MrPhotographer06
Everything posted by MrPhotographer06
Excited to see this turn out. Considering adding it to mine in the near future now the cage is installed.
JAWZ240Z LSTT S30
MrPhotographer06 replied to MrPhotographer06's topic in Gen III & IV Chevy V8Z Tech Board
4 weeks. .jeez! Not much done.. This Army thing takes a lot of time. I mainly worked 3-11 which makes it hard with anything else in life. Front framerails are capped, lower core support finished. Bought wheels, mounted front tires and man.. i should've gone with about 1.5" more BS lol They will work for the time being, but shortly will be buying a second set of wheels with stickies. Front crossmember is halfway done for mounting my double wishbone. I'm sorta stumped on making my LCA's with such a wide triangle that I may be re-engineering some things. with my PS rack clearing the oil pan, and still getting a u-joint angle I can manage with turbo downpipes backtracking the manifold. Lots of thinking to do as I build the back half of my lower crossmember this weekend. My spindle upper ball joint holes will be reamed tomorrow and I can officially order the UCA's. I'm using the slotted mounts for total adjustability with circle track arms. Once the LCA's are on, I'll measure for coilovers! IF I get the wheels on the ground next week and trim removed, I will be taking it to the body shop on Saturday. As of 8 days out, I'm uncertain i will make it lol Photos to come! -
Go for it. A 35 is more affordable than a 37, but both have their advantages. I just sold my 07 350 to get a tow rig, but I wouldn't go below an 07. The VQ35HR is an awesome engine. All the DE owners claim they are equal but if you've ever driven both.. You'll know the difference. Handling on the G platform is supposedly equal to the Z but the sedan has a little less IMO from the track day opinions I've heard of sedan owners. That being said, get what compromises your budget and desires. The "cheaper" versions of the G I disliked such as the X but I'm mainly partial to the Z platform and its legacy so a G coupe is pushing it anyway lol But.. As far as the VHR and HR engines go.. Outstanding. Can tastefully modify and still get good MPG. Wife's Bolton 350 gets like 27 highway. Also road courses all summer. Go 6 speed.. CD009 is where it's at, but the auto seems a little weird to me. Again, Z fan with spirited work commute. All in all, can't go wrong with either. G37's can me made sweet!
This is awesome! Will be doing the same here soon for the 240z with my new mustang rack!
So as some of you have seen, i'm building a LSTT Z. I got a camaro plastic tank for free, and without really thinking, I cut the evap stuff off. So I gotta come up with my own. No vent line to the front,but I'm guessing i'll run a line from the center port on the tank to a looping vent line. I read RebekahsZ's post about running a loop up and back down from 2012... Any other ideas?
GC 280Z is now too low.
MrPhotographer06 replied to kerrys914's topic in Brakes, Wheels, Suspension and Chassis
I too am running a 25" tire. 25" Tire Diameter165/80R15 = 25.4X6.5R15 185/70R15 = 25.2x7.3R15 195/65R15 = 25x7.7R15 195/70R15 = 25.7x7.7R15 205/65R15 = 25.5x8.1R15 215/60R15 = 25.2x8.5R15 225/60R15 = 25.6x8.9R15 265/50R15 = 25.4X10.4R15 275/50R15 = 25.8x10.8R15 These sizes are in range. https://tiresize.com/height-chart/ Two cars here both running 275/50/15's. 10mm isnt enough to get upset over.. i mean look at a 10mm wrench... -
Will view more of the thread to see which fits best.. 4/4.5 lol
What's the sale price?
JAWZ240Z LSTT S30
Brake Booster: 1980 ZX Booster and MC? I will enlarge holes to make work on my 71 car.. but is this competent? NEW SS lines front to rear. Willwood rear 4 POT from the Fritts IRS build... and S10 Blazer 2 Pot rear (for now) until i find something nice. -
JAWZ240Z LSTT S30
Well, in the last few days, I've been in and out and the pollen has taken over! I've had to chase the leak on the 6.4 tow pig in the meantime. Anywho. Tacked the crossmember. I gotta grab another spool of wire to finish out, and with no backflow Argon flow, hard to TIG that up. I just TIG tacked it in. Got some new parts in, Ball Joints, Sleeves, Coilover Mounts for the LCA and inner bushings for the LCA's. Today the Engine mount plates came along with the slider boxes for UCA mount, pics to come tomorrow. Ordered Mustang II Power Rack, and cross-shafts to keep the sliders square. I hate to order the shafts without the arms.. but i'm unsure of the length I need at this moment. 4130 tubing inbound next week along with another 2 sticks of 1" tubing to build the crossmember. going very basic with bolt in plates i'll weld to the frame similar to the Hawk's motor mounts so the X-member will come out. Also mocked up the hot side! Taking the lady to the airport in the AM, may not get a chance for much before working at 3. Going to still give making the mounts a go. Monday should be productive! -
I was acutally comtemplating cutting a hole in my lower framerail and doing the EXACT same thing for making my new tubular crossmember a bolt in thing.. glad to see someone else has proved it works.. lol looks awesome! If you're ever in need of any paint, body or metal work.. Hit up Brent Click at Hyper Formance. He's in Greeville. Tell him Scott sent you!
- 51 replies
- swap
- motor mounts
- (and 8 more)
JAWZ240Z LSTT S30
JAWZ240Z LSTT S30
I like that part as well.. Eager to get it in! The side parts to the front crossmember are done, then ran out of wire ): -
JAWZ240Z LSTT S30
Nice, I had already cut my horizontal bars, but i'll be doing a similar setup for the bands.. I cut my evap shit off without really thinking about it... lmao -
JAWZ240Z LSTT S30
Can't find your post.. Link? -
JAWZ240Z LSTT S30
I saw the trunk was a little different. I'll have to dig through and find your thread. -
JAWZ240Z LSTT S30
Well I got the metal today to make the fuel tank bracing, motor mounts, a 1.5" square tubing crossmember and a couple other odds and ends. Also ordered the remainder of my engine assembly parts aside from head gaskets, intake gaskets and oil pan gasket. Figured id save the money until we figure out the turbo drain situation. OSCS, Ricki Bobi, De Meanz, or Michael AKA (guy with white 280z) whatever you know him by.. I was able to pick up 2 of the 3 cold side piece of piping from his setup as he went A2W. So thats on the way. Got the Blazer Spindle/Hubs en route! Lastly, ordered screw-in ball joint sleeves, and screw in upper and lower ball joints for the custom control arms. Lowers will be fully custom, and uppers will be cross shaft with swedged tubes for circle track cars. If you're not on the facebook page, get there! www.facebook.com/jawz240z Lots going on with the car in the next couple days and weeks as I'm desperately trying to meet the new goal deadline of June 25 as a debut date! I'm leaning towards doubtful, but if I can make the money work, I will get it done. Going to focus on getting as much done in the front end as possible, finish sheet metal, take it for primer and wrap, then assemble drivetrain. As long as it starts and looks pretty at the debut, I'm down with that! Here are a few photos. First is another member here, cant place their name; I'm going with his basic setup for the camaro fuel tank. My poor hatch rust I still need to order a panel for. The clean cut Spare Tire Well and the Locust Roadster LCA i'm mocking for the build. Definitely going to add gusseting all over. -
JAWZ240Z LSTT S30
The owner of the mount i posted shared his front mount with me. I cant post pics, but he essentially lined the trans tunnel with plate, then made a C to mount the front ear with. I am thinking about making more of a clamshell with a solid piece above the front mount ear to hold it down. -
JAWZ240Z LSTT S30
Me too.. Diff is a little further back on my list, but it'll be soon. -
JAWZ240Z LSTT S30
JAWZ240Z LSTT S30
"The tube for the mustache bar is made of 1" square tubing 1/8th thickness. For the front mount, two 1/4" plates were welded to the car where the stock front mount was located (the red arrows in the pics point it out). Then another 1/4" thick plate was bolted on so the diff mount can be removed. " -
JAWZ240Z LSTT S30
Not mine, but the one I'm building. I will get metal specs this weekend and share. I really like that it's one piece. -
JAWZ240Z LSTT S30
Here the 8.8 mount. No front mount yet, but seems like it'll work...not sure how I feel about it yet, but I figure 4 good welds on each side of the mounting surface to the mustache bar mounts are better than 4 bolts... Maybe. -
In awe at this project... makes me feel that i'm doing mine way wrong lol Nice Job!
