I'm curious, isn't this your daily driver/parts hauler? Isn't it still under warranty? Why would you want to do anything to make it less dependable or destroy it? Couldn't you put that on one of your many other cars? Just curious.
It's close but the pic make it look closer than the piping actually is. I may have the turbo re-clocked a bit to point the outlet down. I'll talk to the shop on Monday. As far as the wastegate the shop made an adapter with two T-3 flanges and some tubing.
The turbo is a T3/T4 60-1 Ptrim. If I remember correctly there were only 20 or so made. It uses a prototype lotus housing from what I'm told. I know a few other members have this turbo so they may be able to provide more detailed specs. The turbo was re-clocked because it didn't look like we could fit the intercooler piping next to the shock tower.
Clifton - I think the pic you're referring to is of the ABR 280ZX in Japan. If you saw pic of my primered and beatup hunk of junk you'd realize the engine bay is the nicest thing on it.
I'll try to get some more pics up when I get it back from the shop.
I'm curious as how they came up with $14k? Was it appraised by Haggerty directly? I'm thinking about going with Haggerty as well and am curious as to the the process.
Yeah it's made by ABR. I can upload some more later. Last I heard it's not made anymore but I really want that wing. Wonder if someone has contacts in Japan that can find out.
Generally it's a corrupt temp file. If you go to Start > Run and type %temp% and hit enter your temp folder will open. As long as all your of applications are closed you should be able to delete everything in this folder and then you can try opening the file again.
Actually if you look at this map you'll notice that there is more than 6 counties that smog only on transfer.
http://www.smogcheck.ca.gov/ftp/pdfdocs/program_map.pdf
Do any of the folks using SDS have an excel spreadsheet for the fuel maps? I want to compare my values and I noticed something about a spreadsheet that will graph your maps from the yahoo SDSEFI group. Does anyone have something like this?
Thanks,
