JMortensen
    68
  1. JMortensen
    DSCN0952
    Mocking up the TC rod angle to make sure the rod didn't hit the box through the suspension travel.
  2. JMortensen
    DSCN0977
    Angle iron gusset on top of TC box
  3. JMortensen
    DSCN0974
    Shot shows the now slotted TC rod box, forward gusset, the modified Bad Dog SFC connecting to the TC box, and the support from the box to the rocker tip.
  4. JMortensen
    DSCN0940
    How the frame rail and the box sit together.
  5. JMortensen
    DSCN0937
    Weird shaped hole I cut in the bottom of the TC bracket to square it with the curved part of the frame rail.
  6. JMortensen
    DSCN09011
    Seat bracket ties into subframe connectors.
  7. JMortensen
    DSCN08991
    Front frame rail with TC rod and box structure behind it completely removed.
  8. JMortensen
    DSCN0881
    Rail stitch welded to floor.
  9. JMortensen
    DSCN0880
    Pulling the floor to the rail with sheet metal screws, also shows the special piece that John @ Bad Dog had roostmonkey make for me.
  10. JMortensen
    DSCN0879
    Frame rails removed from bent floor.
  11. The 4 speed shifter has a longer shaft from the pivot to the ball, and hence a shorter throw. I have an early 70, so I cut it off right above the ball, welded it back on at a 90 degree angle pointing straight back, then bent it up so that it comes straight out the console hole. Then I cut it to the length I wanted and ran a die down it to thread on a stock ball. More info: http://forums.hybridz.org/showthread.php?t=96707
  12. Been running a 4 speed truck shifter with the small nylon bushings in mine for 8 years. There was a thread on it a while back about short shifters. Apparently my ghetto version short shifter isn't as short as the Nissan Comp version, but it does work.
  13. I'm pretty sure that body kit is sold by http://www.motorsportauto.com. I know that there are quite a few people running it or something very similar.
  14. You can listen to whoever you want. John measured his car with a setback L6 vs an SR20DET car. I'll listen to him.
  15. Unless someone like me swapped the shifters...
  16. At this point I'll go out on a limb and say that something is not correct. I don't think I've ever seen cam duration over 300 degrees @ .050. It's like someone telling you that they run 100 degrees of timing advance or something.
  17. 325 degrees at .050??? With only .475 lift? I am having time swallowing that one.
  18. Except the front strut inserts of course... Not sure about the answer to the original poster's question, but I think one difference is that the ZX TC rod bolts to the bottom of the control arm and the Z rod bolts to the top. Whether that means that the bolt spacing is different or the length is different to the point where the parts won't swap is something I don't know...
  19. JMortensen
    Fluids
    SWEPCO 201 is my preference. If you've been reading through the archives and seeing all these other threads that express other opinions, what makes you think that this one will be different though???
  20. Try a little searching. There is a sticky post in the drivetrain forum that has info on several different front diff mounts. You won't find a poly mount, and the stock system with the strap and mount underneath is REALLY crappy, so you might look hard at the alternatives instead, including the one that bjhines showed above.
  21. OK, NOW I get it. Since I'm not a computer geek I wouldn't have figured it out unless I saw Mr Fancypant's comments.
  22. I'd check the zhome.com information first and see if you can figure it out. If you can't the other way to do it is to put the trans in a gear and mark the input and output shafts, and then spin the input until the output makes one revolution. Count the number of revolutions for the input, and that would tell you the gear ratio. You can then use a chart like the one on this page: http://www.geocities.com/z_design_studio/ to figure out which one you have. You can check more than one gear if you're not sure. If you do have a Nissan Comp transmission they're worth some $$$ these days, so definitely check it out.
  23. What do you mean by "close ratio"? Do you mean a Nissan Comp transmission, or a 280 ZX transmission? I think zhome.com has a series of pictures which can help you discern which one you have...
  24. 10 pts means it will take your gas from 92 to 93 octane. Most of the stuff raises it 1 or 2 points which means from 92 to 92.1 or 92.2. Most octane boosters are Xylene which is 118 octane or Tolulene which is 114 octane or a mixture of both. It's pretty easy to figure out how much octane you'll end up with by determining the octane of your booster and then adding the octane per gallon and dividing the number of gallons in the tank. When I was running Tolulene I was putting in one gallon for 5 gallons of 92. So 92 x 5 + 114 / 6 = 95.6666666 octane.
  25. The tubing is .072" thick. You can find the swaged tubes from Coleman Racing, AFCO, and any number of other circle track parts suppliers.
