45
Everything posted by A to Z
here are my T3/T04 Turbo specifics: Turbine Side: Turbine Trim: 74.2 Turbine A/R: 0.63 Turbine Inducer: 64.8mm Turbine Exducer: 55.8mm Turbine exhaust outlet : 79mm Turbine exhaust inlet: 44.7mm(length)/85.8mm(width) Compressor Side: Compressor Trim: 48.1 Compressor A/R: 0.5 Compressor Inducer: 52.7mm Compressor Exducer: 76mm Compressor outlet:78 mm Compressor inlet:51.5 mm
Hello! Since my turbo project is going well, I wanted to ask if any of you have any thoughts as to what I can expect from my T3/T04 turbo with .50 A/R 48 trim) with a .63 turbine housing (trim 74.2) on my 2.9 stroker? Since I like quick spool, I think a turbine with more vanes might be nice. Thoughts? Thanks in advance.
Cool writeup I found on my turbocharger: T3/T4 hybrid turbocharger assembly is created by installing a T4 compressor wheel and housing onto a T3 turbine housing wheel and center section. A T3/T4 hybrid turbocharger assembly is a compromise for engines where a T3 turbocharger is too small to reach the desired maximum horsepower but using a T4 turbocharger would create an unacceptable amount of turbo lag. The T3/T4 turbocharger is designed to be used on engines displacing 1.5L-3.0L and is typically good for around 400HP. They are also commonly used in twin turbo applications. In this case those figures would be doubled 3.2L-5.0L engines up to 800HP. Horsepower ratings are generally meant to express the turbochargers maximum airflow capability. Recommended boost pressures are 7psi(0.5 Bar) to 21psi(1.5 Bar) and boost pressures should not exceed 30psi(2 Bar). Exceeding 21psi(1.5 Bar) of boost pressure can significantly reduce a turbochargers lifespan. Generally speaking 14psi(1 Bar) is good for a 100% increase in horsepower from a naturally aspirated engine. Also factory non-turbo engines without forged internal components on high octane pump gas (91-92 octane) it is not recommended exceeding 7psi (.5 Bar) of boost. Doing so could result in damaging your engine.
11-23-2024 TURBO PROJECT UPDATE. Hit the garage running today! Dropped the 2-1 exhaust and carburetors and prepped everything for install. I installed the Crown J pipe with a new gasket, and then installed the Crown log manifold, I then plugged the port for the second carb on my Pallnet fuel rail. Then I went ahead and installed the crown adaptor and 3 inch to 2 inch hose which goes between the carburetor and turbo inlet. I found that the hose that goes from the block to the PCV would not work with the crown intake, so I took cut a portion of the factory hose and attached a breather to it and attached it to the block. I also attached the valve cover breather using Loctite thread seal on everything. I took a break and ran to Ace Hardware and got some chrome button head screws for the manifold so it looks even better but was unable to get a plug to fill the PCV port, so I ordered one on eBay...M14x1.5 thread....so awaiting it.... stainless. Next I jumped on installing the oil supply line. Unfortunately, my oil feed line is about 8-10 inches short, if I want it to go all the way around the back. So I will look into a longer line. This line will work if I run it over the valve cover. I then added a few stickers under the hood, and mounted 2 of the 3 gauges to the Milkfab gauge plate. The 3rd gauge will be for the J*S Safeguard knock sensor which is also en-route. So, quite a bit accomplished. Pics follow. Cheers!
11-21-2024 Turbo Project Update. I got my J pipe and down pipe back from the welder, Juggernaut Welding. He gave them 3 coats of Cerakote dark graphite powder coating, and it is good to 1800 degrees F. I went ahead and brough a bunch of little things in the house and got them done, I got the Water Methanol injection nozzles installed and the hoses installed, put the plugs in the carb adaptor and wrapped the down pipe and J pipe with header wrap. I have a turbo blanket that matches the header wrap waiting. It's starting to come together. Pics follow.
Turbo Guru's, T3 question(s). Please advise
A to Z replied to A to Z's topic in Turbo / Supercharger
thanks. It is at G Pop Shop. Getting Carbon Seals installed, and a possible port and wheel change for quicker spool. My redline is 5500-6000 RPM, so I am willing to sacrifice a top end I won't use for more "meat" in the mid range. -
Yeah....I have started to realize the same thing. I will let it make what it makes and provide the fuel, methanol and water it needs. the knock sensor will save it. If it wants to spool immediately, that would be exactly what I want. I don't go over 6K RPM anyway. I am going to talk to the turbo builder and see what he has for custom wheels....apparently more vanes brings earlier spool.
My welder also does powder coating, so I am having him powder coat the J pipe and down pipe with some graphite black colored hi temp powder. Supposedly good for 1800 degrees F. Also....G POP , who is doing the carbon seals on my turbo is going to hi temp powder coat my hot side with some 2000 degree F Titanium color powder coating, and then the compressor side is being Powder coated gold. You will see, it will all come together. also mulling over having the turbo ported and maybe a custom turbine for the hot side to spool the turbo quicker since I like my 5500-6000 RPM redline. We go forward!
Turbo guru's please read: I have the T3 Turboboosts M12 turbocharger I got off of eBay, and because of what I have learned on here and other pages....being a draw through setup with crown manifolds, etc., I have sent the turbo off to "G POP Shop" in Arkansas to gee carbon seals installed, and the hot side is getting their high temp coating in Titanium finish, and I am having the compressor side powder coated in gold. Since it is there, I am thinking about possibly having a custom hot side wheel put in to create a faster spool. It has journal bearings, which doesn't bother me as this is just a weekend around town toy. The Specifics of the turbo are: Compressor : Inducer 52.7mm, exducer (outer diamter) 76 Ex turbine: exducer 55.8mm, Inducer ( outer diameter) 64.8 Trim: 48.1 A/R .50 420 HP Rated. Going on to a 171 cubic inch (2859cc) inline six cylinder Any opinions on exhaust wheel sizes, etc., that will help deal with a 4000 RPM spool, outside of manifold work and larger down pipe enlarging etc. I am thinking custom wheel(s). Not sure if porting would help either. P.S. I was shocked to find out Garrett turbos are made in Shanghai, CHINA.
$195 ish for the carbon seals installed along with a rebalancing of the turbo wheels, and a thorough checkup for the turbo. It makes my turbo just that much better. Granted its Journal bearing instead of Ball bearing, for my uses, it is fine. On a Draw through Turbo, the vacuum created by the carb being in front of the turbo, tends to cause turbos to leak oil by pulling oil through the seals and burning it, leaving a blue smoke cloud behind you when driving along. This alleviates that.
Link for Juggernaut welding. Cool website. https://l.facebook.com/l.php?u=https%3A%2F%2Fwww.juggernautwelding.com%2F%3Ffbclid%3DIwZXh0bgNhZW0CMTAAAR3EGU-Dqu0cfw2_m63F1YQu-CW318pQXZ_Ush6pggNbeHl8OQNLlR5f4Do_aem_ac5vXnq35WvOclQePkEbLw&h=AT0IhM7k5JMUmU4Da3JegoaFkYJi94JIpgCojduk9VuiZ3kpkgxoK37LEOmHxABvp0Qgj1AMVoPGScUuqmDpxbOOvHp49FuU_pWfpnWcuXN7KiwxEevWjswpH2lwGYs0zxUv&__tn__=R-R&c[0]=AT0k28CDcTUFU3EQVKLS_gVtj8TBYncoOs4GZlXwfM6VDYMIzCwzP9MPcYCFw4y3NS1BI57rNbNSol7ImG8BcVDJcAprSLckoG-ozRnwxaGlgyKOmnoft5id6PzK8HDN8Yp_cPwaTN1lvmKYXbH5BnMZry1voXvE41Pgor9jpkmGgKsmUBRJLQOD-UE7ya_Gklr_D1ctMJ6NDJcQqPqokvOZBxoP2M_8
I dropped my turbo in the mail today to go to G Pop Shop to have it updated with Carbon seals, which apparently are necessary when using a draw through turbo system. I also dropped off my J pipe to get a T3 flange welded on, and my down pipe to weld on a V band clamp, M11x18.5 bung for my AEM A/F gauge and a flange on the bottom at Juggernaut Welding. We go forward. https://www.gpopshop.com/
11-16-2024 TURBO PROJECT UPDATE: wow...busy day. I got my down pipe cleaned up and ready for some welding....V band on the top, flange on the bottom and a bung for my A/F down low. I have a length of flex pipe to get in there when I connect the pipes together. I also went ahead and cut off the old Rayjay flange on the J pipe and I got a T3 flange...sure wish they hadn't chrome plated it. Then I took some time to try and clean up the ports on it a bit. Looks like my welder will have to fill in around the pipe where it meets the flange...maybe plate steel on the outside and fill it in on the back side? We'll see. My crown turbo inlet to carb spacer piece I cut down and got my 2 inch to 3 inch hose to fit on nice....just needs a coat of paint. After getting all of that done, I went ahead and mounted my Snow Performance water/meth injection tank and pump and ran the lines between them. Almost all the parts I need have now arrived, so now it is just welding and then putting it all together. V Performance modded Mikuni HSR 45 Carb and J&S Safeguard (knock protection) are still enroute. Pics follow. Cheers!
Many guys have done high compression and boost. the main issue is detonation. The way to curb the detonation is with water/Methanol injection. The other way is through a knock sensor (J&S Safeguard) that pulls the timing to each cylinder individually. I have elected to do both. My setup is a mild turbo setup......it is mainly for looks. As a by product I'll gain 20-30 horsepower minimum. This is a hobby car, and this is fun. I set it up and run it, if it is rich, then I turn the boost up little by little until it isn't rich anymore. same with timing, as much timing as I can get away with, and if it is rich or lean, change a jet in the carb. when it is running great and the A/F Ratio is good, then that's it. Whatever the boost level is....I'll know then. I anticipate 5-7 psi. 5500-6000 redline. I like torque.
11-10-2024 Turbo project update. I started on the interior, mounting the relay and boost pressure switch for the Snow Performance Water/Methanol injection, and then went ahead and removed the 432R stereo delete plate, and re-routed the wires for my A/F ratio gauge down to that area. I bought a 3 gauge pod panel from Milkfab Engineering to go in there. I will house my AEM A/F ratio gauge, my AEM boost gauge, and my J&S engine knock/ignition retard gauge. AFter that I went and started on the Crown intake plate. I decided to prep the piece for polishing by removing all the fins and stuff so it is smooth, and then I drilled and tapped for the Water/Methanol spray jets. Yeah, the holes aren't perfectly aligned...I double measured, dang......but I can make it look good once installed. I also worked on the aluminum block that mounts the carburetor to the turbo. I can't believe how rough cast it was inside the bore area. I can't believe the previous owner mounted it and used it like that. I went ahead and cleaned it up. So those 2 pieces are going to J&S Polishing in Colorado Springs in a day or two and will be a thing of beauty when I get them back. I have attached pics, and added a pic from Milkfab of a 280Z gauge pod with gauges, as they didn't have a 240Z pic, and the other pic is also from them, to get an idea. Thanks!
Warning - poor R&D and customer service + credit card dispute
A to Z replied to idiot280's topic in Non Tech Board
"it's the Russians"
