Richard Oben
4
Everything posted by Richard Oben
Small update. Have not driven either car yet. LOL. Did get the Eibach springs from the LS car to the standard car. And the 5020 Tokico springs on the LS car. Also got the center section (3.73) back in the LS car. Everything I have read says the KYB in the LS car are just not great, even with the Tokico springs, which is OK because they were very cheap. With a birthday coming up (excuse) I am probably going to bite the bullet and get the externally adjustable Koni strut inserts and be done with it. If added up the Koni and KYB it would add up to the coil over set up so anyone who wants to, can say I told you so. Finally got the MC for the standard car, after 3 attempts so it should go on tomorrow and then that car should be good to go again. Tokico blues with Eibach progressive springs. The LS car will have to wait a bit for the Koni inserts to be back in stock from Motorsports Z (two weeks?). They are externally adjustable, and the pain of putting them in later is worth the wait I hope. After all the work, just do not want to do it a 4 time or more. Car is a blast to drive but chasing all the little stuff is getting old. Stay positive and be (covid) Negative. Richard.
TrackZpeeds CXRacing LS1 T56 240z
Richard Oben replied to trackzpeed's topic in Gen III & IV Chevy V8Z Tech Board
Great pics. Thought I saw them on FB. Richard. -
Thanks. Bump steer blocks on the list. The car with the Tokico already has them, the Tokicos are not adjustable in my case. 14s on the LS car for now, so lots of side wall. I have other issues setting my time line back so an extra 30 is OK. Plan on swapping springs this week. Also doing other things while the cars are down. Fix MC. swap gears in LS car etc. etc. Thanks for all the input. Richard.
NewZed, I know that by definition we have a coil over strut set up. Just trying to avoid the new set of dollars I have to throw at it. I have been looking at the silver mine motors set up. but did not really want to cut and weld on 50 year old parts. RebekasZ I know what you are saying. Again no real want to cut and weld, But I agree it would be silly to put another set of springs I do not like on the car. Changing springs for Autocross vs street or at least adjusting the dampers does have some appeal. Keep the answers coming.
Have Tokico springs and struts on a very stock the 240Z and Eibach and KYB on the LS1 powered 240Z. The Tokico are a bit too rough (for me), the eibach are a LOT too soft. Both cars have the same big sway bars front and rear. Looking for ideas on better spring options without going to coil overs. Did the Eibach and KYB when in a bit of hurry to get the project done a couple of years ago. The 240Z guild uses one Vogtland on any modified cars, any thoughts? A buddy has BC coil overs on one car (Subaru) and Vogtland on his 280Z he finds the V better for the street on his 280Z. I know not the same car 240-280. Just looking for opinions. I thought about just taking the Tokico and Eibach springs and swapping them, which is probably what I should do since I have both. But the LS is a pure street car for me and would like to keep it that way, without being to harsh a ride. Thanks for reading and replying. Richard.
280Z GenV L83 Swap
Richard Oben replied to Fridge Gnome's topic in Gen III & IV Chevy V8Z Tech Board
Looks like the GTO shifter is about 3.5 inches back from the camaro shifter plus the 3/8 spacer. If the engine is in that neighborhood further forward it will be close. The 2.5 looks good too. I wouldn't slam the hood yet but a good start. HTH, Richard. -
280Z GenV L83 Swap
Not using the same engine but we are using the same trans (04 GTO LS and T56) The shifter will likely need to be changed. Can't remember how far the GTO shifter is behind the Camaro one I used but it was a lot. This may help with the more forward engine but it will be something to consider. lowering the engine seems mandatory although the Datsun hood has a lot of clearance in the middle, solid 4 inches above the fender line. Looks high in the pic. Keep us posted, cool project, hope problem solving is fun. I found a lot of good info here even not following the 'recipe'. HTH, Richard. -
Help: Fuel Setup Stock Tank 280zx
Richard Oben replied to OldZNewLife's topic in Gen III & IV Chevy V8Z Tech Board
So sucking through the stock pump? I would swap or make the stock pick up just a pick up. JMHO. Richard. -
The stock ZX pump is not likely strong enough or big enough to run the LS. That being said if the hard lines are big enough swapping to a larger in tank pump should work. The regulator should be fine as long as everything is rated for the pressure and fuel. We did it totally differently, on a 240z. -
Great work, glad it finally got more work done. We kept the factory GTO surge tank. Ugly but never had any issues burping. Vent from radiator and steam vent both T into Surge tank. We also kept the T in the heater hoses that feeds the surge tank. Similar to this. We only have the surge tank not the overflow. Way back when we had a heck of a time burping the FFR GTM. Keep at it, way to far ahead to stop now. Richard.
Plug and play wiring harness
Richard Oben replied to DAT240Z's topic in Gen III & IV Chevy V8Z Tech Board
We used a dieted donor harness. Power, IGN power, Fuel pump, fan, ground and a few others like VSS and AC, in and out at my request. I know that is now what was asked for but it may help in decisions. -
Heavy Duty frame rails and connectors
Richard Oben replied to toolman's topic in Gen III & IV Chevy V8Z Tech Board
Nice work on the fender filler panels for flares. In all the threads on flares not one has done as nice a job documenting the process. So thanks very much. This is going to be a killer car, really good work. R -
Possible LS 280z project need help and advice
Richard Oben replied to 280z-racer's topic in Gen III & IV Chevy V8Z Tech Board
Sounds like a good plan, with a good shell. We did the Bad Dog rails, which help a lot. Start a build thread, at least we can help if we can see what is going on. I can personally say there is no way I would have attempted the project without this forum. There are guys here who are very helpful and extremely knowledgeable. If there is 'what should I do now' question, search and ask. The 240 probably has a R180 and 24 spline hubs, if leaving them in be very careful, they could be the weak link. Richard. -
Get comfortable and read, read, read, read this forum, then read it some more. Most don't use the entire F body harness, lots of weight and complexity that is not needed (we used a new aftermarket 8 circuit chassis harness). Some do use AC, not sure if anyone facilitates the stock F body compressor. There is a solution for the stock mount with a smaller compressor. What is the budget? Thinking 'we got donor the car, all that is need is the 280z shell' is the path to madness, both mentally and financially. A lot of people will say it can be done for $5k or some silly crap. Find out how many they have done. It is a big project, lot of 'while we are in here' stuff comes up like rear end, Limited slip? axles stubs, springs and the all important etc. Good S30 Z cars are getting harder and harder to find and even harder to find inexpensively. All of the above is just a caution. DO IT, it is so worth it, keep the LS stock to start with. Stock power in a 2,400 pound car is hilarious, we have driven several thousand miles at this point and all of them fun. All of the above is only my opinion. Having done a total restoration on one 240 Z. And one 240Z with an LS1 6 speed conversion. (FYI, I spent about $17k on the LS car and did it as cheap as I thought was safe. no paint, no coil overs, nothing fancy) Trackzpeed and I both have build threads here, his is much more comprehensive than mine. HTH, Richard. -
Relentless - 1977 280z LS (5.3l L59) swap
Richard Oben replied to Box5's topic in Gen III & IV Chevy V8Z Tech Board
Nice job especially the exhaust work. Great job. R -
CX Racing 280z LS install issues ??
Richard Oben replied to boostfed's topic in Gen III & IV Chevy V8Z Tech Board
I did the CX and there were several tweaks needed, I just bent the mounts, transmission mount needed tweaking, some of the stuff is the differences in the 240 to 280 stuff, i think they originally did 240 only, but a 72. Added to that, mine is an early car, still series 1 and a lot of the little tweaks were because of that. All in all though still pretty happy with the set up. Don't let this small stuff bug too much. It will be fine in the end. JMHO. Richard. -
New to the Forum... Just got a 260Z Shell
Richard Oben replied to gitnmybelly's topic in Gen III & IV Chevy V8Z Tech Board
No idea if this is it but it might be the one someone was talking about earlier. https://www.dirtydingo.com/shop/product_info.php?products_id=1720 HTH, Richard. -
Mine is on driver side. There is now a small compressor, someone on this site has it, that fits in the stock location. Google may be faster than searching Hybridz Sorry not to be of more help. Is there an issue with the driver side mount compressor? R
