Jboogsthethug
Everything posted by Jboogsthethug
  1. Thanks for sharing that link, that may prove to be super helpful! As far as the ECU, it is the stock ECU but I plan on upgrading at some point so no worries. And unfortunately I'm not sure. It was pulled from a 240sx and has had all the identifying parts (that I know of) replaced with aftermarket parts. But I figure at that point it doesn't really matter regardless, does it?
  2. Unfortunately not yet. I've been focusing on getting a few house projects finished. Moving forward I attached everything I could find a port for and I'll try to start it and just see what codes pop up. I'm thinking they are things that were deleted by the engine's PO but I'll find out for sure at that point. Once I get it narrowed down I plan on marking the unused ports and then rebuilding the harness to fit correctly while also getting rid of any excess plugs.
  3. I never got any specific answers as to why but I can upload things now. I think I was able to a few days later if I remember correctly.
  4. Ok that's like exactly what I'm looking for! Thanks amigo! I'm going to spend more on this than anything else I've bought so far it seems ha.
  5. That's great info, that points me in the right direction! So if/when you get the AIM PDM are you just taking out the racecapture? Maybe I'm just not seeing it but it seems like all of AIM's displays are also dataloggers aren't they?
  6. I am very interested in seeing how this pans out. For some reason i can't seem to find any threads that have the swap 100% done (though I can see that they are out there as people reference them). I'll grab some popcorn and watch you finish it in this build!
  7. So I'm active on the 240z subreddit and a fellow enthusiast on there was giving away these sweet original brochures from Sweden or whatever. I messaged him and he sent them over, what a great guy! These were pretty cool to get. I plan on framing them and hanging them in the garage.
  8. Very interesting. Does the subframe swap just give your rear suspension better geometry overall? Just curious why people swap it out if they're not doing the AWD or something.
  9. Dang what a great find!! That's awesome man! Your thread has so many posts about documents it's like a mini history lesson. Pretty cool!
  10. Dang this is looking good! Is that an R32 subframe? How hard is it to fit in? Also, you're not doing AWD are you? Just rear?
  11. Man I can't believe I've never seen this thread! So stoked to find it while it's nearing completion! It's looking awesome so far!
  12. @Boben Good suggestion! I'm sure I'll apply something like that to it to make sure I don't suddenly lose all my oil! And this is the exact one I bought: https://www.ebay.com/itm/Universal-Intercooler-25X12X3-2-5-Inlet-Outlet-Toyota-Acura-BWM-Audi-Honda-Mazda/161332406851?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 It's now $1100 apparently which is crazy because I paid $78 bucks for it ha. I was able to use the 90 degree rubber and it fit perfectly! Like a glove, no cutting needed! Any bigger would definitely require cutting I bet. The openings are 2.5" FWIW.
  13. Hey Ben, what are your thoughts about your digi dash setup? Do you like it? Do you wish you did it differently or are you happy with it? Also, if your engine throws codes, it doesn't show up does it?
  14. Note: One problem I had with the low pressure pump is they no longer make it and so I couldn't get a replacement for the little weird bolt it had. These were stripped and the threads were so small that it didn't instill confidence. So instead I made my own substitutes with some threaded rod of the same diameter as the smooth piece that fits in the rubber grommet and a few nuts placed around. Worked perfect! I do have reservations about it cutting through the rubber but I figure it won't cut completely through, only as deep as the threads.
  15. So the last I updated about the fuel I was trying to make the stock tank work. After fiddling around with that for a bit I decided I'd rather just get a cheap fuel cell and run with that! So here's the cheap eBay beaut in all her glory! You can see this is the setup of it all for the most part. I laid it out to get a clear picture of things. I got tired of trying to fit it in the wheel well so instead I cut that off! I was careful not to cut into the metal of the actual floor but instead only cut the wheel well material. I want to use the flange for a cover or something. Next I cut slightly into the leftover wheel well flange. I did these little cuts all around it and then pried each piece off while drilling and grinding away the tack welds. Next, I started on the frame supports for the fuel cells. I used just some angle iron across the the subframe in the back. I later on went and used some flat pieces to fix the gap on the ends. I needed that to be that los in order to have the correct angle for the gas. These tabs will hold it on on this side. A mockup for how it will look. After testing the actual cells I realized I made a mistake here so I cut off these tabs, marked up the new spots and welded some new ones on! I used some flat aluminum from a local metal supplier and just measured and bent with my hammer and a vise! Turned out perfect on this and a little loose on the smaller one. I did add strips of window seal on the sindises to keep it from rattling and hold it tighter. Looking great now! I then ground it all down and painted it with primer and some undercoating. Then I drilled all the holes and started fitting things in one piece at a time. I did all the AN fittings and hoses and just tried to optimize it as good as possible. The "final" result: I know these aren't exactly high end race cells but this is plenty of overkill for my needs! I later added better hardware to hold it all together and I bought a fuel pump holder for the Bosch pump.
  16. Yeah the hope is really soon. I still have some updating to do but I'm very close to getting it started. I need a little bit of cash to get a few tidbits to finish it off though!
  17. So after getting the mounts figured out, I then decided to focus on getting the engine put together. I wanted to see what I'm missing, get everything built out, wiring figured out and hopefully do a first startup! So, I pulled out the boxes and laid out all the pieces ha. This went together pretty quickly as it's all bolt on stuff. First, the intake! Then I put the starter and turbo in. It was at this point I remembered I had an oil return line that was directly under my engine mount. Originally the mounts were much less angles downwards which made it possible to put the hose on under the mount. My new mounts have a harsh angle which made that impossible so instead I drilled a hold straight through the mount and had the hose hook up straight through. Not sure how well it will work yet. I may want to go in and dimple the hole but we'll see ha. Works for now and I'll keep an eye on it! After that, most of the bolt ons were on so I started doing the piping for the intercooler! I had so many pieces of this so it was pretty easy. I apparently didn't get a ton of pictures of this stage but here is the almost final result! I did end swapping out the passenger side pipe coming out of the intake manifold for a pipe that already had the blow off valve welded on. The wheel well required some "massaging" with my rubber mallet to get it to fit but I'm eventually planning on cutting that out anyway so I'm not worried. You'll notice that I have a sweet Mishimoto radiator as well. I won it with an instagram video contest and I figured rather than find a radiator with a passenger side intake hole I would just try and make it work with some radiator piping. More to come!
  18. Oh awesome restoration by the way! I love watching people that know what they're doing. I would've done mine really nice if I knew how but as I'm using this as a big ole learning experience I went straight race car!
  19. Curious where you got your rear quarter panels from? And how much did they run you?
  20. Man this makes me want my own powder coating setup! One day. I just want to coat a bunch of the tiny details.
  21. Man the acceleration at :36 is impressive! I can't wait to hit some autocross up and get familiar with my car, makes me stoked!
  22. Those rock guard covers are cool, I've always wondered about that area and didn't realize there was a product for that!
