I finished megasquirting my n/a l28. I'm running a 280zxt distributor, msd 6a, stock resistors, stock fuel rail and injectors. The car runs very good except light throttle and idle where the a/f ratios will jump back and forth and idle flucuates alittle bit. My gauges tell me my injector pulse will be 4.2 ms at idle then jump up to 5.2 then back to 4.2 I have made all my cells in my ve table around the idle the same percentage. The tach in megatune moves about 100rpms back and forth but the car doesn't feel like its missing that much. I don't have an aftermarket tach to verify and I haven't hooked up my stock tach yet.
The only things I've come up with yet is a loose signal from the distributor (bad distributor, bad resistor, or bad power wire to distributor) or a grounding problem. I will be adding a few more grounds tonight in hope of seeing if this fixes it. Right now I have a ground from battery to starter bolt. Then I have all of ms and my sensors grounded on my intake manifold. So i'm going to add another ground inline of ms directly to the battery and add a ground from the battery to the frame tonight. Any other ideas? Thanks
Also the voltage in megatune reads 13.6-13.8 which corresponds to what I get out of the alternator.
