Richard Oben
4
Everything posted by Richard Oben
TrackZpeeds CXRacing LS1 T56 240z
Richard Oben replied to trackzpeed's topic in Gen III & IV Chevy V8Z Tech Board
LOL At video. -
Richard Oben LS1 series 1 240Z build
Richard Oben replied to Richard Oben's topic in Gen III & IV Chevy V8Z Tech Board
Landistitman I can't remember who made them. I will try to find the receipt, I looked once and had no luck. I did it both sides the same sides, which now I have the Z car depot it is a tight fit on the driver side. I agree with you finding off the shelf stuff is a no go. Bo, all CX racing. I have a T56, no idea if the auto would work. The whole kit, Headers, mounts Exhaust all the to the bumper. JCI is a bit weird about payment, once the initial purchase is done, ac mount for me. He was very helpful with the rest of the stuff. Like senders etc. -
favorite rear diff with 5.7 LS1/t56?
Richard Oben replied to 570Z's topic in Gen III & IV Chevy V8Z Tech Board
8.8 in mine with 3.73 gears and an 04 GTO T56. The problem is each person has basically one experience. It comes down to what you have and what you want, all of our opinions will only get you an average. JMHO LOL Richard. -
Well, I drove it around yesterday. I appears the vibration is gone. got up to about 70 in the neighborhood. I thought something was wrong, the car didn't accelerate like i remembered or thought it should. Well cold tires cold road and I figured out the problem, Speedo said 50 car acted like 20, wheel spin, a lot of it. No more clunks in the rear, really no issues at all. Very happy with the mount swap. Now on to struts and springs. -
temp sending unit ls1 to 240z gauge
Richard Oben replied to ben a's topic in Gen III & IV Chevy V8Z Tech Board
I used the John's car conversion kit. In the block of the engine it went, there was a removable plug there, did have to cut a hole in the CX mount for it to clear. With the AC I had not choice, we ran the temp for the computer to the pass side. HTH, Richard. -
That was just more work than I wanted to do. Huge project. A vendor is working on an 8.8 complete set up coming soon. Richard. -
Toolman. Cost is a bit fuzzy. To buy the mount from Z car Depot is about 700 by the time it is delivered. We have done a lot of 8.8 stuff so I had the pumpkin and had the gears. I would not use the Lincoln, I would use the recommended explorer. We had the 3.73 gears already and they work well with the T-56. We bought the 930 to 8.8 stubs, the 930 to 240 hubs, axles, CVs and boot kits all separately and If remember correctly, all that stuff added up to a fairly expensive list. But done only once. No idea how many are out there. It was a preference for us, we did not want to go R200 or R230 or what ever. We have 280 stubs for it so everything will be 28 spline when finished. New zed, Our axles were not perpendicular before, too far up and too far forward, but they are now, and better in both directions, visually perpendicular in both directions. We also used same length axles on both sides. The driver is a tight fit, I can still shift the axle in and out, but I will watch it closely. The pass side is fine. In retrospect I would have done the right mount (didn't exist when we did the swap) and then measured for the axles. When I do the struts, brakes etc. we may shorten the driver side at the same time. Re notch for the clip and cut the current clip groove off. HTH, Richard. -
8.8 IRS questions? Who is happy with what mount?
Richard Oben replied to Richard Oben's topic in Drivetrain
Updated -
So we decided to update and upgrade the rear mount. We bought the Z car depot 8.8 Ford IRS mount system. It is a nice nice set up. Only problem, not built for a 240 or really for a Lincoln Mark 8 differential. No problem, well a few problems. First thing we did was install the mustache bar mounts. We shifted the diff forward and took off most of the rear mount hardware. Sway bar had to come off, uprights had to come off. It would have been better to start from scratch. Second thing we did was install the rear diff mount; It is a little low but it helped a lot. Our axles were too angled and the diff was too far forward. I would highly recommend using the cover Z car Depot sells. It fits like a glove any other mount would likely not fit. Since the mount if for a 280 We had to drill new holes to line up with old strap mounts. In the pic the original holes are very far apart, that would not work for us. On the upper mounts we used Nut inserts. These use a special tool, I didn't have the correct size so I used an allen wrench and a really good washer and a spacer nut and a regular nut. We also had to remove some of the sheet metal that had been folded over. This pic shows the mount installed on the Pass side. The top is Nut inserts and the bottom is the factory strap nuts. Last but not least we used solid mounts for the front as the Lincoln is much smaller on the front eyes than the Explorer. The top is also sandwiched but it is had to see. On last look from the front of the car. If there are any questions. Fire away. Richard. -
From the album: Richard Oben
I will probably follow up on my post in the LS forum FYI. I will take some pics later that show the mount. To answer your question the diff is not anywhere near as low as the exhaust. Shouldn't be an issue. Working on front mounts today. Richard. -
So we bought the Z car depot mount. Fit is tight, but really a nice part. It did exactly what we needed, moved the center section down and back. Front mount will be a challenge, NOT an issue with Z car depot, they built for an explorer, we have MK8, and they built for series 2 and later cars, we have a series one. Thanks for looking. Richard. -
Heavy Duty frame rails and connectors
Richard Oben replied to toolman's topic in Gen III & IV Chevy V8Z Tech Board
Might consider one of those tent with doors for cars. With a little creativity you could make a booth out of that pretty easily. Just thinking out loud. -
Built a LS1 - T 56 1971 240Z and love it. (build thread on the gen 3, 4 forum) We already had an 8.8 out of a Lincoln MK VIII (IRS) and we cobbled it together with a home made really rough mount on the rear and a T-3 front mount. NOT happy with it. We have everything else in and working, Drive shaft, half shafts, hub adapters, CVs, everything. Drove it 1,300 miles on the HOT ROD power tour. Why we don't like it: It is too high, Lincoln cover gets in the way of lower control arm mount, so we can't lower it. We have a vibration and believe the is the home made mount is not straight enough causing a U joint vibration. T-3 mount is not in line with my mount (not T-3 fault in any way). Over 75 mph. clutch in or out, engine at speed or idle it vibrates. How many people have the Will Fritts' stuff? Are you happy with it? A Vendor is working on a similar type. Z Car depot Who has it? Are you happy with it. Sunny Z did his own. Did anyone copy it? are you happy with it. Explorer rear cover mount? Like Fritts Standard 8.8 rear cover? like Spitnaugle. SVT rear cover? like Z car Depot. Going to buy something really soon and don't want to buy a bunch of stuff twice. The rear cover and mount are totally different on the design of the mounts which is why I am asking. Please, please reply if you HAVE THIS IN A CAR. I have read a lot of opinions and not a lot of facts. Thanks for reading and replying in advance.
I did a bit of google search stuff and the later models (10 speeds?) were co-designed by both ford and chevy so it will be a better likelihood that it will fit the LS over the Ford 6hp. Not sure anyone needs 10 speeds but we never thought we would need 6 either. PS I just love my T56 but I am just a 3 pedal guy. These days autos are faster and as efficient but I just like rowing the gears. HTH, Richard.
Any updates? Price? Time frame? Front mount progress? Let us know. Richard.
Probably better answered in the gen 3 4 section. Almost everyone uses an aftermarket master and swaps in the datsun push rod. Even then it take a little work HTH, Richard.
Great news, congrats on seeing it through. What a hassle though, nice work. Richard
