steve260z
Everything posted by steve260z
  1. Have you pulled the plugs? Are they carbon fouled? If so that can confirm the car is actually running rich. Do you have a timing light? If not they are fairly cheap. Sears/other parts stores. But you need a timing light. I'm sure there are many posts on checking the timing either here or on Zcar.com (no need to repeat the procedure here.) Its straightforward.
  2. I would first check the carbs regardless. Are they SU Carbs? Make sure the adjustment nuts are not turned too far down resulting in a rich mixture. Among other how to sites, here's one: http://www.sonic.net/~kyle/su.html
  3. First, thanks for the responses. Block is the F54. The only passageways in the block which don't have a matching hole in the gasket are circled. See below:
  4. I have the 90.5mm metal Stoker Gasket. The coolant holes are not lining up. In this picture the gasket has small circular holes verses the "L" shaped (sort of) holes on the P90. Should I have the circular holes enlarged? On a drill press? On these next two pics there are no coolant holes in the gasket to match the head. Whats the best procedure here? Thanks for the advice. steve
  5. Thanks for the link. steve
  6. How long is your prybar? I used a 4 foot one. I'd first get the longest cheapest one you can find. Try that first if you're using a shorter bar. Harbor Freight or maybe Lowes/Home Depot for a longer one.
  7. I'm putting together my stroker. L28 with a P90 and 240sx pistons. (KA24s if I remember correctly) In assembling the block the piston rose above the block by .6mm. As described here: http://www.geocities.com/inlinestroker/index.htm (Actually a typo on that page. States .06mm but should be .6mm) I had the pistons ground down approx .7mm. So that leaves a deck height of .1mm textbook. In measuring each install piston it averages .12 deck height. Coupled with my .8mm metal head gasket that give me a quench of approx. .92mm or .036 inches. Searching the web regarding the correct amount of Quench provides varying recommended distances between the head and piston. One post on hybrid z stated anything over .035" is too much and other engine building sites talk about running up to .05"... Suggestions anyone? Thanks steve
  8. Uh, oversized piston usually state the oversizing on them. Unless that "90" is a standard Nissan marking, could that block be overbored by .090"?
  9. I'm installing one as well. Here's a thread on zcar.com http://www.zcar.com/forums/890227/rear-main-seal-install-advice
  10. I'd test the compression before anything....then you can fix any problems with the motor apart.
  11. Tom, I'm putting a stroker together. Which ring do you need. I'll donate to ya. I had to buy 2 sets of 4 pistons. Have an extra 2 of everything. steve
  12. C, Ya,I have a couple of books suggesting the silicon..The direction I have the seals pointing seems to make sense...thanks, steve
  13. Installing the rear main seal on my stroker project. The pics in the Datsun rebuild book aren't exactly clear. Which way do the side seals go in relation the the expander and which direction do the rubbers seals face? Does the "U" of the seal face inward toward the motor or outward toward the fenders....so to speak? I assume outward but need to be sure. Thanks, steve
  14. A shout out to all crank pirates...........
  15. Z cranks are internally balanced. So yes, the shop will not need your balancer. Not sure what the above response is saying.
  16. I'm interested in buying if he passes Steve
  17. Thanks, but I think I got one. steve
  18. I'm putting a stroker together right now. I searched never found a non metal one. Are you sure you need a 2mm?
  19. Anybody have an exhaust valve laying around? Need the size for P90 or P79. thanks ss
  20. T, Thanks, yeah just a weekend ride. Regarding Kris, anything is possible but he needs to look at the block. N42 then dished pistons...F54 could be either. If I remember correctly. One would hope if someone put the p90 on their flat tops are underneath.
  21. Hard to know if its stroked for sure...Does it have a metal head gasket? Could be one clue
  22. Awesome! The SM needles work fine? Rev to 6500 with no problem?
  23. Thanks, I currently have a stage 2 Schneider cam installed on my current car. (Thats why I haven't test fit the head/n36 yet.) Steve
