Thumper
Everything posted by Thumper
  1. Damn sorry I didn't catch this thread earlier. Same thing happened to me. The cam was off a tooth. Let us know how the new cam goes once you get it installed again.
  2. Just buy a 5" aftermarket tach and put it in the stock location... It has a faster response rate. Sounds like that might be your only option. I personally used my output from my msd box so can't help.
  3. I call it a stage 1.5 it is a 4-bolt just like a stage 2 but all this and that. Basically its a built up stage 1. Well sunday night he blew a headgasket and did some damage because of a faulty injector. He is tired of things going wrong on the car so he might be parting it out. The stall was suppose to be a 3500-3600 but he says but it is way too loose. He bought it used from someone else something he will never do again. Running only 17lbs of boost and the bad injector he got a 12.0 @ 109mph before the headgasket blew. Funny thing is his knock sensor wasn't going crazy just normal valvetrain noise... Thanks
  4. Thanks for info. My gto is a 6sp so i'm not looking for a stall for my car but trying to help out my friend with his gn motor. It sounds like he has too high of a stall on his car but before I tell him its too big I would like to know for a fact. Thanks
  5. Ok i'm a newb when it comes to stall's. My friend has a buick grand national with lots of work done to it. Its almost a full stage 2 engine with a medium/large turbo. I'm not looking for an exact stall he should run but I was wondering does a 5600rpm stall sound to high? From what i've read you want the stall to be slightly lower than his tq peak? I seriously doubt his tq peak is that high but not sure. Also to make sure I know what a stall is, his car launches at 5500rpms and stays there roughly (up and down 200rpms when it shifts) the whole trip down the 1/4. This doesn't sound right to me but i'm no expert so before I talk to him I would like some info so I sound smart. Key word sound... Thanks P.S. He is very knowledgeable into cars so I doubt he made this obvious of a mistake so please look at all the angles and ask all the questions you want. Thanks for your time.
  6. I think the head is still lifting. Thats the only way I know of that the coolant can become that pressureized (sp)
  7. I just hooked up a dry shot to my GTO but was curious how much bottle pressure effects a dry shot. I know a wet shot its huge because less nitrous or more nitrous effects afr's. But since a dry shot uses the maf to adjust I think that the only thing bottle pressure effects is the amount of nitrous it feeds thus the power of the shot. Since its cold out and I don't have a bottle heater "yet", I'm going to run a .003 larger fitting to compensate for the 650-750psi bottle. Good idea? Thanks
  8. Could be a bad alternator. Charge up the battery fully or try a known good battery. This happened to me once.
  9. Have you checked your battery? If your battery is weak then when you crank it the volts drop low enough that megasquirt turns off. Could also be your relay going bad and losing volts at that. Put the voltage display on your labtop and see if they drop below 10v? while cranking.
  10. One thing it might be is if your Intake temp sensor, or your coolant temp sender is broken or worn and they are reading your car to be cooler than it is, your ecu will inject more fuel. And when its hot out it is too much fuel and your car runs bad. But when it gets cold out and more air (because its denser) gets into your engine the afr's are closer to where they should be you car runs better. Just one theory. Another one is...
  11. It depends on what boost you are running. If you are running stock boost then spend the $800 that a properly setup nitrous kit will run yeah on turbo upgrades and you will get 100hp all the time.
  12. John, what about a bonneville flats speed car. Would you stick with the street setup or have different settings? Thanks
  13. So what do you think about the camber settings? Should I add negative camber to the front since the rear has so much? Thanks
  14. I just found my actual alignment settings and updated the numbers. Also 1/8" equals .010". So I have perfect on front and ever slightly too much on the rear. But on the rear its recommend to be at .020" so I think i'm good there also. Now that i'm looking at the numbers I worried about the little negative camber. I wonder if lets say -.4 or -.5 would be better. Any thoughts? Thanks
  15. I too at first thought that 0 toe would be best but I then thought that in order to counter any changes in the road it would be best if the tires were fighting each other just alittle to keep tension on the suspension.?
  16. I will be replacing the front tires soon on my GTO and will get the car realigned when I do. I am looking to get the most high speed stability as possible since this car is too heavy to handle GREAT and I mostly use the car at a drag track/highway. Right now I have .10" toe front, -0.1 camber, and 8.5 of caster in front. .14" toe rear, -1.2" camber rear(not adjustable). Would you change anything or keep it the same? I just got home and found the actual alignment settings.
  17. Carfan, looks like you are in deep thought. Were you contemplating what engine to put in your z?
  18. Took this a couple of minutes ago. Don't feel too special its for an old school acquaintance who is stalking me/tracked me down:icon31:
  19. Thumper
    myself
    Me, Myself, and I
  20. It looks like at that angle you will have a problem with intercooler piping it hitting your frame rails. You will need to either clock it up 2-3" or further down. Looking good I love holset l28's.
  21. Damn I would love to go but don't think a 1300 mile trip would be worth it.
  22. LOL OOOOOPPPPSSSS I forgot about that part of the video. Umm.. maybe I should edit that out. Funny thing is I wasn't speeding he pulled me over for no front license plate and I got to find out the hard way I had a speeding ticket from 5yrs earlier.
  23. Hey Phil what program do you use to edit video. I'm looking to make a compilation of my z with sound. Thanks
  24. Yes, yes I do. Only problem is I would have to decide road course or drag racing for the next build. No more strandling the fence. So basically auto vs manual. I love manual:icon54:
  25. I was bored so I decided to make myself a youtube page so I uploaded lots of my 260z videos and a few of my gto. (more to come) http://uk.youtube.com/profile?user=thumper2750
