Mike kZ
Super Moderators
Everything posted by Mike kZ
  1. I hope nobody comes in that upper door drunk, I don't see a railing on those stairs!
  2. You can use the stock T56 bellhousing with a 93 - 97 T56.
  3. Cool!, does the hood fit?
  4. WOW! , that looks great!, I may have to come over and check that out.
  5. Aready? You haven't even driven/enjoyed it much yet.
  6. Subaru: http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=32863&highlight=power+steering
  7. That has been posted before: http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=32821 and it's still sick!
  8. Make sure you have a good ground form your engine to frame/body, and do this fix: http://alteredz.com/Headlight_Relay_pg1.htm
  9. OK................ ,but I know what you mean!!!
  10. Do you mean this one: http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=15544&highlight=stony
  11. That's because it's spelled correctly! I even checked it with this spell checker: http://www.spellcheck.net/cgi-bin/spell.exe?action=CHECKWORD&string=banning
  12. Get another high torque starter if it worked. They are better than stock anyway.
  13. From what I can see (small pics) it doesn't look too bad, I'd go look at it. Where in Atlanta are you? Mine was in an old open shed for years in the Roswell area, it looked just like that, and wasn't that bad.
  14. I love those things!! Wish I had one, good for you!
  15. The stock front suspension is pretty light, check out this site: http://www.ratsun.com/
  16. Did you bolt it with those straps straight to the frame or body? I used some small rubber o-rings ( can't remember the name of them, those rubber o's that you place in a hole so you don't damage wires going through metal) between the hold down straps and mounting place. Like I said it's very quiet.
  17. I'm using a pump that looks identical to that. It came with my Pro-Flo EFI. Mine is very quiet, I don't hear it at all. Do you have a filter at the inlet? When I first installed it, I didn't have a filter at the inlet, only after. It started to get quit noisy, and then died. This was after about 30 miles of driving. When I replaced it I installed an inline filter before it and has been running quietly ever since.
  18. That won't work, look at the side view, they stick out from the head 3 3/4" then straight down. They need to hug the block more, also they may hang too low, but not sure on that.
  19. With the check engine light on, and running rough, it sounds like it's in "limp mode". Running just enough to get you to a shop, but not running great. You need to check what the code is. Sounds like your MAF sensor is bad.
  20. Did you check the range voltage on all your sensors? I'm thinking the temp sensor that checks the temp of your coolant. Since weird things are happening when hot, maybe the temp sensor is out of wack?
