mutantZ
Donating Members-
Everything posted by mutantZ
Came across this and I was wondering if anyone went this extreme on our car.
Finally getting rid of parts that I bought, then changed my mind on, then replaced with something similar. 🙄 Price does not include shipping. All these parts (except the axles) were mounted but have zero mileage on them so here goes: 1. Z-therapy rebuilt SU's. SOLD 2. E-brake bracket, spot calipers, and cable for Arizona Zcar wilwood rear brakes from first WOZA group buy. Including new Wilwood prop valve. $350 Backet was trimmed so you don't need to pull the hub to get them on/off. Picture just for ref of it mounted, only items listed are for sale. 3. Arizona Z Car rear caliper bracket $100 Lovingly modded by JohnC 😄 4. Techno Toy Tuning Bump Spacers SOLD These were never mounted 5. Stock 300zx CV axle shafts SOLD 2. 3. 4.
Heavy Duty frame rails and connectors
mutantZ replied to toolman's topic in Gen III & IV Chevy V8Z Tech Board
Great write up! Does that new steering shaft have a collapsible column? I can't really tell from the pictures. I was on the fence about getting this for that reason. -
Where are you hiding your wires?
mutantZ replied to mutantZ's topic in S30 Series - 240z, 260z, 280z
Thanks for the ideas. I'll check out the vent tubes. I'm about to put my car up on a rotisserie so I'll be able to look around the frame rails too. I followed your build for awhile, what part of Oahu are in? I grew up there and my first car was a 510. The salt air there isn't kind to Datsuns! -
Next phase after my hardlines will be rewiring my car. Where are people hiding their harness? Are you running it inside the engine bay frame rails? I have a similar drivetrain to this car and I would love for it to be this sano. http://www.zcarblog.com/wp-content/uploads/2018/07/DSC00774.jpg
I'm having the same issue here.
I bet the VR isn't the cheapest motor to rebuild. I still prefer the sound of a smaller displacement OHC motor, but it's hard to argue against the bang for the buck the LS gives.
CD009 Transmission mount Buy vs Weld
pm sent -
These days, a VR38 is looking like a pretty good option compared to a RB build prices. http://www.speedhunters.com/2017/10/dimmack-datsun-gtz-build/
I just talked to the guys are Godzilla and they said they get it from Apex so there you go. He said that they were pretty stout and never had any issues with it. I'm putting it behind an RB motor. Not gonna be making crazy power, but you know how the sheetmetal is on our cars 😁 -
I checked on Hokes/Godzilla's site and didn't see any for sale. Hoke's would've been idea because it connects to the rails and his stuff is always top notch. -
I was looking into how to mount a CD009 into the car, Apex makes a mount: https://www.apexengineered.com/store/p27/RB25_%2F_T56_%2F_CD009_Transmission_Mount.html I was wondering if this would be better or worse than welding some tabs where the stock mounts are and fabricating up a bracket (aside from cost). More of a rigidity question as the apex kit just bolts to the floor pan and not the rails. Thoughts?
People are crazy. I think BAT is a major reason why parts are hard to come by these days.
I have an early 74 260 and am converting my tank over to support FI. I am going to be running some sort of surge tank, most likely Radium. My tank is similar to this, if not the exact same one: Right now I was planning on using the stock pickup line from the tank connected to a carter/280zx/carb pump as my feeder pump, then having a new return port brazed to the top of the tank (mainly so I can keep my vapor lines intact). I'm sending my tank out for cleaning anyway. I'm replacing all my hard lines under the car so anything from the surge tank forward will be fine. Just wondering if I will have any fuel starvation issues using the stock pickup point to feed my surge tank. This is mostly a streetcar but I do intend on putting some track (circuit) time on it. Thanks for any info!
Old thread. I just came across this and it looks period correct! If I were keeping the L i would seriously consider this. https://www.edelbrock.com/adjustable-universal-efi-sump-fuel-kit-67gph-35-90-psi-36031.html
Thanks rossman, I usually never use crow's foot wrenches so that was a big help!
Thanks guys, they were a class 8.8. Now the big question is if my crowsfoot will hang on to make torque spec!
I know this an old thread but I finally am getting around to installing everything 😁 What torque spec did you guys use for the bolts for your bracket? I was trying to find the torque for the drum backing plate but it didn't look like it was listed in the FSM.
Posted a bad character. Anyway, this is very sano
I just posted a title that had an icon in it and I think it corrupted the link. Its under body and paint "280z black" with a heart after it. I copied it from the youtube link and didnt realize it showed up in the title. Please remove, my bad.
I bought a running engine and the PO told me his mods. I am guessing I am looking at a powerband that would be similar to this dyno I found with similar setup: It's still using the stock turbo however, and I plan on doing a rebuild after I get the whole car sorted (and test driven!). From the previous posts here from people with RB swaps, a lot seemed to say their car seemed pretty lethargic with 3.7 and lower (numerically smaller) gears. Most of the 240sx guys run pretty steep gears out back. Powerband is tough to say as I haven't built the motor but I don't plan on going youtube big, more like 350-400tops. Mainly just want the efficiency of a modern better flowing turbo on it. I'll spec that when I get to it. I was just seeing if I could cheat the diff with the trans I am going to use anyway. Would be one less part to buy and have my LSD swapped into. That OSgiken oil is $60 a can! 😄
I'm doing an RB25 swap and I had a question about driveline. Does anyone have a CD009 (350z) transmission with their swap? I was comparing ratios from the rb25 transmission to the cd009, and the CD has a much lower 1st/2nd. Factory GTST's came with a 24"-ish tire with a 4.11 rear and a 3.215 first gear. My car currently has a 25" tire with a 3.54 gear, the CD009 first is 3.78. I am thinking this would more or less put me at factory gearing. Finding a 3.9 or 4.11 is pretty tough in a r200 long nose these days, and my diff is essentially brand new. But I'm working on the backend of the car now so now's the time to do it. Anyone with a setup like this (rb engine/cd009)? How do you like the gear spread? Thanks.
Do I need to repack rear bearings to add a bracket?
Yeah I was overthinking it. Thanks.
