DuffyMahoney
    19
Everything posted by DuffyMahoney
  1. Finally figured out how to get the vac tube to clear the linkage. Last piece of the linkage puzzle is done IMG_2779.MOV
  2. I actually have no idea, thats at the engine builders.
  3. Well the plan works and i finally found time this am to finish it. Balanced vac, pcv, hidden wires. All with vintage SK ITB. Why do I do this to myself!? Gosh I love to tinker. Now to see if she will run again, which the neighbors love.
  4. No, I don't have a solid plan for that yet.
  5. Tioga knows his stuff. The whole setup looks great Derek! I want to own one someday.
  6. My new current pcv plan. Slightly filtered, oil catched then back into my throttle bodies vac balance log. I will figure out a better filter later on.
  7. Stroker is ready to drop in! Now if I only had some extra time IMG_2282.MOV
  8. Or roughly cnc porting and hand finishing. The Cnc port work coming out is amazing.
  9. I went with clear anodized fuel fittings. I think it gives it a vintage look. My fpr mount works awesome.
  10. I think this ITB vacuum balance bar will work and look good. It’s far enough way from the header in this spot as well.
  11. Next hurdle is a hidden vacuum log for my ITB. My plans for a billet clamp won’t work with the stock hardware. But a simple cushion clamp should do the trick. Next is welding 3x 1/4 hose barbs onto my 5/8 OD aluminum pipe. It’s been threaded to -6 orb on each end. With the plan to use iac at some point.
  12. Now where the heck do I put this.
  13. It means a lot coming from you bud. I was hoping to test fire today. But somehow I lost one of the swivel vac fittings, dammit
  14. I have never drilled a hole in my low miles series 1. That’s my goal to keep going.
  15. I love making/ designing parts! I think it’s my favorite part of this strange hobby. This is a zero hole in my car EFI FPR mount. Next I will have it cnc cut. This is just 3D printed. Draw, design, test and make. So much fun. I really like how simple this radium fuel pressure regulator is. Uses a Bosch top. Very well thought out.
  16. Spacers are done. This should work awesome
  17. SK ITB update! Fuel rail is looking sweet!
  18. So either coil packs or coil on plug. I am using R35 coils, lots of people use the LS style coils with good success. Crank sensor is a bit up in the air. Does your dampener have an ability to add a trigger wheel?
  19. I love it when a plan comes together. Happy Friday! Vintage SK ITB is coming along nicely
