mutantZ
Everything posted by mutantZ
  1. I know this an old thread but I finally am getting around to installing everything 😁 What torque spec did you guys use for the bolts for your bracket? I was trying to find the torque for the drum backing plate but it didn't look like it was listed in the FSM.
  2. Posted a bad character. Anyway, this is very sano
  3. I just posted a title that had an icon in it and I think it corrupted the link. Its under body and paint "280z black" with a heart after it. I copied it from the youtube link and didnt realize it showed up in the title. Please remove, my bad.
  4. As the title states. Very sano.
  5. I bought a running engine and the PO told me his mods. I am guessing I am looking at a powerband that would be similar to this dyno I found with similar setup: It's still using the stock turbo however, and I plan on doing a rebuild after I get the whole car sorted (and test driven!). From the previous posts here from people with RB swaps, a lot seemed to say their car seemed pretty lethargic with 3.7 and lower (numerically smaller) gears. Most of the 240sx guys run pretty steep gears out back. Powerband is tough to say as I haven't built the motor but I don't plan on going youtube big, more like 350-400tops. Mainly just want the efficiency of a modern better flowing turbo on it. I'll spec that when I get to it. I was just seeing if I could cheat the diff with the trans I am going to use anyway. Would be one less part to buy and have my LSD swapped into. That OSgiken oil is $60 a can! 😄
  6. I'm doing an RB25 swap and I had a question about driveline. Does anyone have a CD009 (350z) transmission with their swap? I was comparing ratios from the rb25 transmission to the cd009, and the CD has a much lower 1st/2nd. Factory GTST's came with a 24"-ish tire with a 4.11 rear and a 3.215 first gear. My car currently has a 25" tire with a 3.54 gear, the CD009 first is 3.78. I am thinking this would more or less put me at factory gearing. Finding a 3.9 or 4.11 is pretty tough in a r200 long nose these days, and my diff is essentially brand new. But I'm working on the backend of the car now so now's the time to do it. Anyone with a setup like this (rb engine/cd009)? How do you like the gear spread? Thanks.
  7. Finally getting around to the car again. i got a new parking brake bracket from Woza awhile back. I have to pull my hubs to install, but my bearings have almost zero miles on them since I upgraded the stub axles. Can I get away with just doing a R&R and skip the handful of grease? I know, just being lazy...
  8. Thanks again. I'll try a 25' foot for both and hopefully won't need more. Next up, wiring questions! 🙂
  9. Going to redo my brake line and fuel line at the same time. Anyone know how many feet I am going to need? I am going cunifer for both and want to make sure I don't need to pay double shipping. They come in coils of 25 feet. Thanks.
  10. Shame they never kept developing this engine. So far I've never heard a bad inline 6 sound. The L looks pretty impressive compared to this build tho, considering its down half a liter (on a 3.1) and still makes more oomph. Especially in the torque department.
  11. I came across this solution I may try for the holes in my car
  12. Nice, how much does that usually cost? I'm saving my N42/N42 setup in my stash but just clearing out my now defunct turbo build.
  13. Another unused item taking up space. Motor spins and bores look relatively clean. Has the chain, timing cover, water pump, pulley, oil pan, and motor mounts. Thanks.
  14. I'm in Los Angeles. I was thinking of selling local so I don't need to figure out the boxing of it.
  15. What is the going price for these now? I picked up an RB so I'm looking to clear out some space. They are in decent shape, but haven't been rebuilt.
  16. That is probably about 124 mph faster than I ever intend to go in a Z
  17. Awesome, thanks for the info. I'm going to steal your idea for an access panel in my spare tire well. As for pickup, I'm going to try the Holley Hydramat. It seems to work really well- like it will drain your tank literally dry from some accounts. FYI I heard there was a recall with that pump. I don't know when you bought it, but they seem to have a leak right where the fitting meets the plate at the top. Apparently a bad batch that was misthreaded. If you get a mysterious leak when you start it up, thats probably what its going to be.
  18. Is it necessary to mount the unit that high up since it picks up from the bottom? I was looking at this install mounted on the lower part.
  19. Will a vacuum signal from the intake be reliable enough to work an evap can valve if I mounted it near the gas tank? I'm probably going to replace it with a smaller unit. It would be nice to get that can of the engine bay. I know some people just plug it, but I think its worth keeping around to avoid any of the other issues. I'm converting to EFI so I will be putting new hardlines already.
  20. Good test video of some extreme tubing. Makes me wonder how the plug-side turbo L engine guys response would drop since the tube isn't nearly as long.
  21. Thanks for the heads up, I'll send him an email.
  22. Thanks for the link, I did a search but I didn't see those. I'll look into what goes into the conversions, but having a ready made kit is very tempting.
  23. Does anyone have any direct experience with the electric power steering units out there? Specifically Z Power steering vs Silver Mine. I know one is cheaper but I'd rather 'Buy once, cry once'
  24. These are the rip off of the wider marugens, and I have the real ones now. Its a 295 in the rear, but theres more than enough room to squeeze a 315 back there. 17x10.5's right now. Prob could've gone as far as 11.5 but that would prob be the limit with this offset.
