KnightoftheRound
Everything posted by KnightoftheRound
Curious if anyone could tell me what kinda steering wheel this is? I figure its an old grant or something, but it has no identifying markings. It's real wood by the look of it, even the 8 bolt coupler/spacer behind the wheel is wood. Pulled it out of a 70 2000 Roadster that was on craigslist for parts in my area. Thanks for any insight. I was going to use an old MOMO wheel I had due to the size, but this one is just as small but is still wood, which I am fond of, so I figured I'll use this one instead.
s30 Fiberglass tilt front clip i've googled for hrs...
KnightoftheRound replied to vega's topic in Body Kits & Paint
Not all our pocket books are the same size. Didn't know John Coffey made fiberglass parts, but apparently he owns Beta? I guess I'll look into that. -
Considering a single OEM horn is $97-$110 retail at a Nissan dealer, depending on the horn, although likely unavailable, I don't see how $15 is a lot of money? Unless you left out a zero on the end. Then again, the stock horns sound pathetic and I can't imagine why, other than originality, you'd want new OEM ones. I had planned on going Hella, they sound pretty decent.
Perfect, as in, fitment, or just little things here and there, like nicks, scratches, etc? I'll buy a fiberglass hood in a heartbeat if I don't have to go severely out of my way to make it fit. A wipe of filler here and there is cool, half a gallon is not. No other fiberglass hood supplier seems to have a good reputation. Preferably it would work with stock hinges. -
Have you seen any of his hoods? I haven't seen anything on the quality of his hoods, and I don't remember seeing pictures of it last time I was on the site. His other stuff looks good from pictures though. -
I like it too, my Kamei air dam was like that, without the little triangle cut out thingies in the corners. If I ever find another Kamei air dam, I would throw money at that person in a heartbeat. Sorry pictures kinda suck, maybe someone can lighten them up to see it better.
Rota Kyusha
KnightoftheRound replied to ComicArtist's topic in Brakes, Wheels, Suspension and Chassis
Lower than -40 and I would imagine you would need larger flares or some craftiness. My rear SSRs are 10" -40, with 225s it's a pretty tight fit! -
There are several several R32s here in Virginia beach, GT-R and otherwise, at least 2 S15s that I have seen, an R33 GT-R, R34, a Pulsar GTI-R, imported FD RX-7s, and the like. Gotta picture of my friends S15
What exactly is the reason against rolling the lip a little? I didn't see it mentioned. Why would you want to spend more money on tires that may or may not work, and cause more problems, when rolling your wheel arch lips is free, fast, easy, and generally unnoticeable? Also you can fit a slightly wider range of tires and wheels when done. Not trying to come off in a negative way, just want to know the reasoning.
Totally rock solid or mushy? I've bought brand new cans of primer that were like that, and I have had to stir for a good long time before it was useable. I actually used some primer that was a few years old recently, but I had to stir the hell outta it. The solids in the primer sink to the bottom over time and it has to be mixed back in. Though this is with urethanes, don't know about the lacquer.
I think a light stretch compliments the car. Giant square tires with just ZG flares look out of place imo. Heres a 225/50/15 on a 9.5 and 10. And the all shameless plug Otherwise yeah, wider sizes for 15s are hard to find. Would have liked to find 245s in 15" diameter to make the stretch a little less, but oh well. EDIT: Incase anyone asks, all those Zs in the background in that second picture were rustbucket parts cars I stripped out for parts for my rustless 70 (Which was basically a rolling shell) I have cleaned up my mess to stay good with the neighbors =]
GTR Is "Aurora Flare Blue Pearl" My old ZXT was a dark blue, was some sort of mix of crap we had lying around. Was the darker Porsche blue color, mixed with a metallic black, with scarab red pearl flake squirted in, lol.
What Takayuki said, Dealer cost is actually around $235, suggested retail is like 400ish. Price would likely vary from dealer to dealer. I'd sure love to get a new set for 130 a piece!
Will these wheels fit
KnightoftheRound replied to Daphur280's topic in Brakes, Wheels, Suspension and Chassis
Big flares as in BAMF or ZG? My wheels are 10" wide with a -33 and -40 offset, and they sit just perfect with the very edge of the standard ZG flare (Although this is with about a 3" drop and no camber correction due to being a test fit. Your wheels would be about 1.5" more inset than that. I run 225/50 tires all around on them. I would think at those widths and offsets, you would get kinda close to the suspension? If mine still had suspension in it I would go check for ya. =/ -
I think both look pretty awful. They don't suit either car at all.
Looks good, you modified your bay a LOT more than I plan on doing. As mine sits, I have camber plates welded in, brackets removed, some holes I definitely will never use again welded up, wire harness holes welded up with backing plates. Sitting in self etching primer right now. Are those brackets on your shock towers for mounting a strut bar?
For instance, I am doing the whole wire tucked bay thing. I no longer need the fire wall wire harness hole or wiper harness hole. I also no longer need several screw holes. For the wiper and wire harness holes, I cut a small square piece of sheet metal and welded it behind them, but obviously its still inset there. I also need to smooth out where I welded some new metal where the battery was. Are body fillers OK to smooth out these small things in the engine bay? Last thing I want is to go through all this work having a clean engine bay and the thing crack or what not. The stuff wouldn't be much thicker than like 1/16" inch. Probably more in the battery area. -Daniel
I don't think anyone has used them on an S30. I have two friends that used to have them on S13s, and the general consensus seemed to be that they aren't that great. Supposedly they go lower than Megans, but even Megans on the S30 go more than low enough. I called D2 to ask about specs (like body threads to see if they would work with other peoples adapters already on the market, and their tech department didn't even know). Riding in one of those cars while it still had D2s on it, the ride quality was somewhat rough, though I think it had something like 12k/10k springs on it. Ride quality probably isn't something to be concerned about if your moving to aftermarket performance suspension anyways though. EDIT: Sorry, I didn't realize this was the S130 forum, I saw the post topic on the side about coilovers and just assumed S30. My view on the ride quality still stands though. If I had my 82 longer, I probably would have gone the coilover route and got rid of my cut springs.
I didn't have any cold start or emissions crap left on my L28ET swapped 82 slicktop. Didn't have any problems in winter. Sometimes if its really cold you have to keep the idle up so it won't stall by depressing the gas pedal a little, but its only for like 10-15 seconds.
Does anybody make a ZG flare reversal kit?
KnightoftheRound replied to RebekahsZ's topic in Fabrication / Welding
Can't see how that would be possible considering you make the cuts yourself, then every one's cuts and welds will be different. Probably easier to replace the whole panel than to make someone elses cutouts fit. -
ATTN: 15x9 Shakotan Owners
KnightoftheRound replied to Soup's topic in Brakes, Wheels, Suspension and Chassis
225/50, anything wider is hard to find. Not sure much wider would fit anyway, lol. I plan on using the MM 240SX rear brakes, though. Somewhere down the posts and quotes I got confused at who had the rear disc conversion apparently.
