DuffyMahoney
Donating Members-
13
Everything posted by DuffyMahoney
3.2L engine parts arrived from Rebello today! JE Pistons, Eagle rods and king race bearings. Rod bearing clearances are spot on. Marine Crank did a fanstatic machining job on my extra long stroke LD crank.
Probably my favorite engine swap in a Z
Engine builder is removing the casting flash and de-burring the block today. Getting ready for Glyptol coating. Pretty neat.
Well we finally got a block that passed sonic testing. It took 4 to get one that can handle the 88.5 pistons. N42 for the win! Thanks Andrew Kazanis! It’s going to be a sweet motor.
Not keeping the intake ports rough. They are done already. Flow data is attached. Valve guides were left in during porting then replaced after by a machine shop. I don’t believe the chambers were touched. But I will ask Andrew (engine builder) I went through 4 E-31 heads before i found one that was cast nicely and no flaws.
I did the dsi valves. Nothing was done to the chamber. But I installed dsi valves. Lots of port work though. Flows awesome.
Well it runs, but terrible. I have a massive vac leak, either from my balance bar not sealing or maybe a throttle body wasn't bolted down correctly, I had issues with one not seating well. Even with throttle plates in the fully closed position it runs happily at 900 rpms. So it's getting a ton of air from somewhere.
Haltech elite 750. I will set the butterflies first. Then I can still use the iac for a rock solid idle. But it’s normally perfect.
Warm I want the valve almost 0% open
Pretty neat feature. I will try to set warmed idle at butterfly’s and at the ITB air bypass screws. Hopefully i can leave the IAC adjustable bleed closed
PCV question. This isn’t a debate about the need for a PCV vs a catch can. I want true postive vent. I decided I want to use my exhaust to pull the fumes out, to keep the dirty fumes out of my intake. But since I have Fujitsubo. I have true dual exhaust. Is plumbing to one good enough? Should I still use the stock check valve? I would guess it holds back a tiny bit of pressure before popping open? My plan was to weld this bung at a 45 just past my o2 bungs on my exhaust. With the stock check valve in line.
My comment wasn't directed at you.
Well I wanted it flawless. So it takes a while. my system uses the exact pumps and nozzles as the top system on the market.
Well the 80s bmw iac is awesome, smaller and nice looking. Let’s no air or minimal amount by when physically closed. Now to find out what pin is positive.
It probably took 5 hours to vapor blast all of it. Lots of surface area.
Thank you so so much. Ordering now
Internet is coming up with zero on the plug.
I bought the vdo. Thanks for the help! Now I need to find a pigtail first the harness
No throttle blade on any carb or throttle body that I have seen is designed to seat 100%. On carbs that I have rebuilt you can see damage from people trying. I got it to run and idle down, but butterflys stick almost fully. I will fix it right and get an IAC that closes 90-100%. Really I want the IAC off after it's warm. OEMs that do ITB use a large balance log just like this, bmw etc..
It lets zero air go by?
It’s not about air. But I could have gotten away with a 8mm hole im guessing.
Thanks!!
