Great question, I have no idea why.   Maybe your car is a female and she's punishing you for leaving the gas door flap open....5 months ago
I can't even tell how much air can pass thru a S30's radiator at cruise without the aid of a fan, not to mention a ZX which is what you have IIRC.   IMHO the large radiator opening on S30 might allow it to cool unaided at higher speed, but a ZX is altogether more aerodynamic with smaller frontal opening and a integrated G-nose feature.   I suspect there is lesser air that can pass thru the ZX rad opening unaided at the same speed.
Perhaps the direction of wind plays a role.   When you travel against wind, the wind-to-car speed is more than 60, so you pick up some good cooling.   When you travel with the wind, the relative wind speed is less than 60, less air pass thru the rad, less cooling.   If you were travelling slightly uphill then the engine requires a heavier load to maintain the same speed and generates more heat.   If you cruise with top gear then the water pump is driven at a low speed which leads to slow circulation and higher temp.....etc etc.
