Mike kZ
Super Moderators
Everything posted by Mike kZ
  1. I have a T-56 mated to a small journal 327. The bolt pattern is the same as a large journal. I did have to use the centerforce flywheel and dual friction clutch setup. Go to centerforce.com for part numbers.
  2. This is the best write up on my rear end: http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=7763
  3. The "beams" are around 24" long, I would have to measure them. The frame connectors are installed the usual way, check out Jeff's frames here: http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=35320&highlight=frame+connector The lower mount of my "beams" are mounted to this. Check pic from my site.
  4. The problem is finding them to give them the cow!
  5. This looks the closest: http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=27453&highlight=
  6. Also try and find an air conditioned space to work on it!! That will make all the difference!
  7. I agree! I always wanted to hybrid one of those!
  8. Sounds like a lean condition to me too, needs more fuel.
  9. I have some pics here: http://327-240z.freeservers.com/
  10. Does anyone know how that works?
  11. Very cool! Welcome to the site!!
  12. This site may help: http://www.miatanet.com/garage/pushstart/
  13. That's cool!! I realy like those Magnum RT Hemis, I'm thinking of buying one.
  14. I have mine T'd between the PCV and base, and my brakes work fine. Are you sure your check valve is intalled right? The tapered side of the ck valve goes towards intake side and the flat side of the valve goes towards booster
  15. Very nice Dan!! and Welcome to the site! What part of the country are you from?
  16. Already posted: http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=35169
  17. Happy B- day guys!!, Mine is also July 7th!
  18. Not sure if these are oem: http://www.autopartsland.com/productlist.cfm?model_id=281&keywords=Quarter%20Panel&make_id=27&search_on=description&browse=true call these guys: http://www.nissanautobodypartstore.com/
  19. Try Showcase for both Z and ZX. Looks like they have 1/4 panels in fiberglass only. http://www.showcars-bodyparts.com/240z.html http://www.showcars-bodyparts.com/280zx.html
  20. This is a member's car, not sure if a 350z's engine compartment is smaller then this, but it gives you an idea what a LS1 would look like in your Z. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2483301129#ebayphotohosting
  21. Here is a Healey with an SHO motor: http://members.cox.net/rdgrauman/Healey.html and a couple of members trying it: http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&p=137621#137621
