Everything posted by Bartman
It depends on the specific components you use, but it's easily to spend $1,000 - $1,200 or more. The cost varies on the lines you use, the compressor, condensor, control panel, where you purchase, etc. I bought all my Vintage Air supplies directly from them, so I paid the list prices you can find on their website. I also upgraded my control panel, dryer, bulkhead plate, and probably a few other items.
*pulling my motor* what steps to take? need advice!
Bartman replied to OlderThanMe's topic in Miscellaneous Tech
When I pulled my L6 I did it with the transmission attached, and I think it went pretty smoothly that way. I just followed the instructions in my repair manual, and it didn't take more than a few hours. You don't have to drain your transmission, but if you don't you will need some type of a plug for the rear end (something similar to the end of the driveshaft) otherwise it will go everywhere. Have fun and good luck! -
I don't see any advantage to this setup. I thought the whole point in moving the alternator was to have a shorter belt with simplified routing. This system doesn't appear to deliver on either one. The Alan Grove mount has been discussed, and the consensus seems to be that it wpn't work on a Z.
Rear disc brake setup questions
Bartman replied to deja's topic in Brakes, Wheels, Suspension and Chassis
If you aren't pushing a lot of horsepower and you don't plan on dumping your clutch (if you have manual) you can probably get away with the u-joint halfshafts. If you're going to be driving it hard it may make sense to go with CV's. I think this is one of those things where you get what you pay for. If you want the extra strength you have to pay the extra money. I'm not aware of anyone else selling the adapters other than ModernMotorsports. -
Carb'd LS2 - 240Z on the way!
Bartman replied to Pop N Wood's topic in Gen III & IV Chevy V8Z Tech Board
Looking forward to hearing and seeing how your project progresses. I think in general people don't seem to understand why people go with LSX engines with carb's, but I think there are many benefits to it. -
Here's a link to the exterior pic of the car: http://www.turbobuicks.com/forums/attachment.php?attachmentid=17424
That looks pretty far forward, is this the final position? If so I'm surprised you needed to do any clearancing for that position. I'm wondering if you're going to have problems installing headers, or does John have special headers to go with his kit. How well does you're shifter line up with the stock opening? BTW, congrats on getting the engine installed.
JCI LT1 Kit arrived...pic inside.
Bartman replied to dat240zg's topic in Gen I & II Chevy V8 Tech Board
BTW, neither of these kits will work on an LS1; although John's does have one specifically for the LS1. -
Here's a link to the video as well as a discussion about it: http://www.metacafe.com/watch/152624/criss_angel_and_half_a_woman In the discussion you will find a link to how he levitates, that's pretty interesting to watch: http://www.youtube.com/watch?v=pRMHmnr4b60 This is a link to the woman some people think was used for the first stunt: http://www.five.tv/programmes/extraordinarypeople/womanwith/
Okay that's really wierd, but I'm waiting for the two pieces to go back together. The video just ends with the top half looking at the bottom half and then going away. Is this lady still in two pieces? This guy does very strange stuff, I watch his show every now and then http://www.crissangel.com/indexFlash.html
I finally figured out that the stock Datsun sending unit does not directly fit into the Chevrolet head. This thread gave me the info I needed and I ordered an adapter from JTR. http://forums.hybridz.org/showthread.php?t=95421 I feel like such a knucklehead:lmao:
Yes I used teflon tape on the threads, but I think it's leaking between the sending unit and the nut (no threads here, it's just an interferance fit). In fact I think the teflon tape on the threads caused me to lose my ground and made the gauge stop working. I put teflon tape on the threads of both my stock oil pressure sending unit and my water temperature sending unit, and now neither one of the gauges work...there might be some connection.
I installed the one I got from PartsAmerica and it leaks! I figured I must need to get one with a retaining nut, so I bought another sending unit and retaining nut from MSA. The parts arrived yesterday, and the nut doesn't seem to fit on the sending unit any better than my old retaining nut on the PartsAmerica sending unit. How can I install a Datsun sending unit on my engine without any leaks?
It does seem like a lot of money for what you get. Good luck on the conversion, and keep us updated with progress and pic's. -
thanks Jody! By running the 3900ohm resistor the way you described (and the mod described by Mike Chaney) I shouldn't get an error code. Is that crorect?
It looks nice and clean. It also looks like the motor has a few upgrades already, maybe you can just run with that.
How 'bout a Hybrid Burger. What’s a health-conscious burger lover to do? The real thing tends to have too many calories and too much fat, but meatless burgers seem to lack the flavor and consistency of real beef. St. Louis-based Solae LLC has come up with a solution, a patent-pending invention called SoleCina that involves both the process and the ingredients to produce either a “hybrid†meat — part soy, part real meat — or a completely meatless food that tastes like chicken, beef, pork or turkey. http://www.msnbc.msn.com/id/13580172/
So I went ahead and purchased a cable and downloaded TTS DataMaster. It worked great and I went ahead and recorded a test run of a little over a minute. I just started it up, let it idle a little bit, and revved it a little. Well DTC Code Number 43 is set, which is the Knock Sensor Circuit. Tim (the PO) had already put in a inline resistor in the wiring, but that may not be enough with all the upgrades I recently completed. I'm thinking that I should install an LT4 Knock Sensor Module, which seems to be a pretty common upgrade for upgraded LT1's to prevent the computer from pulling out excessive timing. Anyone else with an LT1 installed one of these LT4 sensors? In the short little recording I made the spark was retarded a good 12 - 13 degrees when the engine was revving. Is this normal or excessive?
If a V8 is what is appealing to you, then go with the Rover V8. In your original post you said "the V8 will always appeal to me" twice. Get what you like or you'll regret it sometime down the road. Maybe you'll be happy with something else for a while, but then you'll see someone else in a nice zed with a V8 in it and you'll wonder why you didn't go that route as well.
Looks like you've been putting a lot of work into it lately. Is this the same Z I've seen at several events over the last couple of years?
I'm hoping to be at the JCCS again this year as well. I got an email from them earlier this week about this year's show, and here's the contents of that email for those that may be interested in entering or attending. JCCS 2006 News Announcement: Registration for the 2006 Japanese Classic Car Show 2006 begins on July 1, 2006! Dear Japanese Classic Car owners and supporters: We are pleased to announce that the 2nd Annual Japanese Classic Car Show will again take place at the Queen Mary Event Park in beautiful Long Beach. September 30th is the day for this celebration of Japanese automotive history, when you can meet other car enthusiasts and see incredible classic cars from Toyota, Mazda, Nissan/Datsun, Honda, Mitsubishi, Subaru, and more! Last year, the Japanese Classic Car Show was covered by many magazines, newspapers, and TV stations. Now, the public is realizing the allure and excitement of the Japanese “Old School†vehicles. Please register to take part in this year’s Japanese Classic Car Show. Space at the event is limited, so we encourage you to register early. As always, although prizes will be awarded, the main purpose of this event is to learn about Japan’s automotive history and to delight in the Classic Cars of all Japanese car manufacturers. If you are interested in volunteering to work for this year’s Japanese Classic Car Show as “JCCS STAFFâ€, please let us know. We would greatly appreciate your help in making the 2006 Japanese Classic Car Show possible! $30.00 Per JCCS Entry includes: A JCCS 2006 event T-shirt, JCCS 2006 commemorative item, drawing ticket and goodies! On-line: PayPal or Major credit cards: PayPal membership is not necessary Mail-In: Downloadable forms will be available. All Pre-85 Japanese cars are eligible including later years for models that were first built in 1985, such as :Toyota MR2 AW11, AE86, Nissan 300ZX, Mitsubishi Starion,Dodge Colt (MITSUBISHI Gallant!),RX-7,Honda Civic 1st gen.... etc... Please watch for upcoming details and news. If you also interested in Vendor Booth, the space is also limited so we encourage you to contact early. Hope to see you all at the Queen Mary! Sincerely, Japanese Classic Car Show Association P.O. Box 1400, Hawaiian Gardens, CA 90716 Phone: (562) 472-4562 Fax: (562)402-7579 www.japaneseclassiccarshow.com E-Mail: operations@japaneseclassiccarshow.com
When are you going to finish the first one? It sounds like a three car garage isn't going to be enough for you.
