Pharaohabq
5
Everything posted by Pharaohabq
Ahh You're right, Austin didn't cut into the firewall. Still it's a tight fit, and w/o cutting in, you'll probably have to mod that crossmember some more. I guess I was confusing Austin and Myron's build. I know Myron really cut into the firewall. I guess Austin's only cut was for that sensor on the lower right. Anyway it's how you can make it fit. If you lower it a little more you might have more room. The engine looks like it's tilted up a little in front. Why brace the hood? It's not supporting anything but itself. Rather than the "traditional" hood clips to hold it shut, I'd like to see someone Get a second stock latch and move them to the corners, connected by a cable. You then pull the Stock handle inside and it unlatches both corners.
Yeah the other VQ35DE installs (Austin and Myron) both cut the firewall, into the wiper cowel area to get that last inch or so to fit. The VQ35HR fortunately doesn't have that issue. But anyway, you may find it easier to cut out a little more of your Steering crossmember and bolster it between the mounts for the Steering Rack. That way you should still be able to fit without cutting the firewall. You'll also see that your sensors on the rear of the engine may also have issue, so check that too. I know on my HR I've got water lines back there that are going to be trouble for me. As for the AC, We're working on ideas for a mounting bracket that would move the AC pump out and up a little so it'll clear the Steering shaft. I'm not quite there yet though. Your hood should actually have a pretty good amount of space. Lay a 2x4 across your fenders. You'll see you can have the engine as high as that board and still fit the hood due to the center bulge in the hood fitting over the engine. BTW, great pictures! I'm loving your work!
Thanks for that, I should have mentioned it was in some other vehicles. Of note though, The VQ35HR In some other "clothes" may have power limits due to different intakes etc. so know what you're buying. Performance cars like the 350Z and G35 should be safe bets, but check the factory specs for whatever donor you find. Again the FWD and AWD versions may require extensive mods to be fit in an S30 (oil and lower case swaps). Hey I'd love this to be a Sticky
Black soot is very often an indication of running too rich. That would also add to my theory of the Cold start injector being turned on. The Thermotyme issue often causes hard starting and rich running due to a failed thermotyme or water temp sensor. If you really thing the water temp sensor is good, then test the Thermotyme. autolight plugs are fine. You're not going racing everyweekend yet so just cleaning those and resetting the gap should be fine. The distrib has a bolt holding it down. there's notches, If it's tight still then don't mess with it, it's probably fine. If it's loose then you might set it to the center then tighten it down. You'd then have to set the ign timing properly in that case. I assume you've D/L'd the FSM and EFI manual. look up the Thermotyme faults in there.
Thinking about a Duratec V6 in my S30
Pharaohabq replied to 4.6StangRage's topic in S30 Series - 240z, 260z, 280z
4.6SR, Sure you could use that engine. A comparable engine is the VQ35DE or HR and/or the VQ37HR out of the respective 350Z and 370Z. Both are available with 6 speed trannies, and both are 280HP+ engines Stock. The VQ37HR is supposed to be rated at 350HP. These are also aluminium, fuel injected and widely supported. The later VQ's use VVT for both Intake and Exhaust timing. There's a few writeups on the install to an S30. So you wouldn't be pathfinding. Check out the V6 forum on here for more info. That being said, I'd love to see another V6 engine ported to the S30 platform. if the Duratec V6 is easilly managed it might be a good swap solution. I'd imagine some of the same methods for mounting may work for both V6's. Do you know what transmissions are availible with the Duratec without having to use adapter plates? -
Might also check your Distrib is bolted down and set properly. Ignition timing should be 10 deg before TDC if I remember correctly off the top of my head. It's in the FSM. If your ignition timing is off it could act like you're describing. There's a lot of things that could cause issue. Maybe pull your plugs and clean/gap them, then inspect your plug wires, cracks and such could also cause issue. Lastly it's possible the Cold Start injector could be stuck and pushing too much fuel in causing a too rich condition. (that's why his water temp/thermotyme was important) Anyway all of those parts listed above can cause issue too, but use the FSM to test before replacing or you could throw away $...
There's some guys doing VG30 swaps in the V6 forum on here too. it looks like yours is coming together.
What year of car? Great, Click here: Google Then Click Images... You'll find this:
What do you think of this engine?
Pharaohabq replied to Sanchez's topic in S30 Series - 240z, 260z, 280z
I was going to say, for that kind of money, you might be able to buy something already built from Rebello or kamerari<sp?> or something. that's closer to 4-5 grand tho if not more. -
I thought the Z32 was an R230. Anyhow no matter. I seem to remember some people using the late Z31 shafts and changing out the inner cups. I've got an VLSD R200 out of a 350Z, and I'm hoping I can take the inner cups and use Z31 shafts, since there's a ton of them as the junk yard. If not I'll have to go with AZCar's setup. It's nice to know it's 17" and 17 3/8" distance. I'll have to look. There's a lot to be said for buying a bolt on system. I'm real tempted to buy an RT mount too, rather than try to make it. It'd be best to search on here and see what other people have done, and especially to see what issues they've had.
'73 door side gas cap assembly
Pharaohabq replied to badjuju's topic in S30 Series - 240z, 260z, 280z
Seriously, no gas caps, Check these links out: http://blogs.cars.com/kickingtires/2008/09/filling-up-a-fo.html http://www.nbcnews.com/id/22688959/ns/business-autos/t/ford-making-gas-caps-thing-past/ -
Not running after rebuild
Pharaohabq replied to IncompetentOne's topic in S30 Series - 240z, 260z, 280z
Yes, if you read that manual about the Cold start system Thermotyme switch and Cold start injector you'll see that some of those sensors are required. A correct thermostat housing is avaliable from a multitude of sources. (on here, junkyards, Z dismantlers, Ebay - I can PM you info if you need) The engine will start without the thermotyme, but it can be a pain.. Next time, Open the cap on your gas tank before removing fuel lines, that'll release most of the pressure to keep you from getting a gasbath. Gas in the eyeballs hurts! if you post pictures, we will be much more likely to help you sort things out since we'll be able to see and discount anything that's obviously correct. The Canister. Well it's not required at all. A Z can pass emissions without one. Though the canister DOES help your gas milage. If you read in the manual, you'll see the canister has 3 lines. one large one and two small, The large I believe runs back to the fuel tank, one of the small tubes operates a vaccum valve, and I believe the other runs to the intake. What the canister does, is sucks fumes condences that into fuel and lets that be sucked back to be reused. Wow Jump starting, You know back in the day, we didn't have jumper cables, We had to beg people to help us push our car fast enough that we could jump in and pop the clutch in 2nd to start them! -
PM'd you. Now if you wanted to do something custom, you could pull the nozzle from a newer car and get the better sealing capless fuel door. -
Very cool, Will all this fit in a Z32 2+2? I'm loving those bumpers wings and skirts. I'll have to check out the website n see if you've got pricing up yet. A couple Q's: On that oil pan, I guess it'll have to be installed only with the motor out since those rear bolts will be about impossible to reach otherwise, right? Not that anythink in the Z32 engine compartment is easy to get to. How well does the VH fit front to back? Won't it hit the radiator?
Progress on my insane VQ35HR 240Z project
Pharaohabq replied to markrolston@mac.com's topic in Nissan V6 Forum
Pretty darn nice, Those valve covers look great in red. I wonder why they didn't print them in red to start with? I'm sure they must be able to get tinted nylon. Anyhow it's looking great! It's so nice to see so much progress and engine pron! I can't hardly wait till you get the wiring harness on. I want to hear what a twin turbo VQ35HR sounds like, especially with that intake. -
You might look at the FSM Power/Ground at the IPDM E/R module. I think the stock Fuel pump relay is in there and may not be hard to patch into.(page "PG-27", Pin 23 on the E7 connector) If you have the Body#1 harness, the Fuel pump lines run through it to Body#2 plug B27 a GY/5 connector. it's on the 03 manual page "PG-53" You may need to upgrade fuse 81 fo a 20A if You're going to run it harder, though since you're using the stock pump so I don't expect you'll really need to change that.
Another part of this that was brought to my attention. Some of the non-Z, Non-G Vq35 engines may be HP limited by their intakes. The Maxima Intake flows well, but the Stock output numbers aren't rated as high as the Z for the same year. Certainly there's issues moving from front wheel drive to rear wheel drive. Most often this involves changing out the oil pans, either just the lower, or both upper and lower pans depending on which engine you find. So, for that reason alone, I'd recommend you find a donor engine that already supports a swap to a 6sp manual RWD, or an Automatic RWD tranny. That being said, I did see something that might make the swap a little easier, That is using the FWD Maxima or Altima headers. They point almost straight down, and by moving the exhaust studs, you can mount the front header on either side of the VQ. This could make it easier to route the exhaust away from the firewall, though if you use a bar between your engine mounts, then these pipes may not work. It would be fun to see someone try this and post their experience. The exhaust would have to make a 90 deg turn from those headers, but that may be easier than trying to mod the stock 350Z Y pipe. Another point I didn't mention is the Driveshaft. The S30 yoke won't fit the 6sp MT. You'll need to source a VQ driveshaft so that you can have your S30 shaft modded or a new shaft made to fit between your tranny and the R200, or R180 from your year of S30. If you're swapping in the R200 Shortnosed (read LSD) from the same donor car you would need the driveshaft flange for the other end. When having a shaft made, you'd need to measure from center of U-joint to center of U-joint, but talk to your shop and see what they want. The 350Z's use a CF driveshaft with metal yokes, they'd need to cut off the CF to make the new shaft. Phar
The Problem with stand alones, is that for the cost and the trouble to install the stand alone units, it's argueable that's it's worth it for the VQ engines. Only the Haltech stand alone supports "drive by wire" as I understand it. But otherwise, you'd have the trouble of swapping out your Throttle Body with a cabled version (I believe some people are using the new Ford mustang TB.) You may have to replace most of the other stock electrical components (MAF, TPS, Temp, CPS, IAC) to work with various after market (AEM) solutions. Right now, I'm not certain if any aftermarket solution can handle exhaust side valve (EVT) adjustment (HR models), tho I do believe Haltech handles intake valve timing adjustment, and last I heard was working on the EVT, but I didn't see any HR support on their site. The Cost of the aftermarket unit likely will be a lot more than just going with a Stock or Zfever adjusted ECU solution. The Haltech ECU alone is really expensive. (~$2500US for Z33 Plat-Pro Plugin) You'd still need the OEM harnesses etc. Haltech does allow for Meth, Water or Nitrous injection, and FI which is nice, but Tuning a stand alone won't be cheap either, it depends on your application. I could not tell you now many other functions such as Tach and Speedo, that Haltech supports. The OEM Service Manual lays out the Electrical pretty well, so it's not that hard to get the engine running on OEM equipment. As I recommended: if your get all your parts from the same donor, you'll save a lot of $ than buying peicemeal, and you'll know you have a system that once worked together complete. I'd recommend getting it running on the OEM ECU before switching to an aftermarket, if possible, mainly for the ease of troubleshooting. The only two companies I have heard work with the VQ35DE are AEM and Haltech. I admit, my experience with After market ECU's is very limited, (primarilly MS+S) but I've done a few swaps using OEM parts. I'd recommend that you do your homework before selecting an alternate engine management solution, as any issues could be quite costly. We know the OEM ECU, without a tune, is already setup for functionality and perfomance.
So I've been asked a lot of times about the different VQ engines, and swapping into an S30. While I'm not exactly an expert on them, I am swapping a VQ35HR into my S30. Most of the questions I get are about what is required to make a VQ run. I've read a lot about it, and I've seen what other people have done to make one work. Props always have to go out to 240Hoke (Austin) and EMWHYR0HEN (Myron) for pioneering this swap into an S30. I highly recommend you read their pages and threads. Doing a swap is a big deal; it's not just a single weekend bolt on change. Usually it requires a little welding, or a lot of $ to have someone else do it. You can about guarantee that you'll blow your budget, so when you're planning a swap. Expect to spend at least $3K-$5K more than you're thinking. A VQ35DE (287HP) is very tempting, stock it’s over 100 HP more powerful than the stock L28E (170HP). Before you buy: There are a lot of places to buy an engine. But before you look, there’s a lot more to a swap than just the engine. There’s all the accessories that often don’t come with the engine (people make more $ selling them separately). Then there are the Wiring harnesses, The Computers, the Fuel management, and the Integration to your car. These are things that are costly in addition to the expense of buying the engine. You should have a plan in place before you start. Expect your car to be out of service for quite some time. Try not to get bit by the “While I’m at it†bug. Do one project at a time, one phase at a time. Planning is probably the most important part of your swap. Read Read Read; make sure you’re familiar and comfortable with all the systems, and steps for swapping an engine. Which Engine? Most people are going for the older VQ35DE, as it’s the most widely available, thus cheaper, engine. Nissan put them in the Altimas, Pathfinders, Quests, Maximas, Muranos, Xterras, and Infinity G35's / FX35's / M35's among others - depending, of course, on the model. Eg. SE, SL etc. Now keep in mind there are variances between these models. Some have different intakes, some have different heads and different transmissions. I’m not going to detail that, since we’re only interested in the RWD versions. You can get a VQ35 from a FWD or AWD car and bolt a RWD Tranny to it, but you may need to change some additional parts out which could cost more, but the initial cost may be cheaper. Buying a 350Z VQ35 may be a lot more expensive than buying an old Altima VQ35 (power limited) or G35 VQ engine based solely on the fact that it came from a 350Z, so consider that. The VQ35HR: Nissan only made the VQ35HR for 2 years in the 350Z, 07-08, so it's a lot harder to find parts. But that being said, it's an excellent engine (306HP compared to the 287HP of the DE). The plenum is side ported so it fits better in the car. The block is taller, but the plenum is shorter so height-wise it still fits in a S30. The Tranny is better internally, but it still uses the same concentric clutch which really isn't that big a deal. Replacement clutches are a lot cheaper now than they were 2 years ago. The HR does require additional Trimming on the S30 Cross member, because the Oil Filter is in the front on the right. Aside from that it's all about the same installation wise. If you’re going to go HR, You might as well go VQ37HR, they're more common (made for more years), 40hp more (~330HP), and fit almost exactly the same since they're the same block as the VQ35HR. You can get a VQ37 out of almost any G37 or 370Z. They're still not as widely available as the VQ35DE is, but the VQ37HR is an awesome engine. Really if you had the $$$$ and could find one, the VR38DETT would be the ultimate, but that's a rare animal, (and way too much $$$$$) But I digress, so with the VQ35HR (and the VQ37HR) like the DE, you still need the ECU/ BCU, NATS, IPDM and Key. It's still drive by wire so you need a gas pedal from the same year car either 350z or G35. The HR uses a 3rd plug on the ECU, so there's a 3rd harness you'll need. The Engine harness, the Engine Bay Harness and the Dash harness (body#1) If you can get these all from the same car, you'd be way ahead. The Dash harness usually comes with the fuse box. The engine bay harness includes the IPDM or at least the plugs for it. The IPDM is a computerized "smart" power management box, but really it's just the relays for things like the headlights and such. If you want to use the gauges, you'll also need the AC Amp. It really is better to buy a whole wrecked donor car, so you can just move the whole systems over directly and not worry about getting the wrong harness. Harness Mods: I know there are companies like Zfever, that can do harness mods to eliminate the extra harnesses and the BCU/NATS security. For many these work out fine, but I really have no experience with them. So look at their site and decide for yourself if you want to go that direction. Myself, I am planning on moving multiple 350Z systems into my S30, so I’m sticking with the stock 350Z harnesses. I would love to get the 350Z Cruise control working. As I understand it, Cruise only requires the ECU/BCU and the speed sensors on the Differential. Going with Stock also means you shouldn’t have to do any tuning / dyno work unless you want to. Gas Pedal: Any VQ gas pedal should work, but one from the same year car G35 or 350z should work best. I only know of one change in the gas pedal, between 04 and 05 they changed the module that senses the pedal, but the plugs are the same so I assume it'll still work. It's best to stick with the same year as the engine - just to be sure it’ll work. Procuring an engine: You might look first at the junkyards, and then if nothing is available there, put an ad up on craigslist or whatever you prefer, and see if someone privately has a car. You may be able to buy a 07 SE or SL Altima or earlier Maxima, pretty cheap with the DE engine. (Though you'd have to find a RWD tranny) Quest minivans are also cheap. (Note that some of these are ECU limited in HP) But look around and see what's available locally. Then if you can't find one, the next is so search JDM engine sources. (Japan has a 35K miles law that basically it's too expensive to drive something with more than 35K miles, tax-wise, so there's tons of good JDM engines being shipped out) Another place to look is into insurance auctions, a lot of times you can buy a wrecked complete car for $2K-$3K though most require that you bring a dealer along. Donors: It’s best to buy a Whole Donor, so not only do you know that all the parts once worked together, it’ll be a lot easier and cheaper to have all the little modules and parts (engine accessories like Alt, PS Pump, AC pump etc) for your swap there on hand, and much cheaper than tracking them all down separately. Your neighbors may not like it, so plan on at least a car cover. Once your swap is complete, you can part the rest or sell it for scrap. A note on this: If you don’t buy a Donor, you can still get a lot of the same parts cheaper from lesser VQ equipped cars, than the higher dollar 350Z/G35 cars. Eg. The MAF’s are all the same part number across most Nissan models since 2003. Eg. It's $60 for a Quest MAF, and $98 for a 350Z MAF, same part #. That being said, I still bought a lot of my parts cheap on Ebay, and from Turbo-Toys, who dismantles mostly VQ cars. Mounting: Well McKinney Motorsports makes a Mount kit which is pretty good. But it’s very expensive. “Why the expense?†is a different conversation. But you can make your own from plans you can find on the internet. Or, you and make your own custom mounts as someone here on Hybridz did. One part that will be common to all VQ swaps in the S30, is the “Modding the Steering cross member.†You’ll need to cut away half or more of the cross member and bolster the front side to retain the stiffness for your suspension and Steering mounting. For the HR, you’ll also have to make a cut out for the oil filter. You’ll also need to cut out the S30 Stock Tranny mounts in the tunnel, and make/buy a new Tranny mount. You may also need to mod the shifter hole to fit. You will also need to build/buy a Shift linkage bracket (Ahoke’s is really nice!) to shorten the distance from the shifter to the Tranny. (This is one argument to switch to the Auto Tranny version as the Auto is shorter and Drive by wire – Though the width I’m uncertain about.) You will also need to route the S30 steering shaft around the exhaust. Usually this is done by adding another U-joint and extension, (Mine came from the donor 350Z steering) and building a bearing mount on the left fender wall. There’s a lot more to this, but this is basically what’s required. AC and Power Steering: Air Conditioning. Well the Stock VQ location for the AC pump won’t work due to the Steering shaft. So either you’ll have to do without, Build a different bracket, or go with electric AC. The S30 AC system can be made to work, but would require complete disassembly and cleanout, then reassembly and recharge using modern refrigerant from the 350Z. (I was looking at replacing the 350Z PS pump with the 350z AC pump and making different bracket. Again that is a different project). Power steering, yes it’s possible, but it’ requires integrating it with the “Adding Power Steering†topics here on Hybridz. It’s probably cheaper to go with that electric PS system. Exhaust: You’ll need to make/buy a custom exhaust as the stock headers point right at the S30 firewall when mounted. Turbo/Twin Turbo: kits are available, but run in the $4K-$6K range. GTM is a good company. Of course there would be further costs and mods required to put them an S30. I recommend that you get it working in stock form first. Transmission: The 350Z’s come with either an Auto or a 6 sp manual. Really either one is great, the Auto has a lot of features like manual shift or automatic. The VQ37 also has synchro rev-match (2010+) available, which is pretty fun, where the ECU detects you're shifting and matches the engine speed to your shift, so technically you can shift without the clutch. Watch out though, if you get the engine from a G37x the x is AWD, and the Tranny won't work in an S30 unless you go AWD with it too, which is really expensive. I think the Auto Tranny may have a control unit, but I haven't looked into that much since I’m going Manual. I know the engine harness is different for the Auto. You can use an Engine / harness from an Auto with a manual, but not vice versa. The auto tranny reverse lockout switch would need to be bypassed. You’d have to source a flywheel/clutch, remove the flex plate and buy a new pinion bearing / Flywheel bolts. The early 03 / 04 350z manual trannies had some synchro issues, so look out for those. All VQ35DE Manual RWD trannies are interchangeable from 03 through 06. The 07-08 years used a JK Tranny with a different bolt pattern, I haven’t verified that the 09 + VQ37 Tranny will work with a 07 or 08 HR engine, but it should because they both use the same block. It's best to use the 350Z Clutch master since it's matched to the concentric slave. Differentials: You can use the Stock S30 R200, and should be fine, though the 3.54 gearing may be a little tall for you. 3.7 or 3.9:1 might make you a little happier. The 350z uses a Short nosed R200, with the timing wheels on the stubs. The timing wheels can be used to tell the ECU to display how fast you’re going using the AC amp and the stock 350Z electronics. You’d have to use a Ron Tyler (RT) type mount to install a short nosed R200. This is the same for installing a short nosed R230 from a Z32. Both have the timing wheels. Your Stock S30 Speedo won’t work with a Z33/Z34 Tranny. A LSD is available in both the Z33/Z34 and the Z32 Diff’s. The Subi LSD R180 should still work with the VQ’s power, but your stub axles are the weak point. Fuel: Most swaps I've seen actually go through the work to upgrade the S30 fuel lines. I'm not certain that's required since the 350Z fuel lines appear to be the same size. The VQ needs to be run either on a "dead head" configuration or on a return configuration. Either way, you'll need a good quality Fuel pressure regulator, and a stronger Fuel pump. I've seen people swap in the Stock 350Z pumps, and I've seen people use walbrough 255 LPH pumps. Both are workable. You'll need to research the different setups and decide what will work for you. My plan is to use a quart sized pressure container in the engine compartment with the input and the output to the engine on the bottom then a FPR and a return to the tank on the top. That way any bubbles float up through the FPR and my engine has constant pressure from before the FPR. Likely I'll use the S30 tank and an external walbrough. The 08+ cars are nice too, in that most use the key fob deal that with Bluetooth, allows for push button operation, so you wouldn't have to even take your keys out of your pocket. But that's another story. Now I realize this is really not much more than a primer, but it answers most of the questions I am regularly asked. I welcome constructive comments. Good luck on your projects. I would highly recommend for you to download the FSM's for the VQ35DE, VQ35HR, and the VQ37HR cars so you can see exactly what these components do, and what each system consists of. Being familiar with that will make sure you pull all the parts you want the FIRST TIME. Here are the FSM links: http://www.xenonz33.com/reference.html http://www.xenonz34.com/reference.html PharaohABQ.
Mark, Those Valve covers are SWEET!, I have done a bit of 3d printing myself, (prusa) bue I haven't made anything as cool as that. Were those printed with a resin photo 3d printer? Your resolution is pretty nice, not to mention the overhangs. Thanks for raising the bar yet again... -
Well that'll be good to know, I hope you're right on that...
Taco'ed my car, haven't been around a while
Pharaohabq replied to clutchdust's topic in S30 Series - 240z, 260z, 280z
Any update? Pictures? Ins issues? -
You may also want to contact the US embassy to make sure you won't have any issues Re-Importing it back to the US when you return. It would be a shame if you couldn't bring your baby home after having it out there with you.
Driveshaft removal, NOT the bolts
Pharaohabq replied to noelawinslow's topic in S30 Series - 240z, 260z, 280z
No, so long as you stick to hitting the flange with a "soft" impact tool, you should not damage it. besides if you destroy it, then it's an upgrade opportunity. CF or aluminum -
There's a lot of reasons it may not be starting. but yes, a little more information might help us give you suggestions without too much sarcasm. As NewZ said, when was the last time it ran? By not turning over I assume you mean it won't start, not that it won't crank over. That alone tells us it's probably not the starter or frozen engine. So the more info you can give us the better. Pull the plugs and see if they're wet or dry. (I'd bet wet) so try pulling the plug off the thermotyme/cold start injector and see if it'll catch. If that doesn't work, pull off the hose from the air cleaner, and see if you can push the flapper on the AFM, it might be stuck. Try starting again. Let us know what you find out. Also, how about some pictures? I need stimulation, I'm falling asleep over here. (Yay me! this is my 1400'th post!)
