I use 6th gear over 60mph. The t56 will not be as fast but it will be alot of fun. Mike
  9. The 280zx cv axles are very week and they will not hold up. Cyrus are you going to be at the cmi races in Sac on the 2nd? Mike
  10. Tim it is 9370010 . I know that you are driving to the BayArea, do you want it?
  11. I have a free chevy 350v8 4bolt block. The block has been bored .030 over, new cam bearings, it has never been used. This is just the block, no pistons, rods, crank. Free------pick it up in the BAYAREA,CA. Mike
  12. Use a engine lift. LS1/t56 with acc is 605lbs..
  13. DaleMX With heads like these you should run 10's. I might put on some ported heads some day. How long until you have it up and running. Mike
  14. mas28O
    JTR LS1 Headers
    Make sure that you go with a 13/4" header for a LS1. Anything smaller and you are going to have power loss.
  15. Here are the November specials. Next month (December) we will be running THE best special on GM parts, EVER, on EVERY GM part. It will be dubbed "Christmas @ FredBeans". I am also introducing a specials email list where when I have my specials ready to post or I want to give all of those people on the list something special they can get it. If you would like to get on this list, especially for the "Christmas @ FredBeans" please email me at gculley@fredbeans.com with your name and specials list as the subject header. At any given time for any given reason you may request to be taken off the list and immediately be taken off. Stay tuned!! ||--All New LS2 Items!--|| LS2 Engine Block - 916.50 + Actual Shipping Charges! LS2 Throttle Body (90mm) - 249.99 Shipped To Continental US! LS2 Long Block - 5499.00 Shipped To Continental US! ||--Genuine GM LS6 Intake Manifold--|| 88894339 - Intake Manifold Only - 389.99!! 88894339 - Intake Manifold W/Coolant Pipes And Plugs - 429.99 Shipped To Continental US!! ||--Genuine GM UltraGuard UPF 44 Oil Filters--|| 25329389 - UPF 44 Oil Filter Must Order In Case Of 6 Only! Case Of 6 Shipped 45.99 To Continental US! ||--Genuine GM Cylinder Head Bolts And Gasket Kits--|| 12498543 - 97-01 LS1 Engine Head Gaskets (2) - 37.25 Shipped To Continental US! 12498544 - 02-04 LS1 & LS6 Engine Head Gaskets (2) - 28.99 Shipped To Continental US! 12498545 - 97-04 LS1 & LS6 Engine Head Bolt Sets (2 Cylinder Heads) - 43.99 Shipped To Continental US! ||--Genuine GM GTO Fuel Rail Covers--|| LH & RH Fuel Rail Covers 89.99 Shipped To Continental US! Availability Is Limited And Will Apply When Ordered! ||--Genuine GM Clutch Parts--|| 12570806 - '02 Fbody And Corvette Z06 Clutch - 369.99 Shipped! 15046288 - '98 -'02 Fbody Slave Cylinder -106.80 Shipped! 12570277 - '01 -'02 Fbody Master Cylinder - 123.80 Shipped! ||--Helms Service Manuals--|| '98-'02 Firebird And Camaro - 124.95 Shipped To Continental US Please Call For Any Other Make/Model Vehicle! ||--Genuine GM GTO "5.7" Emblem--|| 92119040 - GTO "5.7" Emblem - 26.99 Shipped To Continental US! ||--Genuine GM Performance Parts C5R (427) Block--|| 12480030 - C5R (427) Block - 6300.00 Shipped To Continental US! ||--Genuine GM 405HP LS6 Crate Engine--|| 12498399 - Comes With FBody Oil Pan For You Fbody Folks! 5229.99 Shipped To Continental US! ||--Genuine GM LS1/LS6 Engine Parts--|| 12455209 - '98 - '02 WS6 Lower Airbox - 78.50Shipped! 12551366 - 6.0 Litre Bare Engine Block - 639.95 12565308 - '02 LS6 Cam - 209.95 12586484 - '02 LS6 Valve Spring - 5.50 each 12564824 - '02 LS6 Cylinder Head (Assembly) - 699.99 each 12564825 - '02 LS6 Cylinder Head (Bare) - 609.99 each 12480110 - ASA Racing Cam - 359.95 12480033 - LS1 Hotcam Kit - 419.99 88958622 - LS6 CNC Ported Cylinder Head (Assembly) - 959.99 each!! ||--Genuine GM Fbody Brake Parts--|| 18026298 - Front Brake Pads - 95.27 88899570 - Rear Brake Pads - 55.86 18038817 - GM Durastop Front Rotors - 69.95 each! ||--Genuine AC Delco Performance Drilled/Slotted Rotors (Corvette)--|| 88926732 - LH Front Rotor 88926731 - RH Front Rotor 88926734 - LH Rear Rotor 88926733 - RH Rear Rotor Front and Rear Rotor Sets 212.99 Shipped To Continental US! ||--Genuine AC Delco Ceramic Brake Pads (Corvette)--|| 88909667 - Front Complete Set 88909668 - Rear Complete Set Front and Rear Ceramic Pads 117.50 Shipped To Continental US! ||--Genuine GM Performance Parts 6.0 Engine Assembly--|| 12499467 - 3699.00 Shipped To Continental US! Complete 6.0 Engine Assembly With Intake Manifold, Exhaust Manifolds, Fuel Rails, Etc.. 345 HP@ 5200RPM ||--Genuine GM Corvette Z06 Brake Calipers--|| 88895128 - LH Front Caliper 88895129 - RH Front Caliper 88895130 - LH Rear Caliper 88895131 - RH Rear Caliper Both Front and Rear Caliper Sets 349.99 Shipped To Continental U.S! ||--Genuine GM OEM Corvette Rotors--|| 10445856 - Right Front Rotor 10445857 - Left Front Rotor 10445858 - Right Rear Rotor 10445859 - Left Rear Rotor Front and Rear Rotor Sets 258.99 Shipped To Continental US! ||--Genuine GM 2004 Corvette Z06/Z16 Shock GP--|| 10339944 - Front Shocks 10339945 - Rear Shocks 345.99 Shipped To Continental US! ||--Genuine GM Corvette Z06 Stabilizer Bar Kit--|| 10419094 - Front Stabilizer Bar 10424743 - Rear Stabilizer Bar (2) 10351954 - Front End Links (2) 10351954 - Rear End Links (2) 10419095 - Front Bar Insulators (2) 10333410 - Rear Bar Insulators 231.99 Shipped To Continental US! ||--Genuine GM WS6 Emblems--|| 88951585 - Black "WS6" Emblem - 59.97 12455216 - Red "WS6 Emblem" - 79.97 12458777 - Blue "WS6 Emblem" - 69.97 ||--Block Off Plate Kits--|| EGR Block Off Plate And Gasket - 14.80 A.I.R Block Off Plates And Gaskets - 19.80 EGR-A.I.R Block Off Plates And Gaskets - 29.80 ||--Genuine GM LS1/LS6 Fuel Rail Covers--|| 12559261 - '97-'98 LH Fuel Rail Cover (Black With Red "Corvette" Lettering) 12556455 - '97-'98 RH Fuel Rail Cover (Black With Red "Corvette" Lettering) Both 54.99 Shipped To Continental US! 12561503 - '99-'02 LH Fuel Rail Cover (Black with Red "Corvette" Lettering) 12561502 - '99-'02 RH Fuel Rail Cover (Black with Red "Corvette" Lettering) Both 63.99 Shipped To Continental US! 12564257 - '01-'02 LH Fuel Rail Cover (Red With Black "Corvette" Lettering) 12564258 - '01-'02 RH Fuel Rail Cover (Red With Black "Corvette" Lettering) Both 90.50 Shipped To Continental US! Fred Beans Pontiac Buick GMC Terms And Conditions Of All Sales: We reserve the right to change the price of any part at any time and/or refuse to sell a part for any reason at any time. Price changes that can be made through the month are final and all sales before and after the price change are final. We will accept no returns after 30 days and all boxes or packages must be in the same condition as which they were received. If a package is received in anything other than perfect manner, please call and note upon receipt. Anything noted after the fact is the responsibility of the buyer. All returns are subject to a 20% restocking fee and/or a fee for unacceptable boxing or packaging. We reserve the right to change the terms and conditions of a sale at any time for any reason. __________________ Fred Beans Pontiac Buick GMC gculley@fredbeans.com or 610.495.1700
  16. JCI kit looks nice, I have seen it on Joey's car. It will work good for anyone that does not want to refine there swap. JCI mounts there motor about 1" higher and 2-3" forward of where I mounted my motor. This is why JCI was able to keep the alt in the stock location. It would be nice if there where more LS1 powered Z-cars out there. I am surprised that there are not more LS1 swap cars out there. After using both the LT1 and the LS1 I would never consider using the LT1 ever again.
  17. That job look harder right side up.. It was alot easier up side down.
  18. Mat73GNZ What did you do with the fuel pressure regulator?
  19. I hope that someone can bring a video camera. Cyrus I will see you out there. Mike
  20. The car is up and running now. I will be at the track this Saturday if it does not rain. Any Z-cars want to take there car out to Sacramento raceway on Saturday?
  21. Congrats on the first drive, I know that it feals good. I will have to take a look at your car next time that I am in Brownsville. Mike
  22. I will have it at the track in 2 weeks to find out how it performs next to the 240z. My 240z with the ls1/4l60e and roll cage was 2575lbs Mike Knell brought his weight scales buy before I did the swap in the rx7. I think it was 2820lbs before. I will weigh it again after the swap. I think that the rx7 will be 250lbs more than a 240z. I will have to wait for the track before I know how it performs. Mike
  23. My stock LT1 was never on the dyno but it was about 250-260rwhp. My car ran 12.5@107 with a bone stock lt1/4l60e After heads,cam, tb,rr It made 320rwhp and it ran 11.8@114
