Cable
Everything posted by Cable
  1. I don't think we are talking about the samething. I just need the rubber with 3 studs that sits on top of the of the spring.
  2. If you have the pair, they are black in color, and the right price shipped to Bakersfield, Ca. 93308, I might take them them off your hands anyway and figure a way to use them. Thanks!!
  3. Hey Denis, if you still need the lense, I have one and its yours for the asking.
  4. Hey guys!! My passenger side rear strut insulator crumbled and I need a replacement. How much shipped to Bakersfield, Ca. 93308, if the price is right, I have my finger on the PayPal button. Thanks!!
  5. I need a strut insulator, how much shipped to Bakersfield, Ca. 93308? Thanks!!
  6. I went with the non-vented Toyota caliper setup and went with organic pads against my better judgement, but it was they had in stock and I need my car back together. They work fine for normal stop and go driving, but one good hard stop and they uber fadded. So now I am going to break down and spend some coin on the good semi-metalic pads.
  7. I ended up having to have them power bled and they now work just fine.
  8. Hey Bo, I guess you missed the part where it says DOOR panels, not KICK panels... I don't have much interest in kick panel speakers because I don't feel like removing the kick panel speaker in order to get to the fuse box. Thanks anyway.
  9. Spoken just like noob. --------------------------------------------------------- I think I can count on one hand how many successful LSx swaps into Z32's. Unless you have extreme fabrication skills and/or deep pockets, you are going to be in for it on this one. Then again if you have the coin to drop on a LS7/LS9, paddle shifter trans, etc, then you have enough coin (or high enough limit on the credit card) to go for it.
  10. Hey guys, I am looking for pics of installs of 6.0" speakers installed in stock type S30 door panels. I don't think I've ever seen it before or even know if it is possible... Thanks!!
  11. Interested in a pair too if in my price range...
  12. Notice the footnote on the bottom of the ordering page that their headers are still in production... The motor does sit at least 3" farther forward VS the JCI kit. I would NOT be worth it to be to move the engine and trans that much further forward just to be able to run long tube headers.... Just my 2 cents.
  13. Hey guys, I am having my buddy Jay setup my R200 with an OBX. When putting everything back together the backlash is measuring 0.002" (way too tight) and the manual says between .005-.007". Anyone know where to find shims other than tearing into another diff to harvest them? Thanks!!
  14. Yup. The left side (driver) side caliper is even has a big "L" cast into it.
  15. Hey guys. I got a Kragen gift card for my birthday last month and decided to spend it on some Toyota 4x4 calipers for my S30. I got the version to use with the stock (non-vented) rotors. Anyway, I installed them today along with some new braided stainless steel brakelines. Added new sync DOT 3 fluid and began the bleeding process. I had a friend pump the pedal while I used a length of tubing over the bleeder screw into a small jar with some brake fluid to keep the air out. After while switching side to side no more air bubbles. However I still don't have any piston movement on either caliper. None at all. The pistons haven't even moved enough to take up the space between the pistons, pads, and rotors. I am getting fluid to the bleeders as I had to refill the master cylinder a few times. So now I am at a loss. I thought it might be the master cylinder, but it was replaced 9 months ago and was working fine yesterday with the stock calipers. Ideas guys? Thanks!!
  16. What was it running in the quarter? I find it hard to believe the car is untuned with 42# injectors, an aftermarket throttle body and Vic Jr intake. At best the car would run pig rich since the LQ4 come with 22# injectors from the factory...
  17. That car and those exact pics have been posted on here before, I think he is a friend of BigDees.
