Richard Oben
    4
Everything posted by Richard Oben
  1. Richard Oben
    From the album: Richard Oben
  2. Richard Oben
  3. Richard Oben
  4. Richard Oben
  5. Richard Oben
  6. 205 tires on the rear, I definitely need more tire. LOL. Thanks for the input. Richard.
  7. Update time. Over the last few weeks, we replaced all the struts, all the springs, added rear stubs from a 280 (28 spline vs 24), added rear discs, added adjustable rear arms, shortened the driver side axle and got it all back together. Holy cow was it a lot of work. Pulling apart old (really old) stuff was easy when I was younger. I try to post a pick or two. My question is every LSZ tail happy? We used Eibach springs, KYB struts, Big front bar that came from another Z and an ST rear bar. This has alway been a street car, just trying to make it a little more predictable. May have to mess with alignment some more and/or remove rear bar, lower rear pressure. Any thoughts. I posted here as we are the LS Z crowd.
  8. Well we took Leslie (LSZ) out for a local autocross. I have always planned on keeping this a street car AC and all. But holy cow is this thing tail happy. My set up is Eibach springs, progressive on all four corners, I have tokico on the other car and like the eibach better. Big front bar and ST rear bar. All with KYB street struts. Should I ditch the rear bar and see how that helps? I guess my question is your set up completely all race stuff or is it more street and then race.
  9. IN the CX pictures it showed mounted all the way back, unless the parts changed. Remember I bought the complete CXR kit exhaust and all. Some others may be more forward and did their own exhaust. I did have to trim the tunnel just a little to make the CAMARO shifter work. The GTO shifter was not even close. Literally we had it all in and tried to put the transmission mount in and the bell housing hit the hard lines for fuel and brakes. I could have beat the tunnel and probably made it go further back, but did not. Also I am not sure if it means anything but I have a series one 240Z. Also, I am at 2 degrees down on the engine/trans combo. HTH, Richard. Bo, absolutely no problem on asking more questions, I know I asked a lot before I got mine started. Richard.
  10. On the CXR kit it is intended to go in the furthest holes back. My problem was it couldn't, the lines at the front of the tunnel got into the back of the bell housing, so it went one hole forward. The exhaust is now tight but it fits. If there is any way to get it as far back as possible it would help in the long run. JMHO, Richard
  11. You, sir have been very busy. Richard.
  12. Someone asked before. We found the receipt RBP manufacturing out of Anaheim. $290 Dollars. HTH. Richard.
  13. Yup, went from no brakes to great brakes, new booster was magic. Keep it simple keep it easy. Richard.
  14. Sounds like the regulator is bleeding off the pressure. I could be easily wrong, but the key several times helping is a good indicator of faulty regulator. HTH, Richard.
  15. Man what a lot of work, the work is well done too! My only question is was a good shell not available? Richard
  16. If stock worked for this long go back stock. I have the WW MC and have the stock booster. Make sure the plunger measures the same on the MC side. Don't ask how I know.... Richard.
  17. The side windows un bolt from the regulator. Pain to do but not bad. Hard part is getting it all back in, one of those hold your tongue just right moments. Richard.
  18. Get your favorite bottle of whatever relaxes you. Lay down close your eyes think of nothing, empty you thoughts as much as possible. Then in the first sliver of conscientiousness what color is your dream car? Don't over think it. JMHO. PS we have this problem with lots of guys and the FFR color choice. LOL.
  19. JCI is still there, the money policy is odd but the service is good. Richard.
  20. The vette will be a T56 with a Diff no tail shaft, to speak of. It is the same only different. Sometimes a good deal may or may not be one. JMHO, Richard.
  21. Bo, like I said in the other post. My CX kit was fine for my 6 speed. If JCI works with 4l60 use it. Order form is odd but all in all a good guy. Richard.
  22. Frame connectors are in your future. Nice stuff.
