Everything posted by bradyzq
Twin cam head for the L6 from Derek at Datsunworks
bradyzq replied to Derek's topic in Nissan L6 Forum
Wow that is elegant! Inspired by mechanical injection systems? -
It seems like this is no longer putting the cart before the horse to ask these questions: What are your plans for engine management, and do you plan to run it in and tune on an engine dyno, or in a car? Well done, sir! -
Should I relocate this O2 bung on a downpipe I bought?
bradyzq replied to zeeboost's topic in MegaSquirt
You could always get a thread-in O2 bung extender with a 90 degree bend, and angle it wherever you want so that water can never sit on the sensor. http://s13.postimg.org/iju3yrhmf/689_73_popup.jpg -
Have you checked your grounds?
Depending on how that head achieved its 38.4cc combustion chamber size, and how your pistons are shaped and positioned, you could still have piston-valve contact if you try the big cam in your engine. Whitehead has been building and racing Z's for over 30 years. I thnk it's safe to say they know what they are doing.
Car dies only at WOT. Any ideas?
bradyzq replied to dpuma8's topic in Trouble Shooting / General Engine
I love that kind of solution! You feel stupid for awhile, but the fix is easy and cheap, so that part's a win. -
Stock fuel pressure regulator with new walbro 255 pump?
bradyzq replied to supernova_6969's topic in Fuel Delivery
You could check the spark plugs and see if they're more or less equal in colour. That would point out any cylinder-to-cylinder differences, maybe due to injectors, or not... Next, and I seem like a broken record to myself regarding this (and I actually do have a turntable that won't go to the end of a record and lift, so it skips and repeats), make sure you have good voltage to the pump. This means good wiring on both power and ground sides, ideally straight from the battery, with the original wiring being used only to trigger a relay near the pump. This is especially important when the wiring in question is over 30 years old!!- 5 replies
- fuel regulator
- furl pump
(and 1 more)
Tagged with:
Since your advance curve is programmable, when you next visit the dyno, why not try adding or removing advance and see what happens to power or torque? It is safer when dealing with an unproven curve to first remove a couple of degrees then test. If torque drops everywhere, then advance the timing on the next test pull. If it _doesn't_ drop, you were overadvanced. Repeat until you have determined the optimum curve for best torque. You may, depending on the type of dyno, be able to dial in the vacuum advance curve in a similar way. If the dyno is not able to, then Chickenman's suggestions for doing the vacuum advance tuning on the road should work great.
Are you also NapaBill, the guy who contributed so much to the Weber thread? If so, thank you and welcome back! If not, welcome!
There are many plug'n'play ECU options for the RB...
Fifiddy shipped?
Me too, sorta kinda. I just didn't bite!
JSM, you may be right, but who knows how many electromotives should have been electramotives?
Bernardd, I'm sure Tony D could answer that question in a complete and entertaining way.
Lol, yeah I guess I do! I'm guessing that some people think they are one company.
Hi All, I've got to get this off my chest! Electramotive with an "a" built and raced Datsuns in the 1980s. Electromotive with an "o" makes and sells crank triggered ignition and engine management systems. These constantly get mixed up here, mostly by erroneously spelling the race engineering company's name with an "o." Electramotive owns a large chunk of Datsun racing history. Let's at least try to spell their name correctly. EOR. (End of rant.)
I _hope_ that is was off only for base fuel pressure verification.
It depends how you have your fuel pressure regulator plumbed. Regardless, though, you should be able to install the gauge immediately before or after that fuel rail. Other places may or may not work depending or regulator placement/plumbing.
Try free revving to say 3000rpm and measure timing advance. That will give you an idea if things are OK off idle. Also, if you have an exhaust leak between the head and the O2 sensor, the ecu will add fuel to correct the perceived lean condition.
Disclaimer: I've never played with a Z31 ecu. Having said that, if you threw a knock sensor code due to it not being connected, it is very possible you're running on a timing map for when the engine is knocking. This would of course kill fuel economy. Can anyone confirm that these ecus do or don't work this way?
I don't think TEP or Electromotive have ever been accused of selling crap, so I don't think you can go wrong there. Buuut, if you are getting the ecu tuned by somebody else, make sure the tuner is comfortable with the ecu. I have tuned Electromotive ecus and they work well. But so do many others, such as Link (which must be well known in NZ).
Remember that the K20A2 is an iVTEC motor. Unless you go all out and make your new 6 cylinder K-series head iVTEC, you won't have the wonderful wide torque band they have. They only look peaky because the torque just doesn't fall off, seemingly ever. Check out this dyno graph of that motor with boltons and a tune. 90% or greater of max torque between 4500 and 8000RPM. 80% or more for the whole dyno pull. Heck, the torque PEAK is 1000RPM wide!! With conventionally timed cams, I would guess you can still get a nice torquey motor, but it won't be as flat a curve. http://www.av-engineered.com/site/news/224whp160tq-stock-k20a2-dyno-tuned -
NA 3.1L=>head & camshaft questions. No shortcuts, max
bradyzq replied to zredbaron's topic in Nissan L6 Forum
I wish 40's were adequate for all applications! Assuming the carbs are jetted, adjusted, and operating correctly, the extra fuel should be drawn in by pressure delta due to extra airflow. Are you suggesting that the air speed in the center of the venturi, where the fuel is drawn in, keeps increasing, but the overall air volume decreases due to non-laminar flow towards the outside? -
I understand all the improvements in engine breathing are breathtaking. Pun intended. But what Steve and I are trying to say is that you're running too rich because of too much fuel, not due to a lack of oxygen (air). For example, in a modern, EFI'd spark ignition gasoline piston engine, if you're cruising along the highway at an AFR of 10:1, would you say that the engine needs more oxygen and you must therefore turbo/blower/nitrous it? Unlikely. You would say that it needs less fuel and remove some in the fuel table. I was suggesting measuring MAP at WOT to see if pressure starts dropping where you think the choke/stall point may be. -
Wow, had to read that one a few times! We will learn whatever is hidden up in those trees. I suggest that ALL the principles behind a working carb are volume, not mass, based, at all times. So, density changes are not directly tunable without changing parts (jets, etc.). I also suggest that you will not be able to strip the oxygen out of the air under any conditions encountered in a carb. Air volume flow will remain proportional to mass air flow for any given set of atmospheric conditions at the carb inlet. And mass air flow should be proportional to power. And since the venturi is not changing size, power is proportional to air speed though the venturi. And air speed will be proportional to pressure drop through the venturi. Pressure drop at the venturi should be proportional to fuel flow if there was only one jet and nozzle. So, based on that, kinda sorta, if the engine keeps one getting richer and richer, it's because more and more fuel is getting drawn into the carb by higher and higher airflow. Have you measured vacuum in the intake manifold at WOT at higher engine speeds? That would help tell you if the carbs were really a "severe restriction." EDIT: Basically, this is stating what steve260z said a couple of posts up, but in a much less efficient way.... EDIT#2: Errr, it's my description that's the less efficient of the 2.
